Class 387
jon0844
1 Feb 2009
Maybe you've given the 'final' answer - the fact many 365s are not at full power.
spark001uk
20 Aug 2010
...I always thought the 365s accelerated well, but he 387s are something else...
You're not wrong there, on the GWR ones I usually have to hold my drink upon leaving most stops, or it'd be in my lap!!
...The 110mph capability of the 387s could prove beneficial if ever able to be utilised...
Are they limited to 100 on GN currently then? Is that track limitation or signalling?
spark001uk
20 Aug 2010
I believe it's down to the OHLE and/or pantograph design. I may be a little out of date on this, but certainly the 387 I went on today didn't exceed 100.
Hmm. I've certainly been at 110 on a GWR 387 a few times.
Agent_Squash
22 Jul 2016
Didn't they replace the pantograph when they were used on TL, to the same on as used on the rest of the dual voltage fleets?
It doesn't have to be the ECML, it may well be something like the Kings Lynn section. If the pantograph has to be replaced with a different design to cope with issues there, this may prevent 110mph everywhere. Others will no doubt be able to elaborate further, but I believe this is, or certainly was, the issue.
In reality, 110mph will probably not be of too much immediate benefit on GN. The current timetable is based on 100mph. The higher speed doesn't start until some way out of King's Cross, and the chances of catching up with something else is quite high. Adjusting the timings may well require more extensive timetable changes, plus it would then introduce an issue should 365s stand in, which is still quite possible particularly on services to Peterborough Cambridge and Ely although less likely beyond due to the dividing/joining at Cambridge.
I'm sure 110mph will come eventually, but I can't see a pressing need for it especially with the current timetable.
GW is a different route with different infrastructure and different issues.
Don't forget GN was originally going to get the 100mph 377/5s, so evidently 110 wasn't seen as essential.
Adsy125
22 Dec 2016
How busy is the 0935 Maidenhead-Paddington service normally, thinking of doing it next week. Thanks
aleggatta
28 Sep 2015
The pans on the 387's have never changed from build, there were rumours that they were going to be, but this never happened
43096
23 Nov 2015
Any deliveries since 387.156?
Reported elsewhere that 387156 went to Old Dalby from Bletchley and 387160 went there direct from Derby. 387157-159 have now gone to Bletchley (157/158 have started the standard test procedure) and 387161 due out shortly (possibly today).
wls1
6 Jan 2017
North Essex
More GWR 387 diagrams commenced this morning (I think),
0803 MAI-PAD 0827
0836 PAD-MAI 0919
1711 PAD-MAI 1752
That now means the only direct Henley trains are the 0708 and 1905 return, all peak and high peak directs have now been cut.
Several other minor changes as well but none more that I can find are 387.
Melancholia
21 May 2016
Argleton
1507 Oxford to London Paddington stopping service now terminates at Maidenhead (1617) for a connecting EMU 1620 Maidenhead to London Paddington
Siemens Staines
30 Jul 2015
I think that
2D09 0612 Paddington - Maidenhead
2D77 1942 Paddington - Maidenhead
are also 8-car 387 as of today.
This afternoon one of the Hayes turns is shown as 4 vice 8 on GWR journey check.
JN114
28 Jun 2005
I think that
The 4 vice 8 this afternoon is due to a train fault, no spare available to strengthen back to 8 car. At present all M-F 387 workings are booked as 8 car with no plans to change that.
GodAtum
11 Dec 2009
Was 1st class popular on the previous Turbo routes? I can imagine people coming from Marlow - Paddington have a lot of 1st class commuters?
wls1
6 Jan 2017
North Essex
First class would've been removed on those routes when it was removed from 165s so not much change. Only really have an effect on the peak oxford and didcot semi fasts.
reddragon
24 Mar 2016
Churn (closed)
There are now trains from Newbury, Bedwyn, Oxford & Reading terminating at Maidenhead during the peaks.
There are 13 AM and 5 PM UP + 7 AM and 14 PM down electrics to/from Maidenhead, more just to Slough.
I read from those in the know that no 387s west of Maidenhead are planned until January 2018, however, pressure from the top may well see 387s on Reading or Didcot peak trains much earlier than that, but we shall see!
samuelmorris
18 Jul 2013
Brentwood, Essex
First time using Gatwick Express yesterday, it was for the most part pretty pleasant, had the whole carriage almost to myself, being able to use oyster on it from as far afield as the airport was very convenient given the enormous ticket machine queue, though £20 single seems a bit steep given they hold the GX services to wait for stopping Southerns to pass in front. Makes a bit of a mockery of 'express' really!
I also noticed one particularly rough bit of track that nearly launched me from my seat and was sufficiently violent to trigger the inter-carriage doors to open. I don't remember exactly where that was, though. I know people have commented on the ride quality of 387s but I'm curious if that occurs on any of the other stock serving the route, it's certainly not something I remember experiencing on a 700.
Thatcham Xing
1 Nov 2016
I took the 1609 Paddington-Maidenhead (as far as Slough) yesterday, which was my first ride in a 387.
A pleasant experience overall. Seat felt a bit hard to start with, but soon got used to it. Swift acceleration and quiet, smooth ride at down relief linespeed.
spark001uk
20 Aug 2010
387157+158 delivered to West Ealing today (originally booked as Reading TCD), 37800 in charge but failed shortly after leaving Bletchley, train rescued and brought to Ealing by 47813.
physics34
1 Dec 2013
the sideways movement/jolts are bad on all of the electrostar family and worse above a motor bogie. Not great for the poor track conditions on the SR
superalbs
Verified Rep - Superalbs Travels
3 Jul 2014
Kraków
I caught a GN 387 from KGX to ELY, it was insanely rough and you could feel every bump thanks to the awful Fainsa seats, but the acceleration was very impressive.
JN114
28 Jun 2005
Not quite - the delivery is for Reading, the train was recessed in West Ealing for a replacement loco (57310) to be sourced as the batteries on the 37 were still required to run the braking system on the 387s, and couldn't be relied upon any longer with the engine not running.
5Q74 has now departed West Ealing 338L
choochoochoo
6 Aug 2013
is anything being done to stop that dreadful noise if you're in the carriage with the pan on it as you go through neutral sections ?
I think they should issue ear defenders if you sit underneath it :)
D365
29 Jun 2012
There's really not much that can be done when it comes to circuit breakers.
