Class 345 progress
samuelmorris
18 Jul 2013
Brentwood, Essex
I stand corrected, one of the diagrams was still operational I discovered (I didn't see the unit but apparently one was in service westbound from 6pm this evening), but none of the units I passed Eastbound between 6:20 and 6:40 were anything other than 315s - there should normally be two in-service 345s in there. Unusually for peak time I think I counted five 345s in the depot at Ilford.
Fred43123
20 Oct 2009
Somewhere
The 16:36, 16:50 and 17:17 off Liverpool St were 345s today, the 16:50's return trip (17:32 off Gidea Park) was cancelled due to a fault on 345007.
spark001uk
20 Aug 2010
Network Rail has nothing to do with it!
Technically not true, they have everything to do with its getting on and off, and running on, the parts of the existing national rail network.
However in the tunnel it is as you point out Crossrail, my mistake.
Ronnie268
4 Sep 2017
3C19 07+00 Ilford E.M.U.D. to Gidea Park Middle Siding 07+15
5C19 07+26 Gidea Park Middle Siding to Gidea Park 07+28
2C19 0729 Gidea Park to London Liverpool Street 0800
2C14 0807 London Liverpool Street to Gidea Park 0835
5C14 08+37 Gidea Park to Gidea Park Middle Siding 08+39
5C37 08+46 Gidea Park Middle Siding to Gidea Park 08+47
2C37 0849 Gidea Park to London Liverpool Street 0921
2W46 0930 London Liverpool Street to Shenfield 1013
2W63 1024 Shenfield to London Liverpool Street 1107
2W68 1120 London Liverpool Street to Shenfield 1203
2W85 1214 Shenfield to London Liverpool Street 1257
2W90 1310 London Liverpool Street to Shenfield 1353
2W07 1404 Shenfield to London Liverpool Street 1447
2W12 1500 London Liverpool Street to Shenfield 1543
2W29 1554 Shenfield to London Liverpool Street 1637
2C56 1650 London Liverpool Street to Gidea Park 1720
5C56 17+20 Gidea Park to Gidea Park Middle Siding 17+22
5C57 17+29 Gidea Park Middle Siding to Gidea Park 17+31
2C57 1732 Gidea Park to London Liverpool Street 1800
2W52 1807 London Liverpool Street to Shenfield 1847
2W65 1854 Shenfield to London Liverpool Street 1937
2W78 1952 London Liverpool Street to Shenfield 2035
2W87 2044 Shenfield to London Liverpool Street 2127
2W00 2140 London Liverpool Street to Shenfield 2223
5V81 22+34 Shenfield to Ilford E.M.U.D. 23+04
Do we have any diagrams other than the above?
samuelmorris
18 Jul 2013
Brentwood, Essex
I believe the failure was 2W29, so yes, most likely. 2W52 was absent this evening which was concealed among the chaos caused by the fatality at Ingatestone, but probably related.
Something I noticed this evening waiting at Gidea Park to transfer to the Shenfield service behind, to lock the vehicle doors and take the train out of service, rather than press a button high up on the outer wall of the vehicle adjacent to the gangway connection like on most units, the platform staff were simply holding the door open buttons in for five seconds. Someone please tell me this only works after it's been enabled by the driver. Surely passengers wouldn't be able to trigger it if they (accidentally or otherwise) did the same?
rebmcr
15 Nov 2011
St Neots
S Stock has the same feature, and yes it has to be activated from a cab.
Wivenswold
24 Jul 2012
Essex
I'm really surprised that carriage doors can't be shut and locked from a remote fob in this day and age. Driver walks through train from front, empty carriage? Bleep.
samuelmorris
18 Jul 2013
Brentwood, Essex
Good, that's as I would expect, but one does wonder sometimes :lol:
I agree in principle with remote locking, but seeing what can happen with that technology in practice with cars, it's probably best they don't. The impacts of spurious signals causing doors to release/lock by themselves or fail to release when expected doesn't bear thinking about. Unnecessary complexity really, this process seems to work well enough.
jon0844
1 Feb 2009
More likely platform staff and I think you can imagine the mess when the fob stops working, or is lost, or is the fob for the wrong unit. And wouldn't it be tempting not to check each carriage for people (and lost property or suspect packages) if you could just press a button?
May as well just get the driver to count to ten and assume everyone got off and shut down from the cab!
MCR247
7 Nov 2008
Even worse, imagine the complaints on here if it went wrong! :)
tsr
15 Nov 2011
Between the parallel lines
Wasn't that the instruction which caused lengthy industrial action on the Bakerloo Line a little while back? Drivers were basically told not to check their trains or wait for someone to do it, but to flash the saloon lights, make an announcement and then go into the sidings.
samuelmorris
18 Jul 2013
Brentwood, Essex
One of them caused a fair amount of disruption yesterday and I believe was listed as a 'traction fault', the one from the day before (same diagram but not necessarily the same unit) was 'brake fault', beyond that I can't say unless someone on here has any insider knowledge.
Dave1987
20 Oct 2012
A friend of mine travelled on one today. They were not that impressed. Said the seats were rock hard and they felt very uncomfortable after just 15 minutes on board. They did not mention anything else about them as that was their overwhelming feeling, discomfort. They travel regularly on the Circle Line so are used to the newer tube stock which is essentially the same layout but with more forgiving seats.
samuelmorris
18 Jul 2013
Brentwood, Essex
The S stock seats are definitely softer, without a doubt. I'm not sure about 378s but they may be a little softer too. The transverse seats are tolerable but the longitudinal ones are definitely about the hardest seats there have been on LU stock.
iphone76
6 Nov 2010
South Essex
I won't go into too much detail, but this feature isn't quite working as planned at the moment. I must admit, I prefer the old fashioned porter buttons at the end of the carriages. I'm not looking forward to the time when I may have to tip out a train en route.
jon0844
1 Feb 2009
What is with Bombardier and buttons? ;)
theking
30 Sep 2011
The door warble is a joke as is the autoclose doors
Was at liverpool street on one of these for 9 minutes someone gets on door warbles door closes someone comes and presses the button more door warble.
I even moved to near the front and could still hear multiple door openings and closing it's a joke it's so loud don't see the need for it.
Defiance149
30 Dec 2013
Everything up to and including 345017 that have been delivered are 7-car, 345018 and 345019 both at Old Dalby are nine-car.
87electric
27 Jan 2010
Poster on Anglia Gen reported 001-017 are 7 cars initially.
019 was recently delivered to Old Dalby as a 9 car.
samuelmorris
18 Jul 2013
Brentwood, Essex
Fair enough, my mistake.
Yes, I agree about the door sounders. I don't have a problem with automatically closing doors but the excess noise is infuriating! I understand why there needs to be a sound played when the doors are first released at a station and I also understand why one has to play any time the doors close. That said, I think the duration is excessive and I don't feel it's necessary to play a sound to denote when doors already released are opened. I don't recall that being a necessary part of the DDA spec? Perhaps just play the sound once rather than six times when that happens. Oh, and drop the volume a bit!
AM9
13 May 2014
St Albans
I presume that like the class 700s, the 345s have weight sensors in the suspension so that they have a measure of how well loaded cars are, so maybe they should adjust the PA/warning signal system volume to compensate for the absorption of noise in a full car compared with the hard surfaces of a near empty one.
whoosh
3 Sep 2008
Well blind people are disabled aren't they? AND YOU HAVE TO BE LOUD WITH DISABLED PEOPLE IN CASE THEY DON'T UNDERSTAND, DON'T YOU?! :roll:
VTEC's Mark 4's are ridiculous in this respect too, with excessive volume and duration of door opening sound. Blind people aren't silly, they recognise the click of a door release, but their world is being overrun with stupid electronic sounds to 'denote' something happening.
Well they already know, because the something happening has a sound it makes already which 'denotes' it happening!
