splashsquelch
- Joined
- 26 Aug 2013
- Messages
- 18
Hello Fare Gods,
I would like to minimise my fare for the following itinerary, and I have a Gold Card (from an unrelated route):
Fri 14th: Clapham Jct -> Bristol Temple Meads, departing around 09.45/10.00, breaking journey at Basingstoke for the day, then resuming my journey and arriving BRI at around 19.00 (flexible). This roughly means leaving BSK at 16.30 - 17.00ish. Via Reading or Salisbury is fine.
Sun 16th: Bristol Temple Meads -> Clapham Jct, after about 2pm. I don't much mind the route, although if the fares are similar then faster is better. If the outward route pins me via BSK, that's ok if necessary.
It appears there is a clever BSK-DID-BRI ticket split on the Friday evening, i.e via Reading, which is far (far) (far) cheaper than just buying BSK-BRI at the same time. If this can be sensibly combined with other tickets, it looks faster than BSK-SAL-BRI for maybe a small fare increment.
Any fare minimisation help would be much appreciated - the many options are making my head spin!
So far, my best guess is:
1. Gold Card open return CLJ - BSK
2. Gold Card single BSK - DID
3. Open return DID - BRI
4. Gold card single DID-BSK (and then return portion of #1).
But I think there are some single splits that might help between DID and BRI... and maybe I can avoid having to go back via BSK on 14th with only a minor fare increase (maybe an excess?) to allow me replace the DID-BSK option with a DID-CLJ, via RDG or PAD.
Actually, now I am thinking that this looks good:
Fri 14th
1. CLJ - BSK gold card single (after 9.45) : £12.55
2. BSK - DID gold card single around 17.00 : £5.80
3. DID - BRI open return £33.50
Sun 14th
(return portion of #3)
4. DID - CLJ via RDG/AP : £15.60 / 16.20
Total £67.45 / £68.05.
Whereas the option I mentioned above appears to come in at £64.55, but forces me back unnecessarily via BSK.
Fri 14th
Sun 14th
