Chiltern Mk5s: could Chiltern order Class 88 locos and/or Mk5 buffet vehicles?
FrontSideBus
11 Feb 2025
Moderator note: Split from
Could they whack 88's on for running under wires?
HJ10001
3 Dec 2024
Do you think that Chiltern might order MK5 buffet coaches? As the MK3 sets have a buffet/shop coach and the original TransPennine Express coaches don't have a shop.
43096
23 Nov 2015
No chance.
stevieinselby
6 Jan 2013
Selby
As there is currently no plan for electrification of the Chiltern line, 88s wouldn't get very far! More likely that they would go for 99s, as this would allow them to make use of staged electrification as and when it comes on stream, as it is likely it would take several years from the first section being ready to go live to the full route being done.
BerkshireRails
4 Apr 2021
United Kingdom
I think the 100mph 99s would be a better fit to Chiltern as they are a Co-Co rather than a Bo-Bo. The 99s have a more powerful design than the 88s which would allow them to work unelectrified sections with reasonable timings which a class 88 would be unable to do.
22 Jan 2024
They abandoned use of those on the Mk3s a few years back when all catering was removed from Chiltern services. They therefore have no use for a buffet in the MK5a sets.
Its all rather moot at the moment as the Chiltern isn't going to see wires in the next 10-15 years.
2001olib
5 Jun 2025
East mids
If/when bi modes become viable for chiltern wouldnt modified class 93's be more suitable than 88's due to their better diesel performance. Not forgetting their additional batteries
43096
23 Nov 2015
Those 93s with their miracle capabilities away from the wires make another appearance! They’d be about as much use an asthmatic ant with heavy shopping for Chiltern away from the wires.
22 Jan 2024
There aren't enough of them, and by the time Chiltern gets wired (if it ever happens) they will be old technology so Stadler won't be building any more. Plus they aren't powerful enough on diesel other than possibly for short distances off the wires.
BerkshireRails
4 Apr 2021
United Kingdom
I see the 99s being built in massive orders to replace the 66s and there 2400hp diesel engine while not as powerful as a 68s 3000hp diesel engine it is still more than capable for the Chilterns, as it would allow for the higher speed sections to be done first.
Harlequinuk
15 May 2025
From what ive seen, the 93 on diesel is basically a CLass 25 power wise, and add the batteries (which can recharge when coasting), makes it a Class 33. Thats plenty of power, as one climbed shap with 1800 tons .
22 Jan 2024
They also have to supply ETS to the train, which will use a fair bit of the available power.
Belfastmarty
14 Oct 2020
Belfast
Were those tests up Shap in diesel or electric mode? I was under the impression the latter, but happy to be corrected. In hybrid mode the 93s produce 1700 hp (for 10 mins until the battery is exhausted), then 1200hp on pure diesel. Both of which are a substantial downgrade on the 68's 3800hp. And as @Yorkshire09876 says thay have to supply ETS as well.
BerkshireRails
4 Apr 2021
United Kingdom
Green Signals made a video about the 93s which said the 10 minute run time for the battery isn't true, based on my interpretation of the video.
