merlodlliw
http://www.nwrail.org.uk/nwnews.htm scroll down for the item
Wonder how many other Stations have this type of board.
M
M
M
Crewe has one "158 miles toLondon"
It isn't there any more, and neither is the "Carlisle 102" Caledonian Railway milepost that was fixed directly under it.Glasgow Central bridge has a small sign proudly proclaiming the mileage to Carlisle.
There's also this brickwork on the Southbound platform at Lichfield Trent Valley www.mumrar.fotopic.net/p36468280.html
Unless you're on a stopper you're even less likely to see it since the linespeed increase.That is a nice piece of work, I note its date 1987, yet sadly having travelled
to London many,many times, I don't recall seeing it, the only things that used to stick out on the London run were
1.The concrete cows at M K
2.The Ovaltine clock at Hemel H.
I travelled on FNW a few times to Euston, not sure if Lichfield was a stop, but the train did stop in the trent valley
used to catch this train at Sandbach as VT had a Non COMPI on Crewe for any other TOC doing an express run to
London, FNW used Stanstead Airport Express stock EMUs, without ever taking the name off, Man Airport to Euston
via Sandbach for £20 return.Sadly but not surprising, VT started a £10 pre book fare with very heavy advertising
recall the ads at Euston which in the end killed off the rival to London. FNW always used platforms 1 & 2 at Euston.
Sorry I am off the original thread.
And of course don't forget the famous "Euston Station 1 Mile" sign.
I never recall seeing it, is the worlds biggest jig saw still on the walkway
connecting all the platforms at Crewe.
It's on the side of the old box London end
