Class 365 scrap movements + preservation discussion
DanNCL
17 Jul 2017
County Durham
Will it be fitted with third rail gear, or be restricted as far as Drayton Park?
If it was just shoe gear that was the problem, they might have found more use. It seems unlikely that 365525 needs to go south of Drayton Park.
https://railforums.co.uk/threads/go...of-class-365-fleet.189660/page-2#post-4173799
Yes there is zero point in sending a 365 to Moorgate... For starters, forgetting the lack of DC, they're probably not cleared.
Its way more likely they'd use a 717 to test it all!
Or that 313 test unit they already have for initial tests? Presumably the 717 fleet came with ETCS fitted as new?.
365s even if fitted with third rail pickup shoes are not and could not be cleared to Moorgate. Operating south of Drayton Park requires a cab end door for evacuation - the only stock cleared to Moorgate without are 73s (combination of being built to Hastings loading gauge and having inward opening cab doors makes side evacuation possible on those) and even they’re only permitted under limited circumstances.
ETCS testing to Moorgate can be done with 717s, and with 313121 if required.
D365
29 Jun 2012
I would imagine that when they sent 525 for trial fit, the class still had a future.
In 2015, it definitely would have done!
FYI - I've created a dedicated thread for any 717-specific ETCS discussion :)
Wyrleybart
29 Mar 2020
South Staffordshire
AIUI Network Rail have to shell out for the ETCS kit in trains expected to run on line fitted with the new equipment. Therefore a class leader is selected by the owner or operator to undergo the trial fitment of the kit. In this case I reckon Network Rail have funded the fitment to 365525 via the Rosco.
The DRS locos moved to Bo ness are the diesel equivalents - a 0/3 and a 37/6.
Think I read somewhere that Network Rail have ordered in excess of 700 sets of ECTS equipment for instaliing in locos like 60 66 67 70 73 90 and 92
D365
29 Jun 2012
Freight fitments are entirely different - the locos you’ve listed are being fitted under a Siemens-led programme which also includes Class 20, 37, 47, 56, 57, 86 and 325. The 365 contract is led by Eversholt using Alstom kit with ESG as the engineering specialists.
warwickshire
6 Feb 2020
leamingtonspa
Move cancelled. Locomotive now already on way back to derby at 0723 hours Thursday 06th January 2022.
These Belmont yard moves recently again appear to get cancelled at the Last minute maybe still issues at Newport Simms with scrap processing like before xmas?. Or maybe covid affecting things?
What is being moved to Newport Simms please ie the unit numbers.
Thanking you.
ls2270
24 Oct 2012
Basingstoke
Thanking you.
It’s 57312 hauling 365514 and 365534.
warwickshire
6 Feb 2020
leamingtonspa
Thanking you.
Good morning from pangbourne .
57312 with 365514 365534 to Newport Simms Docks for scrap.
Thank you all for the advance information. Again not ideal and sad to see.
YSTrains
13 Dec 2021
That was the last 365 I went on before they were withdrawn. Very sad.
On 3rd May, I went to King's Cross to see a 365 in its final weeks of operations. Unit 534 and 504 were there. I took photos inside unit 534. 534 is my special unit. Never to be seen again.
This picture from Facebook is apparently 365515 being cut up at Booths:
Two things caught my eye in this: firstly, the old interior door buttons can be made out still attached without the doors. Second, the bodyshell on the right of this photo looks like an old 373? (EDIT: Someone has said this is actually a 365 bit but upside down)
YSTrains
13 Dec 2021
What will happen to the traction motors?
John Jarman
11 Jan 2022
Ongar
I spent 15 years working on class 365s at Hornsey. I am really really sad to see them go, such good units and such a shame as they were really really reliable.
To think all of the mods that have been carried out in recent times, this really really is a waste of money.
I'd guess class 387s are better trains but do not have the character that the class 365s had. Such a shame!
Yes you’re certainly not alone. I’ve used them pretty much daily from start to finish, never had one fail to the point of the journey having to be terminated - which is more than can be said for a small handful of years of sporadic use on their replacements. One defective speedometer (able to be fixed by a fitter), a few reboots and a couple of times doors having to be given a kick to close is not a bad record considering the mileage I’ve travelled on them.
Many million pounds of all our money being quite literally burned away there, thanks to the DFT’s bull-in-china-shop franchising “strategy” of recent years.
A mundane train in many ways, but one where the designers managed to get a lot of things very right. The only downside was their rather unfortunate refurbishment in the 2010s, but even in their “dumbed down” state they were still pretty decent.
My annual car mileage has increased considerably as a result.
John Jarman
11 Jan 2022
Ongar
Yes you're quite right in all areas and particular the referb. In my humble opinion they looked far better in NSE colours and the interiors lost their homely feel when the carpets were replaced for lino.
On the positive side the doors had their much needed overhaul and I led a team to carry this work out and I was very proud how successful this was and the prof was in the pudding with the increased performance from the door systems. I found a surplus door actuator that was destined for the skip that I now proudly keep above my workbench in the garage as a little memento of the happy times. Does anyone know whether any parts are being salvaged?
Magdalia
1 Jan 2022
The Fens
Welcome to the forum, and thanks for all of the efforts of you and your colleagues with the Hornsey fleet. As a regular user of Kings Cross services I've long held a high regard for Hornsey's work, especially their ability to turn out 38 of 40 class 365s for the weekday peaks on such a consistent basis.
One thing has puzzled me for a long time, and I think it is the main reason for the early withdrawal of the class 365s. Why was there never a mid life renewal of the traction package, like on the class 465s? I heard more than once that the class 365s ran on Windows 95, but never knew whether it was literally true or just a metaphor for the ancient nature of the electronics/software. Either way, did the lack of a mid life renewal of the traction package make the maintenance task increasingly challenging?
Fuzzytop
4 Jan 2017
Richard Clinnick on Twitter reports that 365518 and 365539 are today's doomed pair, on their way to Newport at the moment. 539 was the last one I used, quite sad really.
14 to go...
D365
29 Jun 2012
It was only the Brush Class 465s that were renewed. The GEC Networkers (465/2, 466, 365) were not touched.
And no Windows on the Networkers. They don’t have any form of train computer.
warwickshire
6 Feb 2020
leamingtonspa
Good morning from goring and Streetly Tuesday 11th January 2021.
Today 57312 took 365539 and 365518 for scrap.
On the 0533 Belmont yard to Newport Simms stock scrap move.
Roast Veg
28 Oct 2016
Nothing like the integrated TCMS on later units, but the oft reocunted tale of the PIS is that FCC lost the "floppies".
