The 59s are basically the same diesel engine power rating as a 66 but have higher low-speed tractive effort - they are proper heavy-haul locos (e.g. like the cl. 60s) whereas the 66s are more general-purpose freight locos.Back in EWS / DB days double headed 59s were quite common on the Jumbo trains, I guess Freightliner are either treating the 59s & 66s as one fleet or doing to 59/66 combo to release more 59s for single work as they are more powerful than a 66 I believe. Given the build quality & reliability I double 59s will be withdrawn for a while yet (perhaps the wires might reach Westbury by then!)
Oh OK, thanks Mollman, I wasn't in the area thenBack in EWS / DB days double headed 59s were quite common on the Jumbo trains
Why were the 66s ‘down-specced’, so to say?(The 59s also have higher capacity traction motors and alternator, plus their EMD 'super series' wheel-slip control is effective down to lower speeds - it's what makes them suitable for hauling 5000 tonne 'jumbo' stone trains slowly uphill...)
EWS already had the 60s for heavy stuff. The 66 needed to be a general purpose loco to replace all the BR stuff and haul everything from trip workings to fast freight. The accounting dept probably said it wasn't worth installing equipment that would only get used once a year.Why were the 66s ‘down-specced’, so to say?
But then that leaves the debate about the demise of the Class 60s, but that's for another thread.EWS already had the 60s for heavy stuff. The 66 needed to be a general purpose loco to replace all the BR stuff and haul everything from trip workings to fast freight. The accounting dept probably said it wasn't worth installing equipment that would only get used once a year.
Change in EWS senior management is the story I heard. There were several locomotive proposals that got canned over the years.But then that leaves the debate about the demise of the Class 60s, but that's for another thread.
Vastly diminished market share being the other factor.Change in EWS senior management is the story I heard. There were several locomotive proposals that got canned over the years.
From what was said in magazine articles at the time (based on interviews with senior EWS people), EWS wanted in particular a large fuel tank capacity (it's about 40% greater than a 59) and the radial-steering bogies. This meant saving weight elsewhere in the design, so lighter weight/lower capacity (but sufficient for the intended use) motors and alternator were chosen.EWS already had the 60s for heavy stuff. The 66 needed to be a general purpose loco to replace all the BR stuff and haul everything from trip workings to fast freight. The accounting dept probably said it wasn't worth installing equipment that would only get used once a year.
Thanks for the clarificationThe 59s are basically the same diesel engine power rating as a 66 but have higher low-speed tractive effort - they are proper heavy-haul locos (e.g. like the cl. 60s) whereas the 66s are more general-purpose freight locos.
I believe that the 59's main generator and traction motors were swapped for small (and lighter) versions. This gave the 66's a much larger fuel tank for the same weight. It also means that 66's can't endure a long, slow slog as well as the 59's, as the electrickery gets too hot too quickly.Why were the 66s ‘down-specced’, so to say?
