xotGD
- Joined
- 4 Feb 2017
- Messages
- 7,865
The Mk 4s weren’t built by BREL, so not sure what your point is?Same here, just the last leg to Stourbridge Junction so no experience of high-speed running (and I felt a right prawn being the only person to remain on the platform for the Kidderminster train). And by the way, I for one am reluctant to call them Mk5s - they weren't built by BREL or its predecessors and have a completely different lineage.
Indeed, but one thing I did notice is that the first class passengers get the thrash!There's a 68 on the front.
(Or back)
I was under the impression that the Mark number was just a way of displaying difference between passenger carrying stock in a similar sort of way you would with a Mk1 and Mk2 Golf (for example)The Mk 4s weren’t built by BREL, so not sure what your point is?
Good point, they were assembled by Metro-Cammell according to Wikipedia but BREL did build some of the bodyshells, which keeps them 'in the family', so to speak.The Mk 4s weren’t built by BREL, so not sure what your point is?
I was surprised by those as well, as the other CAFs don't have them. I assume it's because they rehashed the Mk 5 sleeper carriage design?Vent grilles in window ledges. Er, OK...
I had my first ride on the Chiltern Mk5 today in standard class. The biggest gripe I had was the seat window alignment, which in common with a lot a new trains is poor. This is quite a big let down compared to the class 168 trains which have perfect seat window alignment.Had my first ride in a Mk5 yesterday, and while I've previously been in the CAF 331 and 397, the poor quality (and loudness) of the ride was still a shock, especially as unlike those trains which were running on lines I'm not familiar with, yesterday was on a line I use regularly, so I'm used to how the 165 and 168s cope.
D Exam. Due back this week.Is 68018 still at Leicester? Any one know whats happening with it. I immagine exhaust reduction work similar to the rest of the Chiltern Fleet.
Thanks.D Exam. Due back this week.
No - but they were all built to the same basic jig.I was under the impression that the Mark number was just a way of displaying difference between passenger carrying stock in a similar sort of way you would with a Mk1 and Mk2 Golf (for example)
It should also be noted that not all Mark 1s were built by BREL either.
68026, not 68028 which is still at Wembley.Tuesday morning update
68028 MBDL EGHT RSMD 865Q691F07 V * BANBURY N
Coaches
11506 12716 12717 12718 12806
Dan
Yeah; I found it a pleasant, comfortable experience but I've not had the chance to do it enough times to say it's significantly better for sure. Sadly on a 168 as I write this post!Has anyone tried the first class seats on these?
I'm planning on travelling back from London on the 19.32 on Saturday and will probably give it a try.Yeah; I found it a pleasant, comfortable experience but I've not had the chance to do it enough times to say it's significantly better for sure. Sadly on a 168 as I write this post!
Yes, there was a TOPS error initially yesterday morning.68026, not 68028 which is still at Wembley.
028 on set 7Anyone know which locos are attached to which sets please. RTT is only showing the Set number on some sets. Today CH07 is out, with no loco showing, while CH05 is out showing 68020.
Thanks in advance
I’m the exact opposite, I found the head rest in first class very uncomfortable - so much I so I moved out before departure from Marylebone and into Standard which was a bit better.Yeah; I found it a pleasant, comfortable experience but I've not had the chance to do it enough times to say it's significantly better for sure. Sadly on a 168 as I write this post!
I believe 029 is at Banbury, it ran light to Marylebone and back on the 9thLast Known Location Chiltern 68 & Sets
019 Set 8 (24th March) Eastleigh 5Q86
020 Set 5 (11th April) in service, Stourbridge
022 Set 12 (31st March) Stourbridge 1J47
024 Set 3 (10th April) 3Q72 ?
026 Set 6 (9th April) Eastleigh 5Q86
027 Set 4 (27th March) Wembley 1H77
029 Set 2 (10th April) Stourbridge 1J55
030 Set 10 (10th April) Wembley 3Q90
031 Set 7 (10th April) Wembley loco change
032 Set 13 (7th April) Banbury 1H25 failed
028, (11th April) Wembley - Leicester 0M99
Missing locos
021, Loughborough (25th March)
023, Crewe GB (12th March)
025, Eastleigh (16th March)
Missing sets
1, Long Marston (17th Feb)
9, Long Marston ?
11, Long Marston ?
Dates in ( ) last reported as seen.
Please update or correct,
Thanks
