Class 730 LNR & WMR Delivery/test Updates
185
29 Aug 2010
Being (hideously) orange - how did that get an easement from ORR/RSSB to not have a safe working line aka a 'Cant rail' ??
29 Aug 2010
Doesn't the white line offer that?
Cant rail is supposed to be orange. Just concerns me that long term there's a slippery slope where things like this are no longer considered important by the RSSB until there's an accident.
SCDR_WMR
17 Dec 2017
Crewe
Choice of colours have changed over the years, given that the fly doors are no longer required to be yellow, does the change of colour to the Cant Rail really matter more?
Surely as long as it's easily defined/contrasted it will still be obvious to those who would need to know where it is
Northampton
Is it specifically being Orange important? Surely just being a clearly visible colour is all it needs to be.
AJDesiro
10 May 2019
Rugby
I seem to recall that AWC’s livery has a slight bit of white for the cant rail too on the orange parts of the livery, very much a more common thing now, as long as the line is clearly visible and well contrasted, I fail to see an issue.
rogercov
8 Feb 2019
Coventry/London
Just saw this coming through Coventry on way to Bletchley:
Too far away to see number but could be 730024
Saw it in the platforms at Stafford earlier. Looks reasonable, though window alignment is a bit lazy. There appears to be a 1+1 seated section which I suspect will be the prize!
rogercov
8 Feb 2019
Coventry/London
If the one seen at Stafford was 024, then the one I saw at Coventry was not.
The Stafford one is running to/from Nuneaton all day, as one of them did last week.
1D54
1 Jun 2019
Are there any of these usually parked up at Crewe that can be seen from the WCML?
The_Train
2 Jun 2018
As far as I know there are only the 2x LNWR units (101 & 103) parked at Crewe Arriva Traincare - both have recently been sat next to the WCML running lines so easily visible (although I've not been that way in a few weeks)
Elecman
31 Dec 2013
Lancashire
They are still there
AJDesiro
10 May 2019
Rugby
730004+730024 were doing the Stafford-Nuneaton runs today. They have just returned to Oxley (saw this on the Bushbury Railcam).
Therefore it was two other units that went to Bletchley today.
Most likely heading to Bletchley for driver training duties, the paths for training between Bletchley-Northampton-Rugby and back are beginning to appear it seems.
Liam L
19 Jun 2020
The_Train
2 Jun 2018
I thought that too but it was definitely moving at quite a good lick
Definitely good to see them back out, but I won't panic too much about getting my final 350/2's just yet considering no more of the LNWR 730's are currently coming off the production line
Liam L
19 Jun 2020
Someone correct me if I’m wrong but I think the priority is getting the 730/0s built, that’s what it seems like anyway.
AJDesiro
10 May 2019
Rugby
I do wonder if after 730036 is built they start on the 730/1 construction, considering that the original order only had 36 /0s, building the extra /0s at a later date.
Nicholas Lewis
9 Aug 2019
730034 on 5Q04 stops at top end Tamworth opens doors and punters set off up platform and some nearly boarded but just managed to get doors closed in time!
Must be close to introduction?
