Anyone heard back from the Moor street depot after completing the second further questions?
Nothing yet, thought we would have heard something by now
Not yet, when I applied before for a different TOC (2 years ago) I did this very second questionnaire in July and didn’t hear nothing till the November of the same year and that was for the assessment dayAnyone heard back from the Moor street depot after completing the second further questions?
Thank you very much for the advice and help. Sounds like it'll be a very long day if I do get to do all of it in one go but suppose it's all done and dusted then.
Think it’s a bit quiet across all the depots from Chiltern recently.
Thank you.The people dealing with recruitment are all very busy with myriad other things and the process is quite long and drawn out. Those who have completed the second questionnaire should hear something soon.
Appreciate the feedback. I don't mind waiting, I just wanted to check whether they had gone out or not. I know not all applicants will receive a response quickly or maybe not at all so wanted to ask. Thanks.Think it’s a bit quiet across all the depots from Chiltern recently.
Thank you, appreciate the update. I know what it’s like across the industry so I’m very patient.
Just received my VSE pass with Avanti. I assume this will be eligible with Chiltern
Interestingly, it won't be. You'll be required to resit the VSE, but as it's not an in-person assessment, a failure won't count towards your 'two goes'. Not that you'd fail if you passed with Avanti.
Chiltern only do the VSE as an additional assessment, as far as I'm aware, so you wouldn't need to worry about the M7, but, despite being exactly the same (albeit with different requirements for passing), you would have to do the VSE again. Strange but, it is what it is.
As I say though, doesn't count towards your attempts and passing it again will just be a formality.
Your Avanti VSE pass will be valid for Chiltern.
The VSE test would not have to be undertaken again, but if it was, and it was failed, that would count as a 'life lost' for Chiltern and any other operator that uses the VSE in its selection process.
That's very interesting. I sat and passed the VSE for Avanti in the middle of last year, and then was only required to sit the VSE for Chiltern during an application afterwards. I did question that with the OPC who told me to speak to Chiltern who said I'd have to do it again, which I was happy to.
I withdrew from Avanti as they use the CBI interview format and definitely couldn't afford to overwrite anything. I was told failing the VSE would not lose me a life as it wasn't an in-person assessment. Perhaps a case of different people being told different things or made to do things they don't necessarily need to do.
The online VSE test is only valid for six months, after which time it would need to be taken again. Maybe that is where the confusion is arising. Certainly people who have failed the online VSE during this round of recruitment for Chiltern have lost a life as far as the process is concerned.
That’s good news, thanks for clarifying, really appreciate it.
Did you say that Chiltern now only do the assessments to national standard?
National standard plus the VSE. (which you might class as enhanced, but does not mean a required higher pass mark or any further additional tests above the national standard, if you see what I mean).
Thank you, really appreciate the insight. That’s great news, so I could go straight through to the DMI then?
Avanti have withdrawn my application because I recently passed the MMI and they use CBI.
Would I be correct is saying that a VSE pass would only be valid if it was done within the last 6 months?If you have passed all the required OPC tests required by Chiltern, including the VSE that would seem to be a reasonable assumption, as long as you live within the required distance from your chosen depot.
And there it is! Thank you.If you care to scroll up, that's exactly what I wrote in post #435.
Nope, they don’tAnyone knows does GWR use VSE?
Anyone received any follow up from Marylebone yet? Apart from the initial 'more about you' questionnaire I'm still waiting... It would be good to know if anyone else has heard anything. I know rejections or follow up assessments have been sent for some of the other locations but it seems a little bit quiet for Marylebone. Thanks all.
I didn't realise there were two 'more about you' questionnaires. I've completed the first one however haven't received a follow up yet so I'm still staying positive. My Aylesbury application was turned down which was probably due to the distance (I think it was marginally outside of the 45 mins) but hopefully still being considered for Marylebone.Another Marylebone applicant here - just received a second 'more about you' email yesterday arvo.
Am assuming it is an SJT type questionnaire that others have mentioned. Will get onto it later today.
