Class 43 disposals
Domh245
6 Apr 2013
nowhere
Interesting that the buffered locos had just languished in that pool rather than being moved to a storage one. Doesn't give as much away either
23 Nov 2015
What pool had they been sat in between finishing at EMR and the move to SXCL? Have they just been moved from one stored loco pool to another?
43208/296 had been in SCEL (Angel Train stored locos at Ely), the 6 434xx hadn't been transferred out of the EMPC pool.
Shuttle
4 Mar 2020
Stoke
Will be interesting to see what becomes of these. As I alluded to on the HST Coach disposals thread, there can't be much MK3 Coaching stock left for power cars like this to work any more. Sadly I feel it's only a matter of time until big numbers of 43s hit the scrap. Do love the HST, but it is what it is.
DustyBin
20 Sep 2020
First Class
Have these ones at Eastleigh been scrapped then? Do Eastleigh scrap or will they go from there to somewhere like Sims?
As I don’t think anybody has answered the second part of your question, scrapping takes place on-site at Eastleigh by Raxstar. They’re scrapping the 317s currently.
Jamesrob637
12 Aug 2016
Sadly, I think large numbers of 43s will be history by the time we ring in the New Year 2022.
ExRes
16 Dec 2012
Back in Sussex
SCXL may not be a brand new fresh out of the box pool code but it is now 'Angel Trains/Hanson & Hall Power Cars' and contains no other power cars whatsoever
SCXL now appears to have been renamed 'Angel Trains Hire Locomotives' and has had the damaged 43140 added to it
43096
23 Nov 2015
It hasn’t been renamed. It has always been the Angel Trains stored locomotives pool.
43 302
25 Oct 2019
What makes more sense, that 43140 has been miraculously fixed and is being hired, or that WNXX is wrong and 43140 is off lease. Side note: perhaps the fact that 43030 hasn't also been added shows the potential for it to be repaired?
DB
Guest
18 Nov 2009
There may well be no usable parts to recover from 43140 given the scale of the damage (particularly fire damage).
WNXX also notes that:
43056 43069 43078 43087 43193 & 43197, all currently in store at Long Marston, have been reallocated from the SBXL store pool back to the GWR EFPC pool.
What's that about then?
43 302
25 Oct 2019
More castle sets? Or just wrong?
Edit: it's not wrong.
irish_rail
30 Oct 2013
Plymouth
Hmm, the bit about the 6 power cars being reallocated to the GWR pool is particularly interesting, as I have heard from a fairly good source recently that precisely 6 power cars where to be converted shortly for use on the night riviera to replace the 57s. I discounted it at the time but this makes me wonder......
DB
Guest
18 Nov 2009
43056 would be an odd choice - it and 43053 were always non-standard in the GWR fleet (new control electronics, which none of the others had although all other fleets did eventually - excluding Scotrail which are of course all ex-GWR).
43096
23 Nov 2015
It’s actually 7. 43196 is also back in the GWR pool.
irish_rail
30 Oct 2013
Plymouth
Crewing the 57 is becoming harder and harder as more and more drivers require training and its a 3 week course , whereas the vast majority of drivers in the southwest already sign HSTs so would probably pay for itself in the long term , not to mention increased reliability.
Personally itd be a shame as I like driving the 57 but I think power cars are inevitable on the sleeper now sooner or later.
St. Paddy
11 Sep 2019
Hitchin
There would have to be generator coaches for the sleeper services, incompatible electric supply on the HSTs.
43096
23 Nov 2015
There wouldn’t. Design work was done some time ago on a mod for power cars or stock to convert train supply. There was a proposal to use Mark 4 stock between power cars and the design was done for that.
DB
Guest
18 Nov 2009
Surely as it's Mk3s here the most logical would be to convert the stock to 3-phase supply (or dual supply if they want to retain the ability to work with locos)? Otherwise they would be converting 3-phase to standard ETS and back to 3-phase again.
Would also allow all power cars to be used rather than a dedicated pool.
43096
23 Nov 2015
You need to take the entire rake out of service to do it, though. I’d actually put the kit on the stock (BFO/BSO logically) so you could use any power car. Yes, they’ll still need to put 36-way cables through, but that can be done one vehicle at a time.
DB
Guest
18 Nov 2009
Couldn't they do one at a time if they dual-wired them? Royal train seems to be done that way.
43096
23 Nov 2015
They could. But easier to put one box in one coach to convert than to re-wire the entire fleet.
