Class 175s to GWR
Xavi
17 Apr 2012
Tfw units are being withdrawn at end of their c6.
Correct, though with GWR units going through C6 a right now, adding one more to the fleet would allow the initial Newquay hourly service to go ahead in May without the 175s....
TT-ONR-NRN
30 Dec 2016
Cambridge
It probably could anyway, likely at the expense of a four carriage Exmouth Paignton diagram.
Geeves
6 Jan 2009
Rochdale
There's one Frankenstein unit at TfW (150279) made up two none crashed carriages that presumably has had all the works, it would be odd if it went to SIMs so soon!
Anyway that is off topic, I did like the 4 car GWR 175 the AI had created! Realistically it could be done by stealing a 3 car centre car so maybe they know something we don't
Anonymous10
19 Dec 2019
wales
However they are only being withdrawn at the end of their C6 certificate so would require a new c6 exam.
Xavi
17 Apr 2012
I believe this has been put back beyond May now as the works are behind.
Interesting. I wouldn't be surprised if this is related to Treasury>DfT>NR release of funds (micro-management) rather than ability to keep to programme.
Anonymous10
19 Dec 2019
wales
So cost and profit over service to the public, it is called public transport for a reason
The issue is even if a tfw unit was acquired they would need a c6 and alot of work doing. They are reported to be rotten and riddled with rust. So would be talking months from transfer to actual availability.
Wolfie
17 Aug 2010
What would the power situation be with a four car 175?
Tevion539
23 Apr 2020
The Milkyway
Would 4 cars fit on their intended route? The 175s don’t have SDO. They do have TUDI, but this must be activated in the trailing cab of the desired unit and only locks out trailing units.
Xavi
17 Apr 2012
Slip one ex-TfW unit into the GWR C6 programme and maximise the mileage on the existing GWR fleet before they head to Wolverton. That gives an extra unit in traffic.
It’s an option to keep the Cornwall Metro promise if DfT (Treasury) pulls the 175 deal.
Towers
30 Aug 2021
Can the TUDI selection not be made from the driving cab? Seems a rather bizarre design if it were only operable from the rearmost unit, how is that intended to work mid-journey?
TurboMan
5 Apr 2022
It is operated in the rear cab of the front unit. But it's not designed to be used as an SDO system during a journey and it is unlikely that GWR will use it in that way (too much risk of error).
Towers
30 Aug 2021
Ah; I mis-read the original post!
craigybagel
25 Oct 2012
At the 175s previous TOC, TUDI was operated solely by the guard (as they had sole control over everything door related). There was a protocol in place for using it mid journey with passengers onboard if absolutely necessary but it rarely was carried out - mostly it was used to lock a unit out for the duration.
Towers
30 Aug 2021
Are they full guard release? Their class 180 cousins had an unusual arrangement involving driver & guard exchanging buzzes, ISTR!
craigybagel
25 Oct 2012
Yes, full guard release. As built they were set up for driver release, and the intermediate panels only had close buttons, but the wiring has been removed from the drivers release buttons, and release buttons have been added to the intermediate panels (in addition to the full panels on the cab bulkhead).
3973EXL
2 Feb 2017
tfw756rider
30 Nov 2024
Wales (sometimes in England), thanks for replying!
A third 175 going from Ely to Laira, but 175002 or 175114 going back to Landore?
Tevion539
23 Apr 2020
The Milkyway
I worked the 175s for about six months before they left service. The above posts are correct. The doors are fully guard controlled and TUDI was supposedly used when running multiple units on the Marches. Leominster, Ludlow and Abergavenny have shorter platforms and wouldn’t accommodate 6 coaches. The official stance was that if we were to leave the rear unit unlocked, anyone for stations with short platforms were to be made aware by the time they reach the penultimate stop so that they could move to the front unit in a timely manner. However, I never experienced anyone ever using TUDI and rear units were typically just locked out of use. Multiple 175s only typically run when one had been to Chester for service and needed to get to Cardiff in my experience.
