MatthewRead
Just read the latest issue of RAIL the class 455's are now to be fitted with diesel engines where could they go?
Sounds like a class 210 to me
Just read the latest issue of RAIL the class 455's are now to be fitted with diesel engines where could they go?![]()
So could the announcement that First/MTR are replacing the 455s turn out not to be as bad and wasteful as first thought?
I don't think any replacement of 455s is wasteful, they're 30 years old. If we can reuse them, all the better.
What is wasteful is replacing the traction equipment with brand new and then ditching them. Only in the DfT's dysfunctional world is that even remotely sensible.
It's a sunk cost. Youmake a decision that is correct at the time ....but two or three years later it turns out that something has changed and it may be the case that the correct thing to do then is to write off the earlier spend. the "mistake" (if there was one) was the original decision to retraction the units - but you can't recoup the money already spent.
So you make use of them, say, by swapping them with other TOCs continuing to use 455s but with original traction equipment.
Porterbrook said they were looking into a feasibility study about a 455 Flex if the project for a 319 Flex is deemed suitable.
No point sinking money into an entire fleet if the base project is deemed not suitable.
It's a sunk cost.
However, as Ian Walmsley points out in his latest column, after recent events it will be impossible to get a ROSCO to fund any sort of upgrade unless you give them a long lease contract.
455/7s might be a good choice - ditch the ex-Class 508 trailers and you have a three car DEMU. Who might fancy 43 3-car DEMUs?
Is the proposal to turn them into pure diesel units, for use on non electrified routes, or is the plan to retain the DC traction equipment in addition to diesel power for use on routes that are largely DC but not electrified throughout.
Whilst the class 455 vehicles may be mk3 based, they are only 20m long, compared to 23m on a mk3 carriage. Does that satisfy the requirements for the tunnel?they would be good on Reading to Gatwicks or Ashford to Hastings..... a 3rd rail/Diesel Flex.
WOuld need a toilet fitted and maybe some first class !!!!!
Uckfields would be a problem with good old Oxted tunnel being an obstacle for mk3s.
I'd rather a 455 than a 166, at least you don't bake alive or get poisoned by diesel fumes.
