Sunbird24
i have pulled out of york on a 185 on a few occasions alongside a crosscountry 220, with first gear the two units were side by side, soon as second gear kicked in at 40mph the 185 gives it legs and leaves the voyager for dust. The voyager caught up eventually by colton junction but by that point the higher top end speed of the voyager was giving it the edge over the 185.
Been looking at the wheel diameters of the 185 and 220/1, they are very different, the latter being 780mm max against 1250mm max for the 185. So when the 185 changes gear the bigger wheels will give a lot more speed but it is limited by its lower top speed. There are so many factors to take into consideration, the number of horses may be equal but some have much longer legs than others and the weights can be very different also.
I also find it interesting that a class 68 with 7 coaches can accelerate as well as a 6 car 172 DMU unit despite being heavier and having a less powerful engine. This shows the superiority of an electric transmission system over the torque converter system which much be losing a lot of engine power in torque converter losses and none optimal engine operating conditions!
A class 68 has a 3,800 HP engine, of which 3,200 is available for the 4 x 800 HP traction motors (4 x 600 kW). (Rounded figures for HP).
A 6-car class 172 has 6 x 485 HP engines (6 x 362 kW), 2,910 HP total.
Where do you get the less powerful engine in a class 68 from?.
The class 172 does have much smaller wheels at 780mm diameter against the class 68 at 1,100mm diameter.
