Class 465/466 Ramsgate summer special
nw1
9 Aug 2013
Last summer I went to Dover for a day trip and made a point of going from London Bridge. Never done a long distance run down the SER route before and found it not that much longer than HS1 (especially when starting in South London) and a much more interesting view from the window.
Did most of that route long before HS1 or even Eurostar was a thing, on the Network Day in September 1986. Only as far as Ashford as was heading for Canterbury. Got the Ashford local, changing there, as was anticipating the faster direct train to Canterbury to be overcrowded - which it was. Did mean I didn't experience an express run from Paddock Wood to Ashford though - that came a few years later when I repeated the journey to Canterbury for other purposes, and again on Eurostar heading ultimately for Montpellier. :)
Did a circular route, returning from Canterbury East and thus doing much of the Chatham as well, though a fine morning had turned wet so didn't see so much on the return journey.
Yes, nice route: the fact that the railway cuts through not one but two escarpments (the North Downs and the greensand hills of Sevenoaks) is particularly interesting.
No, unlike most of the historic examples. Comes empty from Gillingham.
Ah ok - thanks. Wonder if this is the most efficient way of doing it? Seems to me that considerably less mileage would be involved if they extended a regular pattern service and then formed its 'normal' return service from Dartford, or wherever, from stock out of Slade Green or ECS from a London terminal.
Also if it's come from Gillingham for an 0925 departure out of Cannon Street, presumably the stock is not involved in the morning peak; can the railway really afford to leave units unused during the peak periods when they are most needed?
On a weekday only 1 special usually runs out to Ramsgate, then it returns empty to Slade Green straight after, presumably to be used in peak services later. Only on weekends and the August Bank Holiday do multiple specials run and in both directions.
