Hi all looking for a cheap day return to Brum from Liverpool. Must travel peak - at around 8-30am. Only able to find single advance fares at £5-95. I have a railcard. Ta.
'Cheap Day Return' (CDR) was the old name for Off Peak Day Return, which retains the
CDR code to this day. CDR tickets may have existed for this journey a long, long time ago however since around the late 1980s (ish) only period returns have been available, which are valid for return within 1 month.
There are also not many CDR tickets that are valid as early as 0830, and it is unlikely that many -
if any - such tickets would be valid from Liverpool this early, though the exact validity does depend on the ticket in question.
CDR tickets are cheaper, so the solution, if you want flexibility, is to "split" the journey into a "combination of tickets", this means you can get the cheaper CDR tickets for portions of the journey that, when combined, cover you for the entire journey.
A CDR from Liverpool to Crewe is valid from 0900, so this would not be valid and an SDR would be required instead, costing £13.20. Crewe-Stafford has no CDR fares and an SDR for that is £10.20. Stafford-Birmingham is £9.10 for a CDR, valid from 0900 but you cannot depart Birmingham between 1635 and 1800 on that ticket.
Other than that explanation, I can't really add much to the advice that has already been posted.
