Class 56 on containers?
alex17595
15 Mar 2013
Burton on Trent
I was working last night between Stafford and crewe and I (think) I saw a 56 hauling containers southbound.
It was dark so I could only really see the headlight and one of the tankers that goes in a frame.
possiby between 0000-0230 on Wednesday night.
So my question is did this run? or am I seeing things?
Beveridges
8 Sep 2010
BLACKPOOL
I've looked on Real Time Trains, the only Class 56 working between Stafford and Crewe at around that time would have been the Chirk Colas Rail - Carlisle which will be empty log-carrying wagons. This ran via Stafford (23:59) and Crewe (00:28) last night. I cannot see any other workings that are usually 56-hauled at around that time at Stafford.
However, this is a northbound working which does not match your description which states a southbound working with Containers.
DCR & Colas are the only two FOC's with 56's currently. I don't think DCR / Colas Rail run any regular Container trains so it would have either been on hire or rescuing a failed train for a 56 to be seen on a container train.
alex17595
15 Mar 2013
Burton on Trent
Im not really sure what it was, I did see the log train going northbound.
I could have been something else, but it was not a 66/70/90 which were going passt all night.
Beveridges
8 Sep 2010
BLACKPOOL
Possibility of a 47 or 57 as there are booked DRS Intermodals between 00:00 - 02:30 in that area.
Beveridges
8 Sep 2010
BLACKPOOL
That section of the WCML is so busy for freight at night, shame its not like that in the day as well.
8A Rail
6 Dec 2012
Mars
Network Rail's 57306??? Poss to Ironbridge PS? Just a thought.
Boothby97
24 Apr 2011
Cleethorpes
But in that case why would it be hauling containers?
Photo shows containers. Another one (not mine), http://m.flickr.com/#/photos/d1021/12993276355/
Have also looked through some TOPS lists - none of the DRS 47/57s were out on Intermodal working, and there weren't any DC Rail/Colas 56s (other than the Chirk-Carlisle empty logs) out in that area.
DarloRich
Fenny Stratford
The NR 57 has been on hire to GBRF to cover for a 66. I assume that the missing 66 should have worked the Seaforth - Ironbridge train but was u/s or needed elsewhere. Therefore the 57 went onto the Ironbridge train and worked an out and back run. The 57 then went back south on a cartic train from Arpley to Tonbridge. I dont know how it got north.
The service with the containers seems to be some sort of containerised coal service to Ironbridge from Seaforth docks
Could be wrong as this is put together through supposition and no "official" sources
Beveridges
8 Sep 2010
BLACKPOOL
I've done a quick search on TRUST and cannot find any workings going to/from Ironbridge that ran through Stafford/Crewe anywhere near the times the OP is talking about...
(00:00-02:30 on Wednesday night)
Plus, this working will not have any of those "Tankers that go into a frame" that the OP mentioned he saw.
What he saw is still a mystery as far as I'm concerned.
alex17595
15 Mar 2013
Burton on Trent
I think I was tired and saw something else!
Just for clarifiation, the tankers were similar to this;
