Class 700 getting confused with Class 70 (700001 vs 70001)
Condor7
13 Jul 2012
Penrith
I have just been looking at photos of the new Thameslink 700, numbered 700001.
Does that not seem very similar to the class 70's i.e. 70001 etc and could this lead to confusion or errors within the rail industry?
bolli
26 Sep 2011
Surely no different to something along the lines of the 31 vs 310?
The numbers are properly 70 001 and 700 001, so quite different.
The two numbers should not be run together (in an ideal world...).
Life was easier when we had D and E prefixes to loco numbers. ;)
Loki
24 May 2013
West Midlands
Shouldn't newly produced units also have their UIC numbers printed? I though all traction needs to have it since 2007?
D7666
12 Aug 2013
No.
There is no UIC requirement for pure domestic traction to display full UIC numbers.
Here domestic means the stock of any railway captive with any one land.
Nick
The 2011 version of the group standard on rolling stock registration and identification is fairly complex but AFAICT does still allow that what is now known as the full EVN (European Vehicle Number) doesn't have to be externally or internally displayed if a unit, coach or loco is not intended for international use. Basically the front part and check digit can be left off what is displayed, leaving a '7 digit' number for each vehicle. MU set numbers remain as a 6 digit number with 3 for the class and 3 for the number.
Here's a link: http://www.rgsonline.co.uk/Railway_...ck/Railway Group Standards/GMRT2453 Iss 2.pdf
D7666 had already said as much, but I'll leave this in case anyone wants to follow the link...
dosxuk
2 Jan 2011
What sort of confusion and errors? If it's on paper, the difference should be obvious, and if it's identifying them in real life, even more obvious - if it's belching smoke and flames, it's a 70, otherwise it's a 700.
eastwestdivide
17 Aug 2009
S Yorks, usually
You could equally well argue that 70001 and 70011 are very similar and could lead to confusion or errors. The possibility of human error being the driving factor behind the UIC check digit I suppose.
I say print a barcode on all rolling stock and give all staff a barcode reader! That'll fool those pesky trainspotters. Could lead to some interesting accidental transactions in the station cafe bar too - two cappuccinos and a line of coal hoppers, that'll be £££ - cash or card?
ash39
8 Feb 2012
As long as you can correctly identify the difference between three zeros and four zeros, or a bright green and yellow diesel loco vs a passenger EMU, it should be fine.
If not, I think it's the least of your worries!
D7666
12 Aug 2013
375301 375701 etc meeting 377301 377501 etc, or 377601 meeting 376001, all of which cross each other paths, and so on, seems to go OK, potentially several times an hour, every day.
Nick
table38
Stalybridge
Surely you could solve the problem by adding an md5 hash to all TOPS numbers, ie:
700018456555f62f58c0e43c8f45d52b3e4b3
700001c543e78865002ff0471267d0cf4dfac2
An obvious solution which I can't see any problems with at all :)
jopsuk
13 May 2008
struggling to imagine what possible situation there could be any confusion and what possible consequences it could have.
route:oxford
1 Nov 2008
Don't ever apply for a job where you need to manage a budget.
samuelmorris
18 Jul 2013
Brentwood, Essex
He's right, in the sense that someone's bound to get that wrong on numerous occasions. The vast majority of the time though, it will be abundantly obvious what is meant.
Yew
12 Mar 2011
Maybe there will be an occasion where 70001 is running thunderbird for 700001? Then it wont matter :D
AndyNLondon
20 Jan 2014
I'm sure there have been occasions when EMUs have been belching smoke & flames, although in that case the number should be the least of anyone's worries...
D7666
12 Aug 2013
Then you can have 70013:
or 70013
Also 60009:
or 60009!
(I know the kettles have different TOPS numbers ;))
Indeed, but, as I'm sure commented before, it is interesting how some kettle numbers coincide with kettles e.g.
SR Q1 and BR SR D6500 - 33001 etc
BR 9F and BR 92 - 92001 etc
Nick
zn1
3 Sep 2011
RSL will if the have any sense allocate unit numbers as a subclass 700 that they cannot be mixed up with locos, the old demu fleet Motor coaches were renumbered so that they couldnt be confused with class 60's
why they cannot reuse the 302-312's im not sure...it would certainly make more sense
