Class 465/466 return to the Victoria - Ashford services
Jturner98
2 Jan 2021
Kent
Looks like today was the first day that a 465 operated a Ashford - Victoria service. Thought it would be a good idea to start a thread covering:
Diagrams
Allocations
Possible withdrawal of the 377s
Admin - please feel free to move this thread if it’s in the wrong category.
Class 466
5 Mar 2010
Atherton, UK
Diagrams:
Monday to Friday from 1st August
All formed 466 + 465/9 (6 car)
5Y06 04+29 Ashford Down Sidings to Swanley
2A06 0606 Swanley to Victoria
2N12 0655 Victoria to Ashford
2A22 0908 Ashford to Victoria
2N28 1055 Victoria to Ashford
5N28 12+27 Ashford to Ashford East Berthing Sidings
5W42 13+50 Ashford East Berthing Sidings to Tonbridge Jubilee Sidings (attaches to 4 car 465/9 to work PM CHX-TBW workings)
5R46 14+11 Tonbridge Jubilee Sidings to Ashford (detaches from 4 car 465/9 off of AM CHX-TBW workings)
2A46 1503 Ashford to Victoria
2N52 1655 Victoria to Ashford
2A62 1855 Ashford to Victoria
2N74 2055 Victoria to Ashford
5N74 22+31 Ashford to Ashford Down Sidings
Saturday from September :
5A10 05+32 Ashford Down Sidings to Ashford
2A10 0603 Ashford to Victoria
2N16 0755 Victoria to Ashford
2A26 1003 Ashford to Victoria
2N32 1155 Victoria to Ashford
2A42 1403 Ashford to Victoria
2N48 1555 Victoria to Ashford
2A58 1803 Ashford to Victoria
2N70 1955 Victoria to Ashford
2A74 2203 Ashford to Victoria
2N86 2355 Victoria to Ashford
5N86 01+30 Ashford to Ashford Down Sidings
BluePenguin
26 Sep 2016
Kent
How much slower are these services now? Are dwell times longer with the extra padding to accommodate the 75mph speed limit?
Class 466
5 Mar 2010
Atherton, UK
No adjustment needed. The SRTs for 375s & 465s are identical across pretty much all the Southeastern Network. Which is why the 2A xx03 AFK - VIC services that are fast Ashford to Bearsted often get in 1-2 minutes early as 375/377.
The MDE line has a top speed of 80mph (other than the 90mph limit between Chislehurst Jct and Swanley), with the line alternating between 70 and 80mph between Otford and Ashford, with lower speeds through Otford Jct, Maidstone-Bearsted and approaching Ashford. A 465/466 formation won't be under speed for much, nor by much, and the relatively frequent stops also prevent any service sustaining top speed for long. If anything a 465's better acceleration at lower speeds makes them perform better than 375/377s when making regular calls.
Benjaminmorgan
2 Mar 2019
When the class 377/5s go back to Southern will the current Charing Cross to Ashford via Tonbridge be extended to Ramsgate via Canterbury West?
When are the Saturday diagrams due to start? From earlier observations no 465+466 was out on the above ones despite being in September.
If it is aligned with the changes on Southern the diagram change should be next Saturday, rather than this.
Is this the only route that Southeastern currently has 6-car 465/466 services on? All the other routes tend to most commonly be 8 or 10 car, with the odd 12 car on the metro routes.
Edsmith
21 Dec 2021
Staplehurst
Are 8 car 465s not possible on the Maidstone East/Ashford line? I'm guessing it's because of 6 car platforms and no selective door opening?
Basically yes. Kemsing, Barming, Hollingbourne, Harrietsham and Charing are all 6-car maximum without SDO. In theory an 8-car 465 set could use the line if on the semi-fast calling pattern, so I'd have thought an 8-car could be allocated to any of the MDE-CHX diagrams in the December timetable change, but I don't know what will be allocated where from December on that line, only that 375/377s will probably still form a large majority of diagrams.
HamworthyGoods
15 Jan 2019
Isn’t everything non HS1 on South Eastern timed at 75mph regardless of stock capability as a performance measure? It certainly used to be.
8 Feb 2021
Manchester
Think the Hastings, all Bromley South fasts (Chatham + Maidstone but not stoppers via Denmark Hill) and the Ashford via Tonbridges are pathed as 100mph, and the Tunbridge Wells + Bromley South to Chatham slows via Denmark Hill are pathed as 90mph
Class 466
5 Mar 2010
Atherton, UK
This is the case in reality - Hence why 375s and 465s have the same SRTs across Kent - Which is why a 375/377 will get to Bearsted a couple of minutes early on a fast run from Ashford whereas a 465 will be much closer to time.
BluePenguin
26 Sep 2016
Kent
What is an SRT? Why don’t they (or didn’t they) make use of the extra speed of a 377 to decrease journey times?
Considering the relative closeness of stops there isn't much of a difference between 75mph and 90/100mph running for most of the SE Network, and in the case of Bearsted-Ashford, that non-stop run appears to be disappearing from December, except I presume for SEML diversions when engineering works shut the SEML anywhere between Sevenoaks and Ashford.
hexagon789
2 Sep 2016
SRT - Sectional Running Time. The time taken by a type or types of traction to traverse a section of track and used to calculate/create timetables from.
In the case of much of the South-Eastern Network, the lack of sustained 75mph+ running in most places means having homogenised SRTs is probably more sensible.
Given 377s accelerate more slowly and creep up quite sluggishly at higher speeds because of the third-rail current draw limitations, I doubt you'd see much in the way of savings, certainly not on stopping workings.
43074
10 Oct 2012
Indeed, to the point there were even a few Class 455 SRTs on Southern which were quicker than the equivalent Electrostar timings.
4BEP
21 Jan 2022
Loose
Diagrams:
Diagrams:
I am wondering if this will continue after December timetable when VIC- AFK reduce to hourly and RAM services end on the Mid Kent Line. Today we see most services running 8 cars but 2N52 a peak service running 465/9 466 so no real logic. I also see that 2A56 is a 7 car, presumably 375/* and 375/3.
Class 466
5 Mar 2010
Atherton, UK
There’s a weekday diagram (peaks only) from December that runs at slightly different times. No weekend work.
Presumably the number of Networker diagrams could increase when the partial 377/5s cascade happens, but as this hasn't been arranged yet it won't be in place for December.
