Class 377/7
TEW
16 May 2008
I imagine it will be very similar to when they were running on the Brightons when they were first introduced, although that was only one set. It was on the Brighton Express trains though. Most the Brighton diagrams are 8-car 377s on Saturdays at the moment, apart from one 9-car set, so the extra capacity for the Summer will be appreciated I imagine.
Class377/5
19 Jun 2010
It was always a pair not a single set. I know as I did them regularly, but they were mainly on the expresses tho did wok stoppers as well as they were added ad hoc.
The current Brighton diagrams are a mix of 8 car 377s and 10 car 442.
Thanks for clarification Class 377/5.
I would imagine then that the two 10-car 377/6 SO will be on Brighton Express services then....
I'm not sure if they are SO if honest as I never bothered to look at Sunday workings.
TEW
16 May 2008
Sorry I wasn't clear, I meant a single diagram which was a pair rather than a single set. There's still one 9-car diagram on Saturdays, 3 /3s which is strengthened with another 3-car for, I think, one trip in each direction. 10:06 Victoria-Brighton rings a bell. Prior to December there were 3 9-car sets on the Brightons on Saturdays.
Class377/5
19 Jun 2010
Ah I get you know. The new timetable should see a mix of 8, 9, 10 & 12 (formed from 377/3 only) 377 Brighton - Victoria service with one early 'stopper' being a 10 car.
Peter Sarf
Croydon
Am I right in assuming that the 10 car Brightons are generally pairs of 442s ?. Thats rather than a 377/3+377/3+377/1 or 377/3+377/3+377/4 combination but possibly 377/6+377/6 or 377/7+377/7. In which case its worth remembering that a 10 car pair of class 442s is roughly the same length (and capacity ?) as a twelve car Electrostar combination because the class 442 coaches are longer.
While I was typing the above the following occured to me. I assume that 377/6 and 377/7 should work together ?. Or is there something to make that difficult ?.
Class377/5
19 Jun 2010
All the workings (unless I missed something) are 377, no 442s. 10 cars are two five car 377s, 12s are only 4x 377/3s.
377/6 & /7 will work together as they are effectively the same units bar the pans.
TEW
16 May 2008
I don't think there's been many, or even any 442s on Saturdays on the Brighton's since December. Best time to get 442s now is weekday evenings.
Class377/5
19 Jun 2010
I've been on a few, normally mornings tho.
G_A_C_C_C
11 Dec 2008
High Wycombe
Why are the 377/7 deliveries so far behind? I know Derby stopped for a while to concentrate on finishing off the 6s....but that was months ago. There was a picture of 707 for the "1000th coach built for Southern" press release...but why has it not come south yet? I thought they were supposed to be in use by this weekend. What is the hold up?
southern442
20 May 2013
Where have the 442 diagrams gone?
TEW
16 May 2008
Pretty much since the 442s were first introduced on Brighton runs they've had slightly less workings each timetable change.
JB25
12 Jan 2013
Have any come down?
I certainly haven't seen any around Selhurst yet.
MK Tom
31 Aug 2011
Milton Keynes
Regarding the introduction of 377/7s onto MKC-South Croydon and the fact the timetable hasn't really changed, have they figured out a solution yet to the clash that happens between Croydon and Euston services at MKC platform 2 around 18:00? To my knowledge you can't get 5/8 car units into platform 2A and the LM train is 12-car.
Class377/5
19 Jun 2010
377/6 Brighton runs for today
377616/602
2A12 05:02 Victoria to Brighton
1A61 07:19 Brighton to Victoria
1A64 08:36 Victoria to Brighton
1A81 09:49 Brighton to Victoria
1A84 11:06 Victoria to Brighton
1A01 12:19 Brighton to Victoria
1A04 13:36 Victoria to Brighton
1A21 14:49 Brighton to Victoria
1A24 16:06 Victoria to Brighton
1A41 17:19 Brighton to Victoria
1A48 18:36 Victoria to Brighton
1A59 19:49 Brighton to Victoria
1A68 21:06 Victoria to Brighton
2A61 23:05 Brighton to Victoria
377620 (only 5 cars today)
1A65 07:49 Brighton to Victoria
1A68 09:06 Victoria to Brighton
1A85 10:19 Brighton to Victoria
1A88 11:36 Victoria to Brighton
1A05 12:49 Brighton to Victoria
1A08 14:06 Victoria to Brighton
1A25 15:19 Brighton to Victoria
1A30 16:36 Victoria to Brighton
1A45 17:49 Brighton to Victoria
1A54 19:06 Victoria to Brighton
1A61 20:19 Brighton to Victoria
1A70 21:36 Victoria to Brighton
MK Tom
31 Aug 2011
Milton Keynes
If anyone is able to answer this that'd be very much appreciated!
455driver
10 May 2010
I have regularly seen 12 coach trains formed of 4x377/3, I have also seen 10 and 11 coach ones made up of 377/3s and /1s or /4s.
Bearing in mind the limited time I see them (just around Clapham jn) I am either very lucky or it is a common occurrence!
Manchester77
4 Jun 2012
Manchester
Is there any word on progress with the 377/7s? Are they any closer to entry into service or is further testing required?
railfanatic
27 Jan 2014
377/7 entry into service is imminent. They are almost at the end of the acceptance process, few of them should enter service within the next 2 weeks.
Techniquest
19 Jun 2005
Nowhere Heath
Good to see progress being made, the cascade process can finally begin!
Aye it's about time! Northern need some 319s to get training done, and the sooner that starts the better! Rather looking forward to getting a 319 from Manchester to Liverpool, or indeed from Liverpool to Wigan!
More stuff to score in London soon then, I doubt at this time even a month of training it every day in London would get me even close to everything done!
LouJ
3 Dec 2008
Does anyone know the numbers of the two new 377s that were standing in Willesden yard on Thursday?
skyblue
6 Jun 2011
Depending on what time. If it was morning and early afternoon, then they should be 703/4. If it was late afternoon/evening, then they would be 702/5.
physics34
1 Dec 2013
10 coach 377/3 + 377/3 + 377/1, 2 or 4 are common in peak times now for metro services, the 12 car 377/3s are normally just for peak time East Grinstead services and Brighton Expresses at the weekends.
Class377/5
19 Jun 2010
I was only refering to booked working. Certainly is a number of ways a train can be formed (or even just shorted formed by a carriage).
southern442
20 May 2013
Some peak mainline services (my morning East Grinstead-Victoria one in particular) are also 10-car 377's, normally two /3's and a /4.
physics34
1 Dec 2013
yeah you are right. There used to be a booked 11 car too, not sure if it runs in the new timetable though.
