Class 27
Bill EWS
10 Feb 2006
Didcot
D306, you have given the wrong directive. Those wishing to download the 27 can go to:
http://www.bvetmd.co.uk
Thanks for the news of the new Train. I am looking forward to giving it a spin and commenting later.
Cheers.
BillEWS
eezypeazy
4 Jul 2005
It IS right now, D306, since your post was edited at 1150.... it WAS pointing to the wrong place earlier... so, Bill was correct....
Regards
eezypeazy
Jordy
9 Jun 2005
WCML South
Yeh it was pointing to Fotopic for some reason, but I corrected it.
Just had a drive, excellent work :)
Bill EWS
10 Feb 2006
Didcot
Well, I am not going to make anything more of it, it was a simple error and was quickly sorted out. But thanks to Eezypeezy for proving me correct in the first instance.
I have since given the 27 a run on the Edinburgh-Aberdeen, using the HST Route file. The 27 looks great. It is many years since I was on one and it was really nice almost being back in the cab once again. I worked on them over the Fraserburgh and Peterhead branchlines and on the mainline to Inverness. Along with the Mann Type 2's and 56's (31's) these were the first locos I learned about from day one.
The wide view is excellent and the loco sounds appear to be very authentic, down to the very noisy compressor(s). I had forgotten about that chunky control handle. The horn is also a nice sound compared to the more modern ones.
One of the nice things too was the lack of TPWS, what a joy to drive without them.
The first run I gave was from Edinburgh to Dalmally, just to see what the 27 would do. It struggled to gain speed and didn't go over 78 mph before the 60mph check approaching Dalmally. However, it gave me a good idea what to expect on a longer run.
Thye second run was from Dundee to Arbroath, which gives a fair length of fast running and would test the loco to see if it could touch 90mph. Once again it struggled out of Dundee and took ages to eventually reach 85 mph before shutting down for Arbroath. The train arrived two minutes late on the HST timings. That doesn't sound much but if it kept the same average loss all the way to Aberdeen that could soon mount up.
However, in spite of that, it was an enjoyable experience. The train handles well and the Sultzer sounds are a joy to hear. I did consider that possibly this particular run could do with double heading, as these locos mainly were when I worked on them.
As mentioned the speed never went over 85 mph, which, as again mentioned, could indicate the need for a bit of double-heading, or a reduction in the train load. Perhaps a route file deliberately programmed for the 27 would show the loco to it's best. Or doesn't that make any difference. I am no BVE programmer.
I liked the wide view and the view out of the window and overall the author has done a grand job of producing the 27. Well Done. Another excellent addition to BVE 4 trains.
Cheers.
Bill EWS.
The Snap
10 Jun 2005
I gave it a spin yesterday on the single line up to Blackbrook - very hellfire! Certainly makes lots of noise!
Excellent work again from Martin. It’s just a shame there are no possibilities for diagrams in NWM and other routes. :(
Bill EWS
10 Feb 2006
Didcot
Well said, D306. BVE shouldn't have any impossibilities as long as there is a genuine reason why a particular train or locomotive is acceptable on any route. Simply find a reason for it.
I have not long given the 27 a run around the 'Loop'. An ideal route for the 27and it feels as if it is at home too. However, it really struggled everywhere and didn't often arrive right time and overall I lost 8 minutes. Perhaps I should have a go at adjusting all the stops to suite! Besides, the route could do with a timetable. I can hardly remember the station names.
This route is also good example where you return over the same route for the final part of it and shows that 'reverse' routes are available. This is quite an oldish route now.
Talking about the Loop, it's a shame that there isn't any work going on to update it to more modern working. The automatically cut off AWS doesn't feel right and the signalling out of place. In fact, when approaching signals you get both yellow and red lights blinking even when at green. But the route has a nice feel about it and would benefit from an upgrade. But then, I'm not the one that can, or would, have to do it.
devon_metro
11 Oct 2005
Railtour...
Dennis
8 Aug 2005
Trowbridge
Excellent work - engine sounds are fantastic :grin: Glad to see no TPWS has been fitted.
I hope the neighbours are off out somewhere nice this weekend, I wouldn't want to disturb them with Sulzer thrash.
Jordy
9 Jun 2005
WCML South
Just had a little tinker with the train.dat file, now simulates about load 3, hellfire <D
