Chords vs Curves
CyrusWuff
20 May 2013
Down in London, the line between Reading Lane Junction and Navarino Road Junction is known as the Graham Road Curve, and in the West Midlands, the line linking the High Level route with the Trent Valley at Lichfield is known as the Lichfield Trent Valley Chord.
My question is this: What's the difference (if any) between a curve and a chord, and who decides as to whether a given section of line is named as such (and, in some cases, whether it's named at all)?
Busaholic
7 Jun 2014
Going 'In Search of the Lost Curve' might impart a different meaning to 'In Search of the Lost Chord'!
snowball
4 Mar 2013
I think we had a thread about this not long ago.
A chord is almost always a curve but a curve is not necessarily a chord. A curve could, for example be anywhere on a long, otherwise straight route with no junctions nearby.
In railway parlance a chord usually means a relatively short line connecting two other lines, so it will normally have junctions at both ends.
In geometry a chord is a straight line segment connecting two points on a circle or other curve.
Starmill
18 May 2012
Bolton
It always struck me as a bit odd that a chord apparently has the inverse meaning on a railway than in mathematics!
Maybe we should refer to it as the Ordsall Segment :lol:
Senex
1 Apr 2014
York
Nowadays yes, but that does seem to be a relatively recent development, replacing the older usage of "curve". Does anyone know when "chord" began to be used in this context?
Wouldn't the Ordsall segment be that area of land bordered by the chord and the railways it links :)
Gathursty
31 May 2011
Wigan
We have the Burscough Curves in Lancashire that are two chords no longer in existence but oft-discussed for re-introduction.
I also believe Morpeth curve is mentioned as a restrictive bend on the ECML.
Sunset route
27 Oct 2015
And south of the river on the old Southern region we call them Spurs, Sydenham Spur, Crystal Palace spur, Selhurst Spur, Lee spur, Brixton spur, Cambria spur, shepperton spur and Kew spur amongst many examples.
snowball
4 Mar 2013
But geometrically incorrect as it has a variable radius. The right word, I think, is locus.
To a mathematician, "arc" does not necessarily imply a circle. Any connected part of any curve is an arc.
A locus is a set of points satisfying some condition, so could mean almost anything.
Kew, Hounslow, Crayford, Sittingbourne and Cliftonville (but the Erith Loop at Barnehurst).
The only other Chord I can think of is Madeley, so is it a localised usage?
70014IronDuke
13 Jun 2015
Indeed. If anything it would be the Ordsall Arc.
Then, if you saw a train go round it, you could say: "Look, the Arc of a Driver."
(with apologies to the former leader of Traffic) . I'll get my coat.
QueensCurve
22 Dec 2014
Hazel Grove Chord (BR, LMR)
Cowlairs Chord (BR, ScR)
Allington Chord (NR, LNE)
Methinks there has been a change in use over recent years. A "curve" used to connect 2 sides of a triangle whereas this would now be referred to as a "chord". This does seem to have set in with Hazel Grove.
Personally I suggest "curve" is more apt since a "chord", as noted above, is not used in its's mathematical sense.
snowball
4 Mar 2013
In the recent thread some 19th century examples of "chords" were found.
QueensCurve
22 Dec 2014
The definitely were some, but I think - perhaps wrongly - they were different to the "curves" making up a triangular junction.
Andyjs247
1 Jan 2011
North Oxfordshire
Chord seems to be the current favourite. Other recently constructed lines include...
Bicester South West Chord
Doncaster North Chord
Nuneaton North Chord
But then I believe the new track at Ipswich is officially the Bacon Factory Curve (rather than Chord).
And then there is also Hitchin Flyover
So not really any consistent rule.
daikilo
2 Feb 2010
I think the explanation is that a "chord" is a connection between nearby locations on two different routes. It does not describe the actual shape of that connection which could be a "curve", a straight line or a combination of the two.
DarloRich
Fenny Stratford
will wiggly bit do? ;)
is the correct answer.
D Foster
5 Jan 2016
N Staffs
Railway usage - of all sorts of terms - is specific to the railway. Rather than conventional usage such as in maths. The key factor is that people using the term and (in this case) a location know what they are talking about - or, if not, that they stop and ask.
daikilo
2 Feb 2010
I think that true "railway usage" is actually respectful of maths qnd geometry, the issue is with the "artists" involved in public communications.
GB
16 Nov 2008
Somewhere
I think its the other way round. Officially Ipswich chord as per the Network Rail planning and government websites but known as bacon factory curve on the ground.
