SkinnyDave
- Joined
- 11 Mar 2012
- Messages
- 1,242
The Scottish routes are calling for Class 220/1/2 when and if available a 185 wouldn't be much more of an improvement over 180s if you ask me
Waterloo Exeter seems a really good call. What about Severn and Solent routes too? Or other serviced in the West Country? I remember travelling on a pacer between Plymouth and Newton Abbott a couple of years ago so surely there's scope for 185s down there?
Any 221's freed up from West Coast by a new order of baby Pendo's will be sent to XC to boost capacity...
Are they?
Who is doing the calling?
If you mean the Central Belt - Inverness/ Aberdeen services then why would you want a four coach narrow 125mph unit that has fewer seats than the three car 170s already running those services?
Speculation. You can't really assume that at all. XC's franchise is a financial basket case by all accounts, just because stock might become available doesn't mean DfT will allow it to be used.
Just thinking aloud re Yorkshire Region, there's going to be lots very busy of non-electric lines after 2019, so once the MML & TPN are wired, what's left ? There's a strong desire to wire the Caldervale Line (an early key target for the West Yorkshire Transport Fund), there's also a strong desire in South Yorkshire to wire the north of Sheffield lines - which could be any combination of the Sheffield-Barnsley-Kirkgate-Leeds or Sheffield-Moorthorpe or Sheffield-Doncaster plus a desire to wire the Hope Valley Line. The north of Sheffield lines could be a convenient cascade for 185's in the medium term, even if some of the routes are under wires. Both West and South Yorkshire are desperate to get shut of the 14x & 150/153/156 fleets - I accept that the 185 fleet isn't that suited as a replacement for routes served by the above though.
So, what about after that ? The Penistone line is never gonna get funding for wires, so maybe battery solutions in the long term could work there or a diesel tram-train ? There's the big elephant in the room of Liverpool to Norwich - that's a prime Voyager/Meridian cascade opportunity, the Sheffield-Derby-Birmingham route is very busy in my experience, perhaps some opportunity for either 185 or more 22x diesels ?
I'm not that familiar with the NW but surely lots of easy cascades there too... I'm struggling to see northern PTE's letting the 185 fleet go to Scotland or even down south - the Rail North brand will be as strong as TfL and the DfT won't wanna mess with that karma by taking the only half decent local stock in the north away.
Interesting times ahead for sure.
I'm not that convinced that a Voyager is any worse than a 158 for dwell times. - also, aren't many if the Liverpool to Norwich services running as 2 car units. ?
Hull is almost certainly to be wired. Middlesbrough is very very likely in CP6.
Current routes served which will remain not electrified Medium Term:
Scarborough, South TPE, Barrow.
Scarborough has an easy solution as regularly discussed on here. Extend Blackpool North - York service with it becoming Semi Fast Leeds-York.
South TPE, well it will need some big platform extensions to take 6 cars. Although if you run it so that it is only 6 car to Doncaster you would only have to extend Meadowhall which is likely to be done alongside HS2 anyway. That will absorb some, plus also the introduction of a third Manc-Sheffield fast service.
could they turn them into electric trains?
Never been on one
SWT 450/444 units are absolutely superb and I'm sure these are too
I am slightly amused by this thread as any potential cascading of the 185's is clearly some years away even assuming the electrification scheme run to schedule, and as for the assertion that this line and that line will also be done, well that is no certainty and within what timescale.
Anything could happen at the end of the day...Blackpool/North TPE electrification may take a couple of years longer than expected, who knows? It's just a speculation thread.
Still think replacing 185s with 158s on South TPE would make sense though - not least because the 158s can make full use of the line speed, 185s can't. Maybe we're thinking too big as far as the 185s go? Once the Bolton line speed is upgraded perhaps it wouldn't be so daft having a small selection of 185s working say Manchester to Wigan/Southport shuttles (obviously with first class removed), or Manchester to Chester shuttles?
Another possibility is Manchester to Cardiff/Swansea if the 175s can be cascaded elsewhere. South of Shrewsbury I'm guessing a 185 would beat a 175 to Cardiff with all the stops en route, because of its better acceleration?
On which particular sections on the South TPE lines did your quote refer to regarding the matter of the line speed ?
To get back on topic though, the 185s are awkward to re-deploy largely for the same reasons they've not been entirely successful on their current duties.
Technically, they're brilliant units: fast, powerful and fairly smooth. But, they've always been far too small capacity-wise and were a drop in capacity compared to the 158s they replaced. For this reason, I'm not sure they'd be suitable for Liverpool-Norwich.
As part of the deployment, I'm not clear on why they couldn't be extended by inserting a new build Desiro trailer to make them four car - reducing the (expensive) power to weight ratio, too. As 4 or 5 car sets (3 powered), they would seem useful in Scotland (WHL, HML, FNLs).
185s would not gain anything over 175s on this route.
There are "Sprinter" differential speed limits between Nantwich and Onibury which 175s can use but 185s can't.
The 175s do quite well over Llanvihangel summit and it's pretty flat on the rest of the Marches.
Although a first class section would be a useful upgrade, the standard accommodation is reduced and the 1/3 2/3 doors don't help.
Bristol-Portsmouth might be a suitable route, but they are likely to go 16x.
They would also be good for XC services currently run by 2-car 170s (Cardiff-Nottingham, Birmingham-Stansted).
