Class 455 with AC Motors
RAIB bulletin on the problem in the equipment cubicle on the Guildford unit, they have apparently worked out what was the cause:
The traction equipment involved was of the new design and the mechanism which caused the explosion was believed to be understood by the industry parties involved. Similar, smaller explosions, have occurred on at least two previous occasions where debris scatter was much more confined. The previous occurrences had been attributed to a manufacturing defect, leading to a build-up of explosive gas within the traction equipment. Industry parties were in the process of devising possible solutions to the problem at the time of the 7 July accident and are continuing to do so.
https://www.gov.uk/government/news/explosion-inside-an-equipment-case-guildford
Bromley boy
18 Jun 2015
I just spotted the below article on The Times website. I believe it's referring to upgraded 455s and sounds pretty serious if true.
Does anyone have any inside knowledge?
https://www.thetimes.co.uk/edition/...west-trains-services-after-upgrades-s7c28hctv
An investigation has been launched into explosions on newly refurbished commuter trains, including one blast that fired debris several metres into a railway station car park.
Rail accident investors revealed yesterday that explosions had been reported on three services operated by South West Trains, Britain’s busiest railway network. They were caused by a build-up of gas caused by a manufacturing defect.
All incidents are believed to be linked to a programme of upgrading the traction systems on electric trains used on the network, which covers a wide area of London, Hampshire, Surrey and Berkshire
AndrewE
9 Nov 2015
I am intrigued, & it's a pity they are so evasive about "a build-up of explosive gas within the traction equipment."
If it's DC stock we are not talking about gases from transformer oil or windings/insulation, so is it something boiling off circuit breakers, lacquered coils or other hot components?
Peter Mugridge
8 Apr 2010
Epsom
455 901 is one of those that have been re-tractioned with inverters and AC traction motors.
Keith Jarrett
10 Aug 2010
No longer in London
As afar as I know, the following have been done
5701-5742, 5750
5850, 5853-5859, 5861-5862, 5866-5870
5901-5912, 5914-5920
Any additions, amendments etc welcome
Class455
19 May 2016
5701-5742, 5750
5847-5849, 5860 and 5864 will be amongst the last to be done.
rebmcr
15 Nov 2011
St Neots
Has there been any pause in conversion pending the investigations into the traction explosions?
TEW
16 May 2008
No, if you read the RAIB bulletin on the issue it states that the cause of the explosion is known and has been remedied.
rebmcr
15 Nov 2011
St Neots
Err... nope.
RAIB said:
The traction equipment involved was of the new design and the mechanism which caused the explosion was believed to be understood by the industry parties involved. [...] Industry parties were in the process of devising possible solutions to the problem at the time of the 7 July accident and are continuing to do so.
TEW
16 May 2008
It was elsewhere I read that then. It was put down to some faulty parts that were only fitted to a few units. The affected units were withdrawn from service pending repairs, but it has not slowed to progress of conversions.
Class455
19 May 2016
455 847 is now retractioned, seen at Clapham Junction this evening. Had 455 913 this evening though and it still had EE507's. Since this is the last unit to be done, I would assume the programme completion is now early September?
860 was not done last I saw it on Friday. As 873 and 864 were done behind it i assume that there are at least 4 units still to be done and 913's going to take a little longer since the carriage was originally a Class 210.
HarleyDavidson
23 Aug 2014
Then they can start taking them all back in to have the software redone to eliminate the jolt you get when you stop, because it doesn't blend or do the changeover from dynamic braking properly. <(
Maybe if we're really lucky they may even install some traction control software on too so that they can deal with damp rails or low adhesion properly too.
Tried going up the Cobham line the other day in light drizzle, I nearly required the services of a chiropractor to sort my back out there was so much banging around. :roll:
Driver@swt
31 Aug 2014
I blame the driver!!
TEW
16 May 2008
455901 is back. Not sure how long it has been back in service but I worked it today.
Bigfoot
2 Dec 2013
I noticed today that some of the 455s have got ratchet straps wrapped around the new traction packs. I'm guessing this is to stop a reoccurrence of the Guildford incident whilst the faulty batch of capacitors is replaced.
Feathers44
12 Aug 2014
Saw a lot of those at Clapham yesterday - every unit I saw had them - I was idly wondering what they were for but I didn't make the connection.
Bigfoot
2 Dec 2013
From what I noticed it was only the early conversions the 57xx's. The 59xx I saw didn't have them. But then there are more 57xx's than the 8s or 9s.
Class455
19 May 2016
455 860 now retractioned. That leaves 873, 864 and 913 to be done.
Class455
19 May 2016
The 455 retractioning project is now complete! Saw 455 913 at Kingston today and it now has Vossloh traction motors. Wonder if the rest will now have to return for mods to stop them exploding.
TEW
16 May 2008
It's not complete. 5864 will be the last unit done, AFAIK it is still in traffic at the moment with DC motors.
