Class 365 PBC Unit and PIS system
RacsoMoquette
24 Nov 2023
South Cambridgeshire
Splendid! So the PIS displays on the 465 in this video were the replacements to the original displays as they look shorter and have a black box housing.
Also from watching that video from 1994, the internal displays seem to have a differant font to the later display.
WMasterJedi
23 Nov 2023
England
In my opinion the font looks the same, so does the box just it has been painted black.
Another curiosity of mine is did the original Julie Berry Class 365 announcements ever get reused for the Class 387s? As the “ Calling At” message sounds comparable to that of a Class 387, however the way she said “Finsbury Park” sounded completely different to ”Finsbury Park on the 387? My question is do phrases or words from previous recordings get reused on newer recordings, or not?
I don’t think so. What is more likely is that the 365 system was used as a model for the Electrostars to be based on. Further evidence of this is the way some of the Electrostar announcements are similar to those found on the 365s - eg new timetable.
WMasterJedi
23 Nov 2023
England
As I mentioned in a previous post, I bought another 365 PIS system controller but it was from a Connex unit as all of the destinations are from the Connex route, unlike my other controller which never had any Connex destinations instead just Great northern route destinations.
However on the side of my new controller it has a bombardier sticker which says "14/08/13", which is interesting as Connex stopped using 365's quite a bit before 2013 so why would they keep it with its Connex destinations.
365 Networker
19 Jul 2019
Perhaps this particular controller came from 365502 which was loaned from Connex to WAGN back in 2002 - before the rest came about a year later. The Great Northern destinations may have just been added on top (perhaps with different codes). Here's a photo:-
WMasterJedi
23 Nov 2023
England
That could possibly be an explanation, however I have been having a look at all of its codes and I have not found a single one with destinations for the Great northern route, every single one has been Connex unlike my other controller where they are all from the great northern route.
365 Networker
19 Jul 2019
How many codes have you tried? Perhaps try higher numbers e.g. 501, 502, 801, 802 etc. If the unit was in use in 2013, it will have been used certainly by FCC. My only other idea is that for some reason the software has been reverted to its original state for some reason.
WMasterJedi
23 Nov 2023
England
I'll keep looking as currently I have done 100, 200, 300 etc, also 150, 250, 350 etc.
Another possibility to answer why it has the original codes is that it may have been kept as a spare in storage so a database update was never done.
Does explain the version number being V1.1 and not V1.2 like my other one.
WMasterJedi
23 Nov 2023
England
Some more routes that I have found.
365 Networker
19 Jul 2019
There aren't any updates currently as I'm just arranging a day when I can meet up with my friend to get them.
No worries. Also spotted on ebay a photograph of the Networker Express test train - it has a slightly different version of the internal PIS unit.
I'm currently making a document of all the destinations that I have found and their route code!
That's a good idea - it would be very annoying to forget something that took ages to find! I wonder if it has some of the special messages such as "Empty to Depot" "Listen to Announcements" etc.
WMasterJedi
23 Nov 2023
England
The unit looks very similar to mine, not sure if there is a difference though.IMG_5124 (1).jpeg
WMasterJedi
23 Nov 2023
England
Currently making an Excel spreadsheet of the route codes and their destinations, and I have just found route code 191 with the route modifier of 1 which terminates at Canterbury West and starts at Cannon Street.
It’s the first Cannon Street route that I have found so far!WhatsApp Image 2024-05-14 at 21.36.37_9ca2f93e.jpg
365 Networker
19 Jul 2019
It’s the first Cannon Street route that I have found so far!View attachment 158143
Good work! Presumably the route modifiers also contain the stopping pattern information - stopper/semi fast/express. I would guess that this information was then transmitted to the EPROMs in the announcement panel. My understanding was that the announcements were programmed to the number of wheel rotations between stations.
WMasterJedi
23 Nov 2023
England
Yes the route modifiers just change the stopping pattern however I did find a couple that changed the destination for a couple of route codes.
WMasterJedi
23 Nov 2023
England
This evening I decided to have a look back inside my corrupted controller.
The logic boards for the controller are on a tray and 3 different PCBs are stacked on top of each other connect together with a small PCB using a connector with a ton of pins!
I slid out the main logic board to have a closer look to see if this corruption was caused by a broken trace and could potentially be fixed with a jumper wire. I have found a couple of spots that appear to have damage to the PCB trace, but I’ll have to see if that is the issue or if the corruption is the actual program and not something physical.
WMasterJedi
23 Nov 2023
England
I apologise that this may be hard to see, but there appears to be a damaged trace that could potentially be causing problems.IMG_5592.jpeg
WMasterJedi
23 Nov 2023
England
Images of the other 2 boards for if anyone is wondering what is on those.
WMasterJedi
23 Nov 2023
England
Sorry for the multiple posts but this board says Class 465/3 otherwise known as the class 365 demonstrator unit.IMG_5595 (1).jpeg
WMasterJedi
23 Nov 2023
England
Did you have any luck repairing the damaged traces? Some other things to look for may be corrosion/dirt on the metal contacts with the chips. Also, I noticed the error message mentioned a “fillgun” - I managed to find this:https://www.cryptomuseum.com/crypto/marconi/scimitar/fill.htm
Perhaps the depot used on of these to update the system?
You may have misread it as its not "fillgun" but instead "filigun". I cant find anything to do with filigun though, so possibly a proprietary tool they used in the depot.
365 Networker
19 Jul 2019
You may have misread it as it’s not "fillgun" but instead "filigun". I cant find anything to do with filigun though, so possibly a proprietary tool they used in the depot.
It definitely looks like ”fillgun” to me - there is an “!” above the second “l” which makes it look a bit like an “i”. Notice the difference in height between the “i” and “l”:-
WMasterJedi
23 Nov 2023
England
From looking online it appears that a fillgun writes data (sort of).
So that might be used to reflash the data to the chips, fixing the corruption and without having to take out the chips.
365 Networker
19 Jul 2019
Quite possibly - it would be interesting if Hornsey or Ilford still have any of these devices.
