Chatham to Stratford Int rte Plus High Speed
crazyjimmy
22 Jun 2013
Hi all
Just a quick question - am I right in thinking that a season ticket from Chatham to Stratford International route Plus High Speed also has validity to central London via the traditional main lines (as that would be the "non high speed" route)?
Sorry - I'm sure this subject has been covered before but I can't see it!
Thanks in advance
Jimmy
maniacmartin
Fares Advisor
15 May 2012
Croydon
The ticket doesn't have a maltese cross, so it is not intended to be used on the classic lines with onward travel on LU/DLR.
Today's Routeing Guide has Chatham Routeing Group to Stratford Routeing Group on page 299:
Maps LONDON or HK. Map HK is the direct HS1 route.
LONDON expands to (FA FB FC FH FL FN FT FV HK ) + (LI HS)
The National Routeing Guide instructions say:
NRG said:
In some instances (particularly long distance cross country journeys) the fares data will show an "any permitted" fare but without the via London, Maltese cross symbol. Reference to Section C (the “yellow pages”) may show via London to be a permitted route for this journey and in such instances travel via London to include cross-London transfer would be permitted.
However, in practice you will most likely be refused entry to London Underground with that ticket, despite what the routeing guide instructions say. Using FA+HS you can trace a route via Elephant & Castle and the Thameslink Core, changing at St Pancras onto HS1 to Stratford International. This requires no arguing over the missing Maltese Cross and no cross-station transfers. Thus, this is a permitted route.
Most reasonable routes into south London Terminals are mapped. Using the mapped route from Liverpool Street and Stratford London (the non-High Speed Stratford) is a bit of a grey area, as sometimes ATOC claim that permitted routes cannot start of end with a walk, and you can't use the DLR to Stratford International as far as I'm aware (TfL claim that a National Rail route cannot start or end with a cross-London transfer). That does not mean you not get hassle at gatelines.
If you want a less problematic ticket available by both routes, consider researching the permitted routes of Chatham to Stratford London (non-HS) +ANY PERMITTED ticket that has a similar price, but comes with a maltese cross, meaning that LU/DLR will accept it.
I'm not sure if seasons are supposed to be available with maltese crosses on any more, so it's possible that it will be withdrawn from sale at some point, leaving only outboundary Travelcards for HS1 travel, especially now that this has been posted on a public forum.
crazyjimmy
22 Jun 2013
Wow what a comprehensive response. Thank you for taking the time to put this together.
In reality it would be Bromley South that would be my only frequent alternative destination, which does appear to be valid; getting through the gate line may still present a challenge though as you highlight!
Thanks again
Jimmy
