Chorley (CRL) - Liverpool Lime St (LIV)
27 May 2009
Hi All.
Is going by Preston (PRE) permitted or would i have to change at Leyland (LEY)?.
Any info much appreciated.
bb21
Emeritus Moderator
4 Feb 2010
Chorley to Liverpool via Preston and Ormskirk is without a shadow of doubt a permitted route.
Chorley to Liverpool via Preston and Wigan/Warrington is not permitted due to doubling back at Leyland, however NRE may well give you an itinerary.
chorleyjeff
3 May 2013
Two changes via Ormskirk and quite a long time.
Easier to get the 109 or local Chorley bus to Balshaw Lane from the bus station across the road from the, dare I say it, train station. Or half an hour walk from the town centre to Balshaw Lane.
bb21
Emeritus Moderator
4 Feb 2010
That does not make the route invalid.
Of course rail may not always be the best mode. In some cases buses and coaches can be a much more convenient alternative.
kieron
22 Mar 2012
Connah's Quay
Three to Lime Street (can you still get from the Merseyrail platform there without going through the barriers?).
Having had a brief check on NRE, it appears that going via Preston is absolutely fine, even if both trains stop in Leyland.
The journey from Euxton is a lot quicker, if 57603 can get there easily enough.
57603
27 May 2009
Hi.
I live in central Chorley so Euxton would not be a problem, but i would prefer to go from Chorley, via Leyland. Going to be catching the 23:02 Liverpool Lime Street ( LIV) back to Euxton Balshaw lane (EBA) 23:59 on saturday then walking back to Chorley.
chorleyjeff
3 May 2013
How about via Bolton and Wigan? I don't have the mileage figure for Chorley to Liverpool via Preston/Ormskirk, or Leyland/Wigan or Bolton/Wigan.
As a matter of interest I once wanted to travel from LPool to Preston after lunchtIme. I turned up at Exchange only to be told I would get to Preston earlier if I went to Lime St and got the Wigan train and changed there then get the Blackburn train and change at Chorley for Preston rather than using the main line North from Liverpool. No bother about using the shortest journey at that time. Also shows how sparse the passenger service was outside peak hours on main lines in steam days.
