Class 701 'Aventra' trains for South Western Railway: progress updates
Goldfish62
14 Feb 2010
701014 just went past me leaving Clapham Yard (destination unknown), looked like a bunch of SWR bods in the cab (could see the name badges).
Can confirm that the two on the Windsor side of the yard are cut in all the time now (marker lights are a bit pathetic in daytime though!).
Just seen a photo on Facebook of four stabled at Wimbledon, all with tail lights on.
3973EXL
2 Feb 2017
47749 701050
47749 701052
25 Apr 2020
Dorset
Hi everyone, I've had a go at listing the current locations of each 701 based on various information sources available to me. I'm happy to receive any corrections and further information. Also happy to publish periodic updates. I'm based in Eastleigh so can regularly check units on test, at Arlington and at Eastleigh TRSMD Airport Sidings. File is attached.
Hi @Stew27005 ,
Update on 701 unit activity :
701041/042 both spotted in Bournemouth Depot but couldnt see 701037 which should be there.
701508/10 were moved down from Derby to Wembley on 5Q70 with 56098/50007 this week.
Hope this helps you.
brownandrew15
12 Aug 2020
Winchester
I saw 5Q90 Clapham Yard Sidings to Clapham Yard Sidings in Egham yesterday evening (at about 22:30), operated with 701014.
Realtime Trains and Railcam both show it as being operated by South Western Railway.
All the ones I have seen have shown ZZ rather than SW as the operator code.
Is this the first 701 to be operated by SWR, at least outside of depots and yards?
While in Egham, the doors were opened. I think I heard two sets of door opening and closing chimes.
Someone in high vis got off, walked down the platform, boarded and entered the rear cab as it departed.
Stew27005
1 Nov 2019
Eastleigh
Hi @Stew27005 ,
Thanks very much for the info.
Ive got a fair amount of updates and will run a revised listing sometime next week.
Thanks to those of you who have provided support.
Fastlane256
28 Jan 2023
Random question, does anyone know if the 701/0 and 701/5 configurations have the pantograph still attached to them? I know that SWR is currently only 3rd rail but if the Heathrow Southern Railway was to go ahead, they would need to be bi-mode.
traji00
17 Aug 2009
A few units might have had a pantograph for dual voltage testing, but the rest don’t (presumably some ballast exists to make up the weight?).
A token number did for certification, not sure if any are still fitted, probably wanted them back to fit on a 720.
The lease Co usually likes to know they can be used on AC so it has alternative uses if returned
Peter Sarf
Croydon
Would that mean that the pantographs and transformers are still fitted to the token number ?. I am thinking maybe the early AC test results would not be valid if enough hardware and software modifications are still being made since those AC tests.
AJDesiro
10 May 2019
Rugby
In realistic situations, do the ROSCOs ever bother to modify units for OHLE or 3rd rail? I could think of many uses for stored/soon-to-be stored units...
3141
1 Apr 2012
Whitchurch, Hampshire
I don't think that question has been an issue until recent years.
There was discussion in a thread about class 365s since some of them had originally run on South eastern third rail services. I think it was concluded that the cost of restoring third rail equipment on all of them was not worthwhile. They've all gone now, anyway.
Are there many other stored or soon to be stored units? Class 379 definitely. They may have a new life with GTR as 25KW trains. Class 458 looked at one stage as though they might go for scrap but now (probably) have a new lease of life. Class 350/2 are definitely vulnerable. Most other EMUs likely to be withdrawn are 30 - 40 years old. The exceptions are classes 375 and 376 on South Eastern, if ever the DfT makes its mind up about new rolling stock there.
If a ROSCO was considering modifying EMUs for OHLE from third rail or vice versa it would want to be very sure there was a lessee who would take them.
phil_
7 Mar 2023
Southampton
Correct me if I'm wrong, but I'm under the impression that all new builds have to have a spot for a panto, even if they're being built for 3rd rail (sadly I don't have a reference for this off the top of my head)? So I would think that would include actually being able to actually use AC if configured to.
Mainsideman
6 Jul 2018
Croydon
Have guards retained dispatch for the 701s during degraded working? I remember seeing something about this but can not find it anywhere!
XAM2175
8 Jun 2016
The intent is that any third-rail stock is capable of being converted to AC operation at some point in the future, should it be necessary.
No, they wouldn't need to be "bi-mode", as that would refer to adding engines or another source of traction supply. They would simply need to be dual-voltage.
701001, 701501/502 were the pan fitted units, I thought.
Correct, these are the three units that were certified by the ORR for dual-voltage operation. The DM and PM vehicles accordingly have different design codes.
Whether the AC kit remains fitted to them is something I don't know.
TEW
16 May 2008
It was to be for a time limited period during introduction. I can’t remember the exact date that Metro Guards were to lose dispatch competency, but it was likely to be before one turned a wheel in service.
I suspect what will happen is that Guards will be trained to dispatch 701s when they are first introduced and whether it is retained longer term will depend how often it is put to use.
Metro Guards losing dispatch competency, and subsequently reducing the training and assessment requirements was part of the savings required to fund the drop in Guard's hours.
pompeyfan
24 Jan 2012
A lot of the metro guards will need to retain dispatch competency on Desiros to work weekend engineering works via Feltham etc, also, unless the link system gets a shake up a lot of guards at places like Guildford and Woking will do metro work 1st half then a run down to Basingstoke/Alton/Pompey after their grub.
TEW
16 May 2008
The plan was all Metro Guards to lose dispatch competency and only work 701s, all the Desiro diversions would have to be covered by Commercial Guards. Mixed 701/ Desiro work and mixed method of operations was planned for Commercial Guards at inner depots.
pompeyfan
24 Jan 2012
Surely there’s not enough commercial guards and they’ll have to grow that establishment? It also doesn’t sound particularly resilient during disruption, we’ll have to wait and see as the plan has probably changed several times since! Apparently the COO said on a recent colleague call that depot driver training has finally begun for 701s, although no news on mainline drivers.
Mainsideman
6 Jul 2018
Croydon
So woking and guilford metro guards would lose alton basingstoke and pompy? Surely that makes zero sense from a business prospective!
TEW
16 May 2008
There were always some unanswered questions. The whole deal had to get DfT approval and cost savings were necessary to keep a guard on every train and reduce working hours. Reduced training and assessment requirements was a big part of that.
That was certainly the plan. It may not make sense from a reliability perspective, but it does from a cost saving one.
Mainsideman
6 Jul 2018
Croydon
D
With regards to reduced training and assessments? Would route learning go, and guards be able to work any route basically blind?
TEW
16 May 2008
D
No, there would still be a route learning requirement, but it would be less.
pompeyfan
24 Jan 2012
If it’s true and guards on 701s have no dispatch competency at all, this will be the first “classic lines” safety critical but without door competency role. There is no model currently available to base what the training package will need to be.
They’ll still need PTS, Short Circuit Bar, GSMR and emergency protection training as well as some form of look and learn. Also I’m not sure any thought has been given to how guards will work the trains on crush loaded sporting events. No middle cab so loiter around the accessible vestibule and hope you don’t get covered in beer I guess!
swr444
26 Aug 2008
Word on the grapevine from ops standards and various drivers is that 701s will now be driver open guard close as drivers have refused to do the final PTI check. We shall see if that’s true eventually
43096
23 Nov 2015
Don't SWR drivers have DOO-P already in their contract T&Cs?
Goldfish62
14 Feb 2010
What's PTI?
Refused, or declined unless it comes with extra salary ?
Carlisle
26 Aug 2012
Didn’t Heathrow Express initially require a second safety critical staff member for evacuation purposes, in the tunnel section at least?
