Class 60 Headlights - Is This True?
dan4291
9 Dec 2019
County Durham
I've been told an odd thing about the headlights on a class 60 and wondered if anyone knew if it was true. Apparently when a class 60 is stood, say at a red signal, the headlights automatically switch off. Is this true?
C96
31 Mar 2018
Intrigued by this I looked at a few videos.
Around 16:28 you can see it stopped with headlights remaining on whilst stopped.
Darandio
24 Feb 2007
Yet watch here from 1:53 and they extinguish. Happens in a few others where i've seen drivers changeover. Because the key is taken out maybe?
richa2002
8 Jun 2005
Yes. The headlight only illuminates when the reverser is in direction.
Towers
30 Aug 2021
Regarding keys, I would think it's highly likely that drivers just swap keys, the outgoing driver leaving his in the desk and then the new driver handing his over - saves a lot of faffing about setting up the cabs again!
ExRes
16 Dec 2012
Back in Sussex
Interestingly my experience was that drivers almost always took their key out so that the relieving driver had to put their PIN in the OTMR before being able to move the train
Towers
30 Aug 2021
Interesting! And a fair point, although I'd imagine any TOC/FOC would know who was actually driving at any given time these days, even if the OTMR hadn't been properly set up (which presumably would be disciplinary territory?).
D365
29 Jun 2012
Do you mean the direction switch?
On that basis, this order of actions would make more sense.
66701GBRF
3 Jun 2017
Locos can moves whether pin is in or not. While I don't sign 60's I am sure that is still the case with them.
Without a pin you would have to rely on rosters which can be out of date an hour after publishing. The pin is only there for management downloading purposes following an incident or assessment. It acts as a sort of bookends. Not really disciplinary territory unless you constantly fail to put it in after lots and lots of warnings from you manager.....or you put it in on the move which is a big no no.
ExRes
16 Dec 2012
Back in Sussex
You're right of course, I didn't word that very well, as far as I'm aware the point was that removing your key was recorded on the OTMR should a download be required
