Class 175s to GWR
RPI
6 Dec 2010
1219 3 car 158 off plymouth to Penzance on Monday had standees. Don't forget alot of these trains connect off London services and are swamped at Plymouth when not formed of a 5 car IET. Saturday mornings too, especially when Argyle are at home are going to need more than a 3 car. I like 175s, I think they look good trains, but I do fear we are going to see overcrowding in a way that we just haven't seen down here on local stuff, post covid.
It's not the norm though, I work these most of the time, including some of the earlier ones that originate in Exeter and they're generally very comfortable.
Summer holiday season, so not school/college times, I have had to stand several times St.Erth - Truro, normally when a 4-car 150 formation, but also a Castle set last summer.
Yes, things are better than they were pre-Covid, but still have found capacity to be an issue.
Roy
Certainly isn't the norm, they can be busy but certainly won't be unbearable with 3 car 175's. Which mainline workings are 4 car 150's?
The exile
31 Mar 2010
Somerset
As you’re using it as an example of overcrowding, I’m sure this is not the case, but I’m frequently on trains where there are standees (sometimes to the extent of hardly being able get through the vestibule) yet the loading appears to be under 100% of seating capacity. (Ie more empty seats than standees).
Reported as 175101/113 T&T by 37501/510. Passed March 74 late and no further reports on RTT. May be in trouble
Presumably they can just hold the train in one of the loops/sidings outside the station if it's broken down in some way.
In an update on RTT, the diagram now appears to have arrived on time at Wolverton, but no report is seen on every location after March before this. Does anyone know if the full allocation made the journey or if an alteration occurred?
Obar123
16 Aug 2024
Cambridgeshire
Nope, turned back at March and has gone back to Ely, just arriving back into Papworth as I am typing this. It was 37501, 37510, 175101, 175113. The 37s were working too hard for the short set so the brakes may be on as it sounded like an air leak.
RPI
6 Dec 2010
Probably fine after Saltash too.
Rich McLean
6 Feb 2012
It's going into peak holiday season. It is not unusual for the Paddington to Penzance Trains to be full and standing, leaving people behind, right the way through until Truro when it empties out a bit, but remains busy until St Erth. This pushes those left behind onto Plymouth & Exeter Terminators, who then change at Exeter or Plymouth onto the local stopper filling that up.
With the 175s they can double them up for the school holidays and use 5 car IETs where possible to fill the gaps to meet demand by moving them around. Most of the year, 3 cars will be more than adeqate with a few 4 car workings thrown in. As part of the works at Wolverton, they are being fitted with new driver seats and SDO Mods amongst other things. Saltash will still be an issue, but ensuring passengers are in the right carraiges at St Germans will be a workaround.
Once all crews west of Taunton are trained, then Bristol crews can be trained up, which will allow them to run through to Cardiff again, with portion working and a few 5 car 80x thrown in. Diagrams can also be optimised at that point to get the most out of the stock.
Choo choo 66
26 May 2020
Kernow
That 1219 from Plymouth is regularly fairly busy throughout, as well as a number of the other trains. Winter time it isn’t as bad but peak summer 3 car 175 will certainly be full and standing regularly if on these trains
JKF
29 May 2019
The 175s are replacing the Castle Sets, which will be withdrawn, the class 158s, which will move to Bristol Metro and IETs. The Class 158s will release some Turbos to head back to London Thames Valley to allow extra services to be run.
Aren’t 158s not particularly great for metro services, with their doors at carriage end rather than thirds like on the turbo? A lot more hassle getting bikes/pushchairs on and into appropriate storage areas which will increase dwellings times. We do get 158s already on Severn Beach line but the more common turbos are preferable, and quite smart after the recent refurb.
Wilts Wanderer
21 Nov 2016
Has there been any suggestion that the Cardiff-Penzance through workings will be restored in the future?
Rich McLean
6 Feb 2012
It was always the intention. The split in the service should be temporary, for ease of crew training. We are looking at a few TT changes before we see through workings returning and as always subject to DfT approval.
TT-ONR-NRN
30 Dec 2016
Cambridge
With solely IETs I suppose, and 175s being restricted to services that don’t go north of Exeter?
Strictly Oakhampton and Barnstaple are north of Exeter.
As the main overhaul depot is at Bristol, will occasionally work there, and there are some early and late trains that get that far (but not onto Cardiff). These might be ECS workings, and often scheduled as driver only
The_Train
2 Jun 2018
I see it was canned at March so presumably stock has been dumped in the sidings there? RTT reporting the cancellation reason as a problem with the brakes (although this should be taken with a pinch of salt as we often see many random reasons thrown into a cancellation)
Edit: Seen elsewhere that the stock was returned to Ely Papworth
I think the latest round of Government funding, has covered the new stations in South Wales which would see a TfL service running to Bristol (and thus alternate with the Cardiff-Portsmouth trains)
It could potentially lead to revised plan if effectively also got Cardiff-Bristol-Exeter section covered by TfW and XC with a change, and need to serve the new stations at Wellington and Cullompton. Sort of opens question is Cardiff-Penzance to be a limited stop fast service, or a semi-fast service.
The extra stations probably mean a direct like for like restoration of through service might be modified
fgwrich
15 Apr 2009
Hampshire
It could potentially lead to revised plan if effectively also got Cardiff-Bristol-Exeter section covered by TfL and XC with a change, and need to serve the new stations at Wellington and Cullompton. Sort of opens question is Cardiff-Penzance to be a limited stop fast service, or a semi-fast service.
*TfW.
I’d be surprised to see wales services extended back to Devon again frankly, Swansea > Bristol yes, into Devon no.
Though frankly this is somewhat academic and probably best served in another thread.
Bikeman78
26 Apr 2018
The mainline Exeter to Penzance services are mostly dead (non London services) outside of the odd college/school kid train, so 2/3 will be more than adequate and actually easier to manage.
It's surprised me how much quieter they've become even since the timetable change where the Cardiff trains were split, I'm not sure if this has resulted in XC being busier?
I expect the loadings will pick up in the summer. I seem to recall that passenger loadings increased a lot when the through trains started so splitting the service permanently is a bit of an own goal.
tfw756rider
30 Nov 2024
Wales (sometimes in England), thanks for replying!
Any news on the units at Wolverton? What is being done to them and when can we expect to see one?
We know that they're getting new high-back driving seats with head rests, the repositioning of some controls in the driving cabs, and Selective Door Operation (SDO) modifications have even been mentioned.
I wonder if they're also doing anything to the livery/branding/interior trim there?
TT-ONR-NRN
30 Dec 2016
Cambridge
Oh for goodness’ sake, behave ;)
Robin Edwards
1 Dec 2013
Retry scheduled for Tuesday 15th?
BillStampy
6 Jan 2024
Llanharan
Seems my notifications from this thread didn't wish to go through recently, just caught up on everything.
There's these paths in tomorrow from Laira to Saltash, are these expected to be a 175?
fgwrich
15 Apr 2009
Hampshire
Looking further throughout the morning and into the afternoon, it the does a few shuttles from Plymouth to Liskaerd and back before heading to Laira just after lunchtime.
BillStampy
6 Jan 2024
Llanharan
Another thing to note is that it's operated by GWR directly, not ROG like we've previously seen. Likely using the newly trained driver managers I assume? (This is also all assuming this is still a 175!)
