Chiltern loco hauled services on RTT
MichaelAMW
18 Jun 2010
The timing load has nothing to do with what is actually booked for that service.
Surely that's not true. Whilst I appreciate your point that the type of rolling stock used is not necessarily (ever) that indicated by the timing load, the two *are* strongly related because the class of train used needs to be able to keep to the timings.
Class168s can and do substitute for locomotive hauled services on Chiltern. In very limited cases the opposite is true. Seems a very good reason to have a common timing load that both can keep to.
DarloRich
Fenny Stratford
True... but why is it labelled as a Sprinter when Chiltern have never had them?
because that is simply the way the system churns out the information and it isnt worth the time and money to rectify an insignificant little problem that has little impact on the traveling public.
PHILIPE
14 Nov 2011
Caerphilly
Trains can be worked by any loco/unit that can maintain the timings of the timing load. It could be that timing for the LHCS locos have never found their way into the system.
Shaw S Hunter
21 Apr 2016
Over The Hill
They aren't.
That's just how the timing load appears on Realtimetrains.
You are reading too much into it; see the post by D6700 (who is an experienced train planner) in the hyperlink above.
It would be useful if that post could be made a sticky. It also explains one or two things that I didn't quite understand when I actually worked trains especially as regards timings over diversionary routes.
Freightmaster
Verified Rep
7 Jul 2009
Particularly the bit where he says:
I am pleased to see these officially approved open online systems,
but do feel that many of the questions arising are simply due to people
over-analysing things that don't really need to be analysed!
That was back in 2013, but four years on, many people still seem to be
convinced that the 'timing load' on RTT is a direct and infallible indication
of the type of train that a particular service is booked to be worked by!
MARK
