Class 730 LNR & WMR Delivery/test Updates
Liam L
19 Jun 2020
They’ll be miles better than 323s I should think - 2+2 seating with tables, carpet, air con, LED lighting etc.
Definitely. Also cycle spaces too I believe. Which is currently a pain on a 323 as the cycle space is shared with the buggy / wheelchair space so will nice to have it separate.
The_Train
2 Jun 2018
Someone on WNXX said that a Bletchley guard (Chris Warmen) had said 23/10 if training continues as planned.
That would fit the latest narrative of the LNR 319s only surviving until the end of this month (although we've heard it all before :lol: )
Russel
30 Jun 2022
Lichfield
What routes would they end up working first, if this happens?
Do Bletchley guards cover the full Trent Valley route?
AJDesiro
10 May 2019
Rugby
MKC/Tring-Euston. Bletchley traincrew cover London-Birmingham via both Weedon and Northampton, some also cover the Marston Vale too, but the 730/0s won't make it north of Northampton, yet.
There's two good threads in the Railway Jobs & Careers subforum about driver/guard routes.
Silverlinky
3 Feb 2012
The 730/0's are not planned to run north of Milton Keynes, and with maintenance at Bletchley there is no need for moves to Northampton as was the case for 319's.
The first 730 diagram will be replaced either 23rd or 30th October with a further one the following week. The third will be a couple of weeks behind them.
Bletchley guards the only ones being trained on 730's for West Coast use, and they do not sign the Trent Valley route. Northampton and Crewe guards share work on the Euston-Crewe services.
warwickshire
6 Feb 2020
leamingtonspa
Exactly what I heard from a Lnwr guard last night, when travelling the Lnwr 319s for final time, however take with a pinch of salt disclaimer, possible 30th October 2023 just a slight bit more, due to same day the 150 event is taking place at Bletchley. Put the two together making the 30Th October 2023. IE A positive, possible launch day for both the150 and 730 together at Bletchley as a introduction to the new fleet launch event etc. But wait and see.
Techniquest
19 Jun 2005
Nowhere Heath
Wow we are close to seeing 730s in passenger action then! I smell a visit to MKC next month! :D
Can someone confirm it was 730009 on test at Stafford at around 1245, 13/10/2023 (today) please? I arrived on 390124, en-route to Crewe, and while it looked like I'd read '009' on the white numbers above the driver's windscreen I'd like to be sure :)
AJDesiro
10 May 2019
Rugby
I've read something saying that guards are only being passed out on them to work empty until an issue with the passcoms is rectified. Does anyone know if this is true, or just wibble?
Liam L
19 Jun 2020
Something doesn't add up, if the passcoms anit working they wouldn't be going into service so why would there be a need for a guard?
SCDR_WMR
17 Dec 2017
Crewe
Agreed. Can't say I've heard anything, sounds like maybe one unit has a passcomm problem which means it cant go into service. I guess we'll find out in a week or so.
AJDesiro
10 May 2019
Rugby
That’s what I thought would be the case, I don’t see how there could be a fleet wide issue when the similar 720s (and other Aventra’s) don’t have many issues.
Jacob Porrett
28 Jan 2022
Telford
730007 and 730006 were on test at Stafford today. They both departed at the same time heading to Crewe on their respective services.
Merle Haggard
20 Oct 2019
Northampton
Weekdays there seems to be a regular departure from Stafford around 13.45 to Crewe for 730s on test. About this time, there's a Blackpool down the slow and a Manchester via Crewe down the fast both stopping at Stafford and it runs in front of both, after seeming to test the doors in the down fast platform Doesn't seem ideal.
Jacob Porrett
28 Jan 2022
Telford
They both arrived and around 2-3 minutes later they both departed. Didn't test doors or anything. More millage runs by the looks of it.
SCDR_WMR
17 Dec 2017
Crewe
DI retraining runs for Crewe Drivers I believe. They do the door testing on milage runs which tend to sit at Stafford a while
Silverlinky
3 Feb 2012
Guards and Drivers. The passcom reset is in the drivers cab, remembering these trains were designed for Driver Only. The question was who presses the reset button.
SCDR_WMR
17 Dec 2017
Crewe
Why is that even an issue, I've never worked a traction that the guard uses the reset in the cabs, yes they use a T-key to deactivate the pressed passcom, but I can't see there being an issue with the drivers resetting it in the cabs.
I haven't had the chance to view the training documentation for the 730s yet though as they are with the area manager, be interested in knowing what it says.
CHAPS2034
13 Mar 2018
Oooh. Looking forward to having a go - if anyone gets wind of what diagram and what day that'd be brilliant, as I'm sure I can coincide a trip to the office with it! :)
Looking forward to reading your review, no doubt including comments on seats and seating / window line-up...:smile:
37884
20 Oct 2023
I spoke to a driver today, apparently the 730s are still miles off and training is no where near complete.
