Class 387 related disruption, inc. Heathrow Express suspension
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
Due to a significant incident outside of our control, there are currently no Heathrow Express services running. We are actively working to resolve the issue as quickly as possible. Current service information and advice can be found here: Live Service Updates | Heathrow Express
Rumour has it that there’s an issue with the couplings on their fleet of 387s that is preventing multiple working. Is there any truth to this?
This would be the second saga Heathrow Express have encountered where all their trains have been withdrawn from service.
Robski
15 May 2016
Great Northern has cancelled a number of 387 operated services due to "a shortage of trains because of extra safety inspections"
Jamiescott1
22 Feb 2019
The announcements at Paddington say "Heathrow express services cancelled due to an issue with the fleet"
Liz line still running as usual to Heathrow
All the gwr Didcot stoppers are scheduled as 4 car today (usually a mix of 4,8 or 12 car). These are operated with 387
Wilts Wanderer
21 Nov 2016
Must be more to it than just couplings, as it would be perfectly feasible to maintain a service using single-sets. Unless it’s so urgent that sets that already coupled are essentially immobilised wherever they are?
Halish Railway
26 Apr 2017
It seems like this issue has also impacted GWR and GN’s Class 387s.
The suggestion I’ve seen is that Heathrow Express are currently undertaking the process of uncoupling all of their trains to run as single units.
Trainguy34
29 Apr 2023
Kent
Ouch, that might to mess up Southern/Gatwick Express. Hope it doesn't get 375s out of service as that's the whole south east gone effectively.
Tetchytyke
12 Sep 2013
Isle of Man
Well that was sudden. I’m at Heathrow now and the trains were running as 8-car at 2pm when I transferred through.
Wonder what’s happened to cause that reaction? Train split somewhere?
Horizon22
Jobs & Careers
8 Sep 2019
Sometimes (I mean it is daily, but often it is minor) urgent safety advice is sent around to all operators and it depends when that email/bulletin was sent I suppose.
Did HEX ever get authorisation to run as 4 cars?
GWR/HEX were working towards, not sure if it was approved in the end.
DanNCL
17 Jul 2017
County Durham
What I don’t understand is why it’s only the 387s impacted. Lots of fleets have identical couplings.
Only authorised as 8 car sets to Heathrow.
MrJeeves
28 Aug 2015
Burgess Hill
My hypothesis would be, if it is coupler related, that it could well be some electronics issue rather than a physical defect with the coupler. Either that, or only one variant/batch/MOD strike of the Dellner couplers are affected.
Halish Railway
26 Apr 2017
Or it’s an issue with the gangways, which I would imagine are a more 387-specific issue.
MrJeeves
28 Aug 2015
Burgess Hill
In which case, couldn't the units simply run with the gangways locked shut, similar to how they would run when the cab is in use? At least for HEX, where there's no short platforms or anything.
DanNCL
17 Jul 2017
County Durham
Buggy software update maybe
Software is a possibility. Aren’t the couplers themselves the same variant as on the other electrostars though?
2 Jun 2023
Richmond
Yes but that doesn't mean they'll receive the same software update at the same time. Remember that some electrostars have even completely different operating systems.
VP185
13 Feb 2010
They’ve discovered incorrect parts have been fitted to couplers on sets being returned from overhaul.
Hex to resume shortly.
800301
29 Dec 2022
Essex
It’s coupler related, apparently wrong part fitted while under overhaul, affected sets being identified and sets that haven’t been overhauled, to be coupled at depot and back into service
Nothing to do with software, as they are currently running at least 2 different versions anyway
arb
31 Oct 2010
My usual 8-car 387 Great Northern from Ely to Cambridge yesterday morning was only 4 cars. Only a single data point, might be a coincidence, might not. I've only used Greater Anglia since then so can't add anything else to the thread!
roadrunner147
24 Jun 2016
This likely explains why my evening Kings Cross to Cambridge stopper service was only 4 cars yesterday, which I've not experienced for many years! This morning an 8 car 387 turned up though
Horizon22
Jobs & Careers
8 Sep 2019
Heathrow Express was back to normal by 1830.
Bikeman78
26 Apr 2018
That is an odd scenario. Are there any other units in the country that must run in pairs? I can't think of any.
DanNCL
17 Jul 2017
County Durham
Tyne & Wear Metro units have the same restriction simply as they’re so unreliable that the chances of a single unit failing and blocking the line for an extended period are too high, other than that though I can’t think of any either.
800301
29 Dec 2022
Essex
It’s only in service they aren’t permitted, the units can run as 4 or 12’s ECS, they just haven’t been certified to run as a 4 car in service yet, despite them recently running tests and installing 4 car stop markers
Horizon22
Jobs & Careers
8 Sep 2019
GWR are still checking their whole 387 fleet which may cause some short-formations on Monday if it can’t all be inspected (unlikely).
Purple Train
16 Jul 2022
Exile or exile
Can units that have been overhauled work in multiple with each other, or can they not yet work in multiple at all? This afternoon I was on 387150+387151 (14.08 London Paddington-Didcot Parkway), and I'm sure I saw 387150 when it was being hauled back (by 37800, if I remember correctly) to Reading. I'm not sure if 387151 has been overhauled, hence the question!
JN114
28 Jun 2005
As long as the coupling/uncoupling occurs under engineering supervision; with some additional checks - it doesn’t matter what combination of overhauled/not overhauled units are coupled. I believe 150+151 have both been to Ilford recently; but that they’re a pair today is just a coincidence.
To de-risk operations today; alterations have been made by control to some formations to eliminate any and all coupling/uncoupling away from depot. In short, almost everything is running as a fixed 8 car; except the two 4 cars on the Newburys.
