Class 67's and Hull Trains?
Shaun1709
6 Nov 2006
Anyone else heard that Hull Trains will be running a 67 hauled coach stock to replace their badly damaged 222?
16CSVT2700
4 Sep 2005
Gdansk
Hmm I somehow doubt the 67s will be able to keep to 222 timings, that is if the rumour is true.
I shall ask my Hull Trains contact ;)
1VWC
3 Jan 2007
WB64 (or part of it) supposedly being prepared at Wembley as we speak...
ChrisCooper
7 Sep 2005
Loughborough
I doubt they will keep to timings at all. A 67 with 5 Mk3s and a DVT isn't going to accelerate very well at all, either from a stand (due to 67s having quite low tractive effort) or at speed. Also, I don't think the Mk3 DVTs are cleared for 125mph, I think they are restricted to 110. In particular on the ECML this might cause pathing problems. I also wonder what reliability and the overall standard of the stock will be like. If it's anything like the 'one' Mk3s or the MML HSTs in ex-Virgin condition they won't give a good impression at all. Then again, if they are planning on keeping them for a while, they might give them a refurbishment, or at least paint them up.
Shaun1709
6 Nov 2006
Hey there are plenty of reasons to visit Hull!! erm let me think...well maybe not plenty......maybe a few......I'll let you know..... and i'm allowed to say that...i live there
1VWC
3 Jan 2007
Take a look at the data panel and think again! Mark 3 loco hauled stock is 125 capable, it was the locos that held them back.
Guinness
13 Jun 2005
I thought they were 125mph but the problem was there no locos to pull them up to 125mph? Not including HSTs as they have special rakes of Mk3s because of the way they're wired.
WCML was limited to 110mph because the 87s/90s couldn't go any faster without gearing alterations. Besides there wasn't many places it could reach 125mph.
The only 125mph Locos are 91s and 67s. 91s obvious can't run to Hull and besides there aren't any spare. 67s are the other option as they're are plenty about and they work with DVTs.
True, they may not keep to timings a lot but it's surely better than a cancelled service? Finally, it would be one of the last Diesel LHCS in the country. So what's everyone's problem with them?
Max
8 Jun 2005
Cambridge
Where will they get the stock and the skip from?
I dont think this will happen to be honest.
I think the set in question was actually being prepared yesterday so I think it's looking pretty likely! They will need to look further to find a more long term replacement though in my opinion, as the public will see 67+mk3s as no comparison to the shiny new 222s. And it will be in completely the wrong livery!
ChrisCooper
7 Sep 2005
Loughborough
The Mk3 coaches are 125mph capable, it's the DVTs that I don't think are. I can't manage to see a DVT data pannel from where I am, but according to Locomotives and Coaching Stock 2005, they are 110mph maximum, and those books are usually right. AFAIK, since the locos and the line were 110mph limited, the DVTs were never certified for any higher speed, afterall, to do so would have required using a locomotive capable of 125mph. The coaches though being near identical to the HST trailers didn't need seperate certification, so have always been 125 capable. The DVTs though have a lot of changes, including a new type of bogie (also used on 158s and 442s), and quite a few structural changes, so would have needed their own certification.
Coxster
9 Jun 2005
According to the Platform 5 publication, the ex-Virgin DVTs (82101-82152) are 110mph max and GNER's (82200-82209) are 140mph max.
Guinness
13 Jun 2005
The GNER ones are 140s because they're the Mk4 DVTs and not Mk3. Mk4 DVTs are a different bogie, one called SIG IIRC.
16CSVT2700
4 Sep 2005
Gdansk
There is something up with this option.
Class 67s cannot work with the DVT's Time Division Multiplex system without modifications.
The only 67 that can work with a DVT is 67029, however IIRC it was the DVT that was modified for operation with the 67's AAR multiple working system and not the original TDM system.
So unless EWS are about to ching out for a bunch of modifications to it's 67s to work to TDM then I somehow think this will not get far.
Of course, if anyone knows otherwise please, feel free to correct me.
Guinness
13 Jun 2005
A 47/7 would do the trick as all of these are modified to work with TDM.
However given the recent reliability of TDMs and DVTs on XC90s (fails at least 3 times a week because of TDM Issues) we might see Top and Tail 67s purely for reliability along the ECML.
1VWC
3 Jan 2007
Mark 3b. Gangwayed on non-driving end. 125mph. T4 bogies. 45.18t. Cab-shore radio fitted.
82101-82152 BREL Derby 31042/88-90.
Design codes:
NZ5010A ETH 5X.
NZ5010B ETH 6X.
All that is needed for 125 running is a revised exam schedule (and 125mph passed locos).
Below taken from a drivers slip:
82131 4331 NZ5/H 0 VT 125 XC91 18.838 43.700 A Y
AlexS
7 Jun 2005
Just outside the Black Country
However to muddy the waters further, a 47/7s TDM is different to the one on the DVTs and as they've been modified, the DBSOs.
ChrisCooper
7 Sep 2005
Loughborough
There are 3 different systems of remote control that use the RCH (lighting control) cables on coaches. The original system was fitted to the 47/7s and DBSOs when running in Scotland. This isn't TDM, AFAIK it's an analogue system. TDM is fitted to the 37/6s, 86-92 electric locos, both types of DVT, and the DBSOs were fitted when they moved to Anglia. The other system isn't a proper remote control system, but it allows communication between a PCV (propelling control vehicle) and the loco, and was used on parcels and mail trains, with 47s, 67s and 86/4s fitted (the latter having TDM aswell). As far as modifying a DVT to work with AAR on a 67, if this could be done, it would need the coaches through wiring aswell. 67029 has probably had TDM fitted, it can't be that hard considering the fact that 86s and 87s were fitted. Then again they could always use 37/6s.
1VWC
3 Jan 2007
You seem to be confusing TDM with RCH.
RCH is essentially a lighting circuit through which the TDM (remote control) signals are sent. TDM fitted locos can use this system for multi working.
To confuse matters more, there are two levels of the 'second generation' of TDM...standard and enhanced. Mark 4 stock has separate communication channels for TDM signals making this system more reliable.
37/6 and 92 are not fitted with TDM. 37/6s (apart from the refurbed DRS jobbies) are fitted with RCH though.
You mention the EWS company train; The whole set has been through wired for AAR and 67029 is 'plugged in'. It was deemed easier to configure the DVT to work in multiple with the existing AAR system than to retrofit 67029 with TDM (which isn't that reliable anyway)!
Bearing in mind the last point, it may be that the set includes a DVT (all l/h passenger trains need a brake vehicle/guards accomodation) but the loco runs round at Hull (if possible). Seems uneconomical to be dragging a dead loco on the rear which would also impede timekeeping.
Edit: Just found the following showing all the jumpers on the company train (http://great-western.fotopic.net/p25533911.html)
