Class 390 Pendolino PTSRMB
Class 323221
14 Jun 2024
England
Hello everyone,
A short question:
I was looking into the formation of the Class 390. I am a bit confused by the PTSRMB. I am under the impression that it stands for 'Pantograph Trailer Standard Resteraunt Motor Buffet' or 'Pantograph Standard Buffet'. This seems a bit weird as I thought there weren't motors in the pantograph car and the 'T' and 'M' also suggest that I am wrong as one is 'trailer' and the other 'motor'. Would anyone be able to help me to understanding this car?
Thank you everyone and have a good evening.
D1537
11 Jul 2019
North Yorkshire
I believe that PTSRMB stands for Pantograph Trailer Standard Restaurant Miniature Buffet, like the RMB in hauled coaches.
Class 323221
14 Jun 2024
England
Thank you. That would make more sense then. I didn't think that Pantograph cars have motors. At least not usually.
norbitonflyer
24 Mar 2020
SW London
Aventras (classes 345/710/720/730) do, and so do/did BR-era units (classes 302-305,308-312, 316-325, 365, 506)
Efini92
14 Dec 2016
Hello everyone,
A short question:
You are correct that the pantograph car doesn’t have traction motors.
Class 323221
14 Jun 2024
England
I assume this is in regards to 390s and not in general for all trains?
I meant as in a general for all trains, however it appears that I have been corrected on that. I thought it was a general thing that Pantograph cars did not feature a motor but apparently my local line has stock that do.
Do you know if there is any reason for the Aventras to have motors in all cars? Especially for a three car Multiple Unit, I don't see why it is needed.
Ah. That makes more sense then. Thank you.
323 and 365 don't/didn't.
Yes, I remember that the 323s didn't, you could just hear a hum from the PTSO if you were on the outside.
NSEWonderer
5 Dec 2020
Was Going to say, our 701s definitely have motorised pantograph cars, so had to be sure I wasn't going mad.
As for why they have motorised pantograph cars, why not? Older trains didn't have it, most likely due to how restrictive the technology was back then and the complex amount of work needed to fit all that equipment into one car, where as technology has become a lot better, equipment smaller and more efficient.
D365
29 Jun 2012
There are no three car Aventras in production. But, considering the Class 345 for example, each vehicle has one motored bogie and one trailer bogie.
DaveyJones
12 Mar 2023
730/0 begs to differ :) I have no idea on how they're motored though
D365
29 Jun 2012
The replacement of Class 323s somehow slipped my mind.
This post suggests that Class 730 has the same 2’Bo (trailer + motored) bogie arrangement on each coach. Although there doesn’t seem to be a consensus on whether the motored bogie is at the No.1 (cab) or No.2 (gangway) end.
hexagon789
2 Sep 2016
345s are actually quite complex in their traction arrangements having both half-motored cars (2'Bo), fully motored cars (Bo'Bo) as well as one trailer car (2'2) in the centre - with 20 traction motors in all across a set.
The arrangement you describe does apply to the 730s though, where each vehicle is motored on one bogie.
Each vehicle has one motored and one un-motored bogie - a 2'Bo arrangement.
730s have the un-motored bogie under the cab.
MCR247
7 Nov 2008
I believe earlier Electostar like 375s and 377s also have an unmotored bogie under the cab
D365
29 Jun 2012
Thanks for clarifying. This makes the most sense as it provides symmetry if Class 345 units are ever shortened back to 7 cars, or lengthened to 11 cars.
Additionally, I understand that the leading bogie at each cab is unbraked, to allow for precise measurement of distance travelled.
I suspected that this would be the case in order to mirror the Class 345 approach.
The Glasgow Blue Trains, Class AM3 and later 303, dating from 1960, did! The motorised pantograph car was the centre vehicle.
Same with Class 318/320.
hexagon789
2 Sep 2016
Exactly, because then the performance is unaffected by lengthening.
I believe it's just the outermost axles at each end, but is for exactly the reason you give.
