Class 175 future speculation
Mzzzs
14 May 2022
London<->Nottingham
They slip into the GWR fleet best and would definitely suit them.
Edit
With a shortage of turbos they can be used to fill in and then be moved to replace 150.
However, i think a mechanical overhaul and some design changes need to happen before moving anywhere
How do you reach that conclusion? They would require a large training exercise to be undertaken. That costs money. Much easier to stick with the current fleet, even if there are difficulties with Turbo reliability.
CBlue
30 Mar 2020
East Angular
EMR would also be ideal for the 175 to replace the 158. There are 27 of them vs 26 158's, Plus about half of them are already 3 cars so they can easily can work in 4-6 cars, has a higher top speed, larger toilets etc. Seating Capacity is also very similar (134 per 2 car vs 158's 138 ish). Im not sure the acceleration between the two but i expect that'll also be similar.
A small section of first class on the 3 car set?
I think EMR passangers on the Norwich - Liverpool service would welcome these type of trains, Only missing is the end gangway.
They don't meet requirements to do Sprinter speeds (unlike 170s etc) so no chance they'd make it to Norwich on time across that weak Fenland track.
Rhydgaled
25 Nov 2010
Given the lack of end gangways I personally would only suggest 175s for Liverpool-Norwich if they were run as 5/6 coaches throughout (ie. no splitting and joining at Nottingham or anywhere else) which would probably mean they need more units.
GWR to cover Cardiff - Portsmouth route, much more suitable than 158/166 units. The cascaded 158's can remain with GWR to help replace the HST's and the 166's can be swapped around GWR to release 165's to Chiltern and in turn allow replacement of their LHCS.
Not sure if 175s would be more-suitable than 158s due to the afformentioned gangway issue but a suitably refurbished 5-car 175 formation on Portsmouth-Cardiff certainly would be an improvement on 166/165.
Also approach TfW to start them back at Swansea/Carmarthen or link them to the two hourly Cardiff - Milford Haven service giving a direct South Wales - Bristol - Portsmouth service.
I'm not sure the lines west of Swansea/Carmarthen justify more than 3 coaches, so extending a 5-car Portsmouth service west of Cardiff is probably unrealistic (as much as I used to fantasize about a Fishguard Harbour to Portsmouth Harbour service - although that would have been with 158s which could split at Cardiff). Currently I'm lamenting that TfW didn't snap up more of the mark 4s that went for scrap, since the ideal thing in my view would be to run Manchester-Swansea hourly with mark 4s and cascade the 175s west to Landore with the 2-car sets doing HOWL and some Swansea-Pembrokeshire workings.
The 3-car 175s would then do the rest of Swansea-Pembrokeshire plus an hourly Cardiff-Carmarthen calling at only Port Talbot Parkway and Llanelli (partly for speed to compete with the M4 and partly to avoid it getting swamped by passengers between Cardiff and Neath/Bridgend/Swansea). This fast Cardiff-Carmarthen service would extend to Fishguard Harbour twice daily (calling only at Whitland and Fishguard & Goodwick) as the boat trains (other Fishguard workings fall under the Swansea-Pembrokeshire category above) and to Milford Haven (fast to Haverfordwest, calling only at Whitland on that leg) providing roughly half the service at the latter (the rest going to/from Swansea).
Do GWR have any crew based in Cardiff and, if so, could they do an exchange (TUPE?) of employees between TfW and GWR with any TfW staff who sign 175s (but haven't learnt the new TfW stock yet, to avoid wasted training) transfering to GWR and some GWR staff moving to TfW in return?
Where are the SP differentials on that route? I was aware that 175s are unsuitable for XC's Birmingham-Stansted route because of SP differential(s) somewhere on the route, but the only section common to both routes is Peterborough-Ely I believe so it's possible only one of those routes is impacted.
RailWonderer
25 Jul 2018
All around the network
The Class 175s were built with steel-bodied vehicle shells from Spain, with no corrosion protection applied - the damp British climate has not been kind to them. The body shells are said to be in a shocking condition, so the scrapyard may be the only suitable place for these units once they leave TFW, which seems a massive shame as they are very comfortable from a passenger point of view.
CAF also built the bodyshells of the 332s and those were said to be racked with corrosion issues. I'm curious what state Northern's 333s are in by extension (OT I know). Scrap I agree is likely, as Northern is the only credible place for them to go and I can't see them wanting what is now a microfleet of serviceable units.
The ex MML ones did have an extra row as built, legroom was awful.
Those are now with XC and EMR (which are ex-LM and CT).
Mzzzs
14 May 2022
London<->Nottingham
The 150 won't last forever they have to go at some point. 20 150s for 27 175 however take away 2 units reportedly used as donors.
Emr are better off keeping the 158s than the 175s just for the gangways they have.
Northern look like they won't take on another type of train, especially one with a unique design.
Northern have invested money into corrosion-riddled 156s I can see another TOC doing the same.
skyhigh
14 Sep 2014
The fleet is undergoing work to repair corrosion so it isn't an issue going forward.
NorthernSpirit
21 Jun 2013
Whichever rolling stock company that owns the class 175's should look at reforming as many as they can into fixed walk-through four car units and get as much use out of them as a short term stopgap. Then whatever's left of the unused units is then stripped for parts to keep whatever's left going and the shell that's left is scrapped.
TT-ONR-NRN
30 Dec 2016
Worcester
They can - on the most basic level, not taking into account potentially corroded or troublesome coaches - get seven walk-through four car units from the fleet, using two of the single intermediate cars from the fourteen three-car sets, leaving thirty-six remaining driving cars, which I suppose could be used as eighteen two car sets or scrapped.
Both Class 180 and 175 intermediate cars are 23.03m length, so if we're to get really speculative, you could steal the centre cars of EMR's 180 (although those are notably corroded) and you wouldn't be able to tell if they were used. Using these, you could have a total of nineteen fixed walk-through four car 175s.
Eight surely or does your measure of 'corroded or troublesome coaches' exclude two intermediate coaches from this assessment? There are sixteen three-car units, although this proposal would leave nineteen two-car units.
I guess that a fleet of four and two car units could be operated as four car on all services like the 196 fleet.
Lots of logic in making a few 4 car units out of the best bits and keeping spare engines and bogies, and handful of spare driving cars
Possibly if they were then restricted to a single route, releasing other standard units, then wouldn't need so much staff training. Somewhere like Weymouth-Bristol-Worcester would be ideal.
I suspect that isn't the sort of route that would be ideal to keep the staff training to a minimum, given the number of traincrew depots on the route.
TT-ONR-NRN
30 Dec 2016
Worcester
Yes, eight; there was me forgetting about 115 and 116.
Anonymous10
19 Dec 2019
wales
You'd still have to train Bristol and Westbury staff and I'm sure there's probably another depot but I'm no expert there
61653 HTAFC
18 Dec 2012
With regard to the 4-car suggestion, you'd be creating a bit of a microfleet which many view as anathema. Eight units would be comparable to the seven 155s (though with double the capacity and one extra unit) so they could be a straight swap for those. However with all the investment in the depot at Hull the 155s will presumably be around for a good while, so swapping them out would render that work pointless. The 175s probably aren't in much better shape than the 155s which had a heavy refurbishment a few years ago. The 155s also have at least some commonality with other Sprinters, which the 175s don't. If there's another place where such a fleet could work without creating too much of a headache, but it's unlikely.
As nice as they are to ride, the scrapheap is still the most likely destination for them.
Yes, but you would have 8 4-cars and 19 2-cars. The latter units could be formed up as 9 further 4-car pairings, obviously not permanent with a spare, so it would be a fleet effectively of 17 4-car units that could be diagrammed for, perhaps, 14 4-car workings.
61653 HTAFC
18 Dec 2012
Yes, but you would have 8 4-cars and 19 2-cars. The latter units could be formed up as 9 further 4-car formations, with a spare, so it would be a fleet that could be diagrammed for, perhaps 14 4-car workings.
I was assuming the spare driving cars would be stripped and scrapped, maybe with a couple kept intact as spares in case one had one of those "thermal incidents" the units seem to enjoy from time to time.
That seems a little odd as an approach though, as I don't see how 4-car units are less likely to have a thermal incidents than 2-car units.
skyhigh
14 Sep 2014
155s are a simple conversion course for crew from other 15x, roughly a day. 175s are a completely different type so would need a full traction course and you'd need 3 large depots (Leeds, York and Hull) to do it as they all currently work 155s. 155s are also compatible with all 15x/170s and often work in multiple. You'd lose that with a micro fleet of 175s.
61653 HTAFC
18 Dec 2012
They aren't, but the original suggestion disregarded the 2-car units so I was working from that basis. Semi-permanent pairs of 2-car units would also cause issues with revenue protection due to the lack of gangways.
I agree it's unlikely and a bit daft- perhaps I didn't make it clear enough but I wasn't advocating the idea, just trying to think of ways it could (that word doing a lot of heavy lifting) work. As I said, scrapping is the most likely outcome. The Chiltern suggestion has echoes of the "loco-hauled 442s for TPE" proposal about it.
MattRat
26 May 2021
Honestly, it's looking more likely the 175s will stay with TFW for the foreseeable future, due to how slow the 197 procurement is going, and the fact they've gone to the effort of getting them working again.
FrodshamJnct
14 Apr 2019
Cheshire
The 197 entry into service looks to have picked up a fair bit of pace to me of late, and what were TFW supposed to do with the 175s that had “thermal incidents”? Leave them sat somewhere broken?
Mzzzs
14 May 2022
London<->Nottingham
Well, the class 175s would have to be returned to the lessor in an acceptable condition and the trains being unable to move also hazardous would not be in an acceptable condition so they have to be fixed and then returned.
Ayman Ilham
2 Jul 2016
Blackburn (Lancs)
Even with all the 197s and Mk4 sets in service, TfW could retain them (at least the ones that still work) for West Wales locals and Heart of Wales, allowing them to get rid of all of their 150 and 153 units.
