Class 730 LNR & WMR Delivery/test Updates
That’s promising then. Word on the street is that LNR want rid of the 319s and even 350/2s ASAP.
Network Rail are doing some work on Bletchley CS (related, I think, to EWR, though I may recall wrongly) that will reduce their stabling capacity there, resulting in a few short-forms of trains that start/terminate there. It came out as an email the other week.
Silverlinky
3 Feb 2012
There is no diagrammed 9 car 730 work for the current timetable, just as there was no diagrammed 12 car 319 work for this timetable. Not to say it wouldn't happen, but if it did as a result of ad-hoc strengthening for example the infrastructure is in place.
Bletchley TMD is undergoing some work in connection with EWR, and all stock in the TMD is being moved out next week, 730 units will be stabled in the CS from Monday I believe. The 230 stock has been moved to the fuel road to be accessible for imminent removal of the units by road.
Thanks. Does that mean that the present 8.319 diagrams will become 6.730 in due course? That'll be cosy!
Class15
30 Dec 2021
North London or Mildmay line
Right, time to try and get 350s for a change!
Indeed! I’ll love it!
Foxxle
23 Feb 2022
Just seen 730008 + 2 others in the sidings outside Euston, Camden CS I think it is? Next to loads of Class 378s
011, 014, 015, 017, and 018 are all sitting in sidings between Bletchley and Milton Keynes too.
59CosG95
18 Aug 2013
Beeston (Notts)
730039? I did not realise that there was going to be that many. My book shows only up to 730036.
The original order was indeed for 36 3-car units, but it was also for 45 5-car units (a total of 333 vehicles); this has now been amended to 48 3-car units and 36 5-car units (a total of 324 vehicles).
Wyrleybart
29 Mar 2020
South Staffordshire
That is how I understand it, but confusion over the 5 cars. I am sure I read somewhere that class 730/2 has been dropped and all 5 car units will be 730/1s. So where does that fit with the plan to split WMR and LNR, which I believe the designations were to distinguish. Presumably as the 730/1s are being turned out in green they will be for LNR and all the 3 car 730/0s will be WMR
43096
23 Nov 2015
Apart from the livery, as far as I know nothing. They were both going to be 5 car 110mph EMUs but some with WMR and some with LNR, as was the intention when they were ordered.
But things change where government departments are involved !!
The difference was seat layout. 2+2 on one type and 2+3 on the other. All were for LNR.
SCDR_WMR
17 Dec 2017
Crewe
And the change from 3+2 to 2+2 seating. As can be seen on the 2 5car LNR liveried units at Crewe
AJDesiro
10 May 2019
Rugby
I thought both /1 and /2 were going to be LNR branded, with the /1s having an interior similar to the 720s except with first class, with the /2s having a regional interior, with 2+2 seating, tables, armrests, and first class. Of course all LNR units are planned to be 2+2 now, and hopefully it stays that way.
That was the original plan, and would have seen more 350s in the West Midlands than the revised plan (as it's been found that 8.350 is a sweet spot for a lot of south WCML services post COVID). The increased /0 order means hardly any 350s if any at all will work WMR services.
I believe the plan to split the two TOCs (other than in branding terms) has gone away, though.
AJDesiro
10 May 2019
Rugby
The current plan is probably best for brand identity, it’s certainly odd seeing every WMR electric service aside from the cross city run by 350s. I just hope that if the 730/2s (or whatever they’re going with for the subclass) are still running Trent Valley services as they’ve been planned to as of late, that they are run as 10 car, and not 5, 8.350 isn’t enough on the Trent Valley anymore, considering the amount of people changing at rugby from an LNR from Birmingham, onto the Trent Valley service to London in order to save a large amount of time.
I would hope so too. The idea of the 730s being on Tring/MKC stoppers also makes some sense because these are much quieter off peak, with far less leisure travel, so 5 off peak (other than the vomit comets) will probably work fairly well.
The awkward one is Liverpool to Brum, for which 2tph at 5 car would work, but 1tph at 5 car won't and 10 may be overkill, so it'll be interesting to see which way this ends up going.
AJDesiro
10 May 2019
Rugby
I traveled on a Liverpool to Brum service today at around 3 pm, it seemed to be ok with 8.350, but I have been on some very busy Liverpool services in the past too. I do wonder whether 730s will run Liverpool's, considering that most LNR routes through Birmingham will remain 350s, it just seems peculiar that these would be run as 730s, perhaps it would be beneficial at peak times? If 2tph didn't seem to be a dead plan, a single 5-car every 30 minutes could work, there are enough LNR units to run the service.
If they are to be used on Euston-Tring/MKC, Euston-Crewe, and Euston-Liverpool, and if every service operated as 10.730, that would be 26/36 units in use each day, if my calculation of the number of diagrams is correct. I'm not that well educated on how much money there is to be saved by coupling and uncoupling to meet demand throughout the day, part of me thinks that it may just be easier to keep them coupled throughout the day, as is done with 8.350s currently.
I do wonder what the future of the 350 operated services will be like in terms of unit formations though, as it seems that there will be many more 350s out of use each day, considering Euston-Birmingham requires 22 units currently (11 8-car diagrams), with the Abbey Line requiring one, and Birmingham-Crewe requiring around 3 or 4 (though I'm unsure as to whether this will be run by 730/0s in the future, as it is displayed as a WMR service on the PIS, but is also branded as an LNR service on route maps), meaning only around 27/50 units would be in use each day, could we perhaps see the bolstering of some services to 8/12 car? Euston-Birmingham is healthily loaded, and less frequent than prior to COVID, though I understand that there are very few stations north of Northampton that could actually handle 12 carriages (Rugby, Coventry, Birmingham International and Birmingham New Street are the only stations if my memory serves me correctly, leaving Long Buckby, Canley, Tile Hill, Berkswell, Hampton-in-Arden and Marston Green, the latter only gets a Euston-Birmingham service on Sundays at 1tph). I wouldn't be surprised if the DfT didn't allow this though.
Dave91131
13 Jun 2018
I noticed what I think was 730034 in the yard at Wembley earlier today, amongst the lines of Renatus 321's. Can anyone advise if any other 730's are there with it please?
008 / 009 / 012 still stabled at Camden too.
Wyrleybart
29 Mar 2020
South Staffordshire
Would the fact that 730s are 23m bodyshells whereas 350s are 20m length, mean more room ? Theoretically a 730.5 is 115m whereas a 4.350 is 80m
AJDesiro
10 May 2019
Rugby
It would do, yes, a 10 car 730 is the equivalent of a 12 car 350, with the 730s having 24m carriages, though it would be very foolish to run single 5 cars on many of the routes that the LNR units are planned to run, considering 5.730 is the same as 6.350.
It will be interesting to see how certain services, like the Chase Line, will react to having 3 car 730s when they previously had 4 car 350s too.
pokemonsuper9
20 Dec 2022
Greater Manchester
At least short forms will mean a 6*350 compared to a 4*350.
childwallblues
3 Jul 2014
Liverpool, UK
Liverpool to Birmingham is currently hourly 8 car but used to be half hourly 4 car. 8 cars do not fit on to the platforms at Smethwick Galton Bridge, Penkridge, Winsford, Acton Bridge and Liverpool South Parkway. The current service leaves Liverpool at xx33 and reaches Crewe at xx15 so missing the connections to Derby/Nottingham, South Wales and the Trent Valley.
Reverting to a half hourly service using 5 car 730s would mean that passengers would not be sitting around Crewe were the waiting facilities are very poor in quality.
VicH
11 Feb 2020
Chelmsford
I believe 024 is there.
I noticed one at the south end where the loco's stable, was that 034?
SCDR_WMR
17 Dec 2017
Crewe
Could we perhaps see the bolstering of some services to 8/12 car? Euston-Birmingham is healthily loaded, and less frequent than prior to COVID, though I understand that there are very few stations north of Northampton that could actually handle 12 carriages.
12 car 350 is due for its 2nd test run on Trent Valley services, with the plan to introduce it as a way to improve capacity on weekends. Staff are very reluctant to accept 12 car north of Rugby but it has been proven that UDS from 12-4 does work so it will become an option for planners.
This hasn't been tested on RUG-BHM yet as far as I'm aware.
