Class 455
adamp
5 Oct 2007
Manchester
Installed it of Coxsters site, and the sounds are all there...but no sounds actually play when on bve, so im driving a train with no sound atall...everything else works though, Does anyone know how to get these sounds to work??
Juniper Driver
17 Jul 2007
SWR Metals
Great I can practice on my day off.<D
I've already got 555/8.Did you get the sounds and put them in them or install them into the sounds folder?
Are your speakers ok?
adamp
5 Oct 2007
Manchester
I just installed the train, with everything already in. But the sounds are all in different folders like Sounds *other foler* Engine then the Actual engine sounds.
I tried putting all the sounds just in the cl 455 main folder...and it still doesnt work.
By the way, Yes, My speakers do work ;)
velaro
25 Jun 2007
Reutlingen, Germany
You don't have to move any files around - in fact, you'll cause problems if you do. The train is configured in such a way that the run sounds are expected in .../sounds/run, the engine sounds in /sounds/motor and so forth. If you like, take a look at sound.cfg and you'll see what I mean.
The train works fine for me as is, so I'm not sure what the problem is. Do you have trouble with any other trains?
