Class 08
badassunicorn
8 Jul 2012
Firstly, I'd just like to say that I do have a soft spot for 08's, but really they are so outdated. Seeing out the flat end is fine, but going "forward" is a nightmare, having to switch sides constantly. It is loud, cold and uncomfortable to be in for any amount of time. Are there any loco's suitable for the work that 08's do that could realistically replace them? Something a little more crew friendly?
455driver
10 May 2010
So what do you propose the get around the bad view along the nose?
2 cabs? Well that would be brilliant having to change ends every 2 minutes!
A centre cab? not with that engine you cant!
The 08 does what it says on the tin and it does it well (and cheaply), it has done it for well over 50 years and there is no sign of a replacement any time soon so that probably says something!
#1 driver
2 May 2013
england , top right
I've just had a review of these last week !
To the OP , it makes a nice change to be able to stand up while driving .
If you're cold put a jacket on .
455driver
10 May 2010
Maybe they could look into doing a cab refurb on them to improve the heating, draught proofing etc but bearing in mind how often they are in and out of store which ones would you do?
badassunicorn
8 Jul 2012
I'm not proposing anything, thats not my job. I'm just thinking surely in this day and age there must be a solution to increase vision/safety and driver comfort? Don't get me wrong they are fantastic work horses but as you say, they are 50 years old and surely modern engineering can come up with a better alternative?
DownSouth
10 Dec 2011
I can't imagine the BCR of replacement being >1 if they are indeed fantastic workhorses which get the job done as is.
Radio-controlled shunters are used in a number of nations on the European Mainland, but rail carries a far greater share of all freight in those nations, while Britain's freight network has been pared back to small numbers of just unit trains which need minimal marshalling operations.
455driver
10 May 2010
But why spend millions designing and building replacement locos when the 08s are perfectly adequate, if it aint broke dont fix it!
bronzeonion
1 Apr 2009
West London
Sorry to sound like a bit of a smartarse but when driving a shunt loco isn't leaning out the side the done thing rather than just looking down the nose out of those tiny windows?
david_VI
18 Jul 2008
You at Ilford or Crown Point badassunicorn?
I would guess the novelty of an 08 trundling along wears off quickly. I also have a soft spot for them since I was a child.. :)
455driver
10 May 2010
Thats only if somebody points a camera at you! ;)
badassunicorn
8 Jul 2012
Ilford.
Leaning out the window doesn't help much when pushing a 4/8 car unit along through a windy yard filled with other unit movements going on.
bigdelboy
9 Apr 2012
mid/offset CAB designs may have visibilty issues in both directions.
Classes 07 and 14 could arguably be 08 replacements in some circumstances
Perhaps a Eurounnnel could be considered the modern replacement ... though it is a far bigger beast in the 'type 1' power range.
ExRes
16 Dec 2012
Back in Sussex
Why the problem with looking out the window ?, don't shunters, or whatever they're called nowadays, still exist. All we ever needed was a shunter and a radio, job done, safely
As for being cold, that's what the hotplate was there for ........
bronzeonion
1 Apr 2009
West London
Practical thinking there, show offs can lean out and the shy ones can stay inside when a camera is pointed at them!
Ilford.
Surely you have a shunter on the ground with a radio telling you what to do? Can understand if it's more re-assuring to actually see where you going though...
badassunicorn
8 Jul 2012
yeah of course we do have somebody on the ground but as you say, it is reassuring to be able to see where you are going
61653 HTAFC
18 Dec 2012
If the visibility when going nose-first is an issue, wouldn't it be cheaper to fit a camera to the front which displayed on a small LCD display in the cab, rather than building a whole new shunting loco?
D7666
12 Aug 2013
DBS ?
Think German.
Vossloh G6.
http://www.vossloh-locomotives.com/...ces/diesel-hydraulic_locomotives/g6/g6_1.html
This is a three axle (C) diesel hydraulic that can accept different engines (MTU, Cummins, CAT), different transmissions for 40 km/h shunting or 80 km/h trip work, and different weights.
ISTR when it was launched there was atalk about a diesel electric version (G6ME) but no takers or prototype yet.
Obviously this wouild need to be scaled down for GB load gauge. Vossloh do do small batch jobs so not a problem.
This is the other bit of Vossloh, the German bit ex-MaK, not the Spanish bit ex-Alsthom building the 68/88s.
Further, there is a rival model the Voith 5C, but there are none built yet.
There was also the UK Hunslet DH60C prototype. Is it still at DRIFT or long gone ?
Not sure what has happened to this project. I believe but no proof Hunslet may have started this project for the mainland European with a view to rival what is now the Vossloh G6 as the two projects started about the same time.
Nick
321446
15 Nov 2008
Southend Stations
Aah, my old friend 573!
I do take your points, but realistically the Railway & whoever runs ICS this week love saving money, and as others have said there are so many 08s about it's more cost effective to keep them going. At least it's warmer & drier in the draughty cab than doing the ground work on a frosty or moist night!
Give her a pat from me. I still look out for her when I pass by!
matchmaker
8 Mar 2009
Central Scotland
Having been in the cab of a Clayton which was shunting the British Aluminium sidings at Burntisland I can confirm that a centre cab loco has visibility issues in either direction!
WestCountry
31 Dec 2010
Cambridge, UK
Hunslet's DH60C looks like an ideal 08 replacement - slightly more HP and TE, with much better visibility. The demo is/was at Daventry.
RMWeb has a nice picture (not mine!).
bronzeonion
1 Apr 2009
West London
Wow that is very nice! Somebody just needs to rotate those light clusters to actually be upright rather than pointlessly angled!
GearJammer
12 Nov 2009
On the Southern
Thing is 08 shunters don't generally owe anyone anything, there paid for. A new shunting locomotive would have to earn its keep to pay off the cost of buying it and its very rare for a shunter to earn revenue.
Why spend hundreds of thousands... or millions of pounds on a new loco when an old one does the job!
