Changes to SE metro services next June
ComUtoR
13 Dec 2013
Youve had a different experience to Thameslink than most I’ve met, most people hate it, and wish for the old Gillingham semi fasts to return, which I must say in light of the EL at Abbey Wood, would be handy, I can’t imagine the all stations Thameslink service being as popular as the old Gillingham semi fasts.
We often disagree about the Thameslinks but you do have a point about the Gilly semi fasts. My problem with those was always that they were too exclusive. If you benefitted from a semi; I can see why you would want them back.
In Metroland, the goal is to shovel passengers into and out of London. Turn up and go services and swallow up passenger loads to reduce overcrowding during the peaks.
I would say that a turn up and go service isn't about faster journey times. Nobody really cares. Commuters time their journeys for the daily grind and the leisure folks just want to get where they are going without making an effort.
Even the Sidcup 'semi fasts' don't really sit with the 'Metro' ethos. They tend to run based on minimal service requirements and operationally to get units back in town to run peak services.
PGAT
13 Apr 2022
Selhurst
I agree but the Thameslink doesn’t do a good job at providing a turn-up-and-go service.
ComUtoR
13 Dec 2013
I had quite a long journey in a 465 from Charing Cross - Tunbridge Wells 2 months ago, and found it quite comfortable. It certainly did not seem like a rust bucket to me.
I like new and shiny. Networkers are workhorses but have had their day and should be consigned to history.
It was probably more comfortable than the return journey in a 375, although the return train was busier. I don't get why the 365s are fawned over and the 465s/466s are disliked on this forum, when they are almost the same train.
Never been on a 365 and I don't have an enthusiasts perspective. SE stock has been kicked down the road too often and the 707 cast offs felt like a backhander rather than meeting the needs of SE
I hope TFL dont take over the Southeastern Metro
Again, I genuinely don't think the everyday passenger cares what livery is on the train or who's name is on their ticket. If TL took over and run identical routes or, keeping on topic, reinstated the semi fasts. I'm not sure we'd be having this discussion.
The 365s were better cared for and had a serious refurbishment. Southeastern have done pretty much nothing to the 465/466s except fit retention toilets (and l'm not sure that was done to all of them).
Retractioning. (Hitachi Motors) numerous Mods and "upgrades" PRM upgrades, quick 'refreshes'.
They have done some bits
In isolation, no.
I was convinced by "Richard without hair" that hitting London Bridge and changing was going to be the new normal. If you switch your mindset a little; it sorta works.
The Railway isn't perfect. Less changes for me is the default. A-B and plan accordingly.
Again, maybe I'm strange that I just look at my options and then make a plan. Get there early, have a backup option and not stress or care about the other service that gets me there 2 minutes before if I make 3 different connections :/
I had quite a long journey in a 465 from Charing Cross - Tunbridge Wells 2 months ago, and found it quite comfortable. It certainly did not seem like a rust bucket to me. It was probably more comfortable than the return journey in a 375, although the return train was busier. I don't get why the 365s are fawned over and the 465s/466s are disliked on this forum, when they are almost the same train.
On the point about 365s, they had a refined interior design from the start, weren’t subject to the level of abuse the 465s have had in terms of vandalism, and were better looked after. The SE Networkers have been somewhat left to rot, and it shows.
Blindtraveler
28 Feb 2011
If Thameslink were faster on both sides of the river it would be attractive but it calls at way too many stations for it to ever be useful
I was going to write something near enough identical to this. A faster train to abbey wood that isn't operated by Thameslink and isn't a third class cattle wagon that masquerades as a UK passenger train is very much desired, I'm in Chatham and use the Lizzie a lot although have altered my habits a bit since the summer due to plunging reliability.
I await any potential changes to Thames link services with interest, not that I'm expecting improvements but if there's going to be theoretically less trained on that section of root then we might have a few less problems with reliability particularly passing through a Dartford
southern442
20 May 2013
Just a more even service via Woolwich would be very much welcome. With regards to thameslink vs liz line, the fact that we have some people on here strongly preferring the direct service and others advocating for the quicker one with a change is a sign of healthy transport flow - ideally we want both at capacity!
ComUtoR
13 Dec 2013
As you are Chatham way. Why not HS1 as your alternative ?
I'd happily dig up the A2 and extend the Elizabeth Line for you...
Blindtraveler
28 Feb 2011
Only just become a viable option again in my view in terms of cost, the restrictive one tph outside of the peaks and pretty much all day Saturday until the December TT change made it bad value for money, furthermore I like the range of connecting destinations available via the Lizzie without necessarily having to change in zone 1
richa2002
8 Jun 2005
I don't know the details but I wouldn't be surprised if at least some element of pre-election sweeteners is involved: that tweet coming from the local Tory MP already shows some of that at play, and all the constituencies on the south-east edge of London and NW Kent are Tory held.
I'm always amazed at the idea of an increased rail service being significant enough to sway a voter...!
ComUtoR
13 Dec 2013
Cheers, that makes sense.
I'm only just dipping my toe into the Lizzy but those connections are interesting. I met a friend who came up from Reading the other month. That was pretty cool. Also, when I have travelled, plenty of folks with suitcases.
NorthKent1989
13 May 2017
With the Rainham Thameslink service I don’t see any substantial changes unfortunately, it’ll either stay as it is or revert back to a SE service, in the 90s it was possible to reach Abbey Wood from Rochester inside of 30 minutes, with stops only at Strood, Higham, Gravesend and Dartford, as I’ve said before this would be so handy now.
This is true, the last big Networker refurb was in the 2000s and even then it wasn’t nearly as extensive enough.
markyl
24 May 2014
Having a look at Orpington Services to London Bridge on Sundays from June
Daytime departures
Orpington XX08 & XX38 Slow & XX08 & XX38 Fast
Why not space these departures 15 minutes apart ?
An unnecessary 30 Min perceived gap
30907
Daytime departures
If you did that, the stopper would be overtaken at Lewisham by the fast, and there would be complaints. As it is they are about 15min apart at LBG both ways.
There may be a complicated timetabling reason, or (my unwarranted suspicion of) a lobby from Chelsfield etc for a connection into the fast at Orpington. Or possibly a connection out of the Ashford service at Sevenoaks (not yet uploaded BTW).
markyl
24 May 2014
Or at least leave it as it is now ...
Orpington XX21 & XX51 Slow & XX12 & XX42 Fast
N/100
9 Jan 2016
The Victoria services will be at XX20 and XX 50, so (1) in terms of bridging the gap that's job done and (2) the slow CHX couldn't run as now .
Stephen42
6 Aug 2020
Whyever not?
They use the same tracks so would need to be 3 minutes apart. The current arrangement isn't great, while they may be 15 minutes apart at Orpington they arrive at London Bridge 6 minutes apart. The opposite direction the fast overtakes the slow so it is a 30 minute gap anyway.
The new arrangement has connections from the slow to fast at Orpington for those between Chelsfield and Dunton Green to have a faster London journey with a change in both directions. It also avoids some performance risks with the slow trains having a longer reoccupation time than the current 3 minutes at Sevenoaks and not immediately following the Hastings service to London which may get delayed on the single track sections.
Class15
30 Dec 2021
North London or Mildmay line
The timetable on the Greenwich line is quite shocking. As someone who regularly uses Thameslink between Greenwich and North London, there is a Thameslink train that is normally perfectly timed for me to take from Greenwich. However, if I miss that train due to delays leaving or other factors, it’s then a 23-minute wait until the next SouthEastern service. I believe it’s better beyond Charlton as Blackheath services join on there. But it’s really annoying how a 4tph service is so unevenly spaced.
Horizon22
Jobs & Careers
8 Sep 2019
Much more even from June, as discussed above.
ScotGG
3 Apr 2013
Though only temp isn't it due to Blackheath tunnel closure? From August trains per hour are back down again and while spacings are slightly improved it's still far from what it was before cuts
nw1
9 Aug 2013
Not Metro but Southeastern seems to be taking a much more positive attitude to re-growing the peak than, say, SWR.
From their improvements page:
Trains have been better spaced and run every 15 minutes towards London Bridge from stations between Pluckley and Paddock Wood during the busiest times of the morning, arriving in London between 0711 and 0842.
There are 2 extra trains from Ashford to Charing Cross to provide more space during the busiest times in the morning, arriving at Charing Cross at 0802 and 0832.
and
An extra 2 services will run from Charing Cross to Ashford via Maidstone East at 1659 and 1759, giving a half hourly service from 1629 until 1829 between Charing Cross and Maidstone East line stations.
This will also mean that customers can travel direct from Charing Cross to Bearsted, Hollingbourne, Harrietsham, Lenham and Charing during this time.
An extra 3 services will run from Tunbridge Wells to Charing Cross on weekdays between 0900 and 1030, calling at High Brooms, Tonbridge, Hildenborough, Sevenoaks, and Orpington and an extra service from Charing Cross will run to Hastings arriving at 0829.
Departures from Tunbridge Wells are better spaced during the busiest times in the morning between 0709 and 0820 from Tunbridge Wells towards London helping to create more space.
Nice to see some positive improvements for a change.
Blindtraveler
28 Feb 2011
Really positive indeed, I think they have seen the value of commuter services being put back and made usable, as someone who frequently uses the evening canon Street cruises two and from the Medway towns and onwards to the coast it is plain that whilst not as many people are going into the office every day, across the week the numbers justify the level of Service being offered
Class15
30 Dec 2021
Stephen42
6 Aug 2020
Thanks. Seems like a good improvement, even if 6tph is temporary.
In the morning peak, there's an hour of 6tph perfectly spaced. On that link it's only the Dartford to Cannon Street trains that will be removed once the engineering works are over which run 3 minutes apart from other trains.
Outside the peak it's 12/18 minute spacing at Greenwich and varies a little across the route due to differing stopping patterns.
The North Kent summer specials are returning this year, with 2 return trips from Cannon St-Ramsgate on Saturdays from early June, and 1 return trip on Sundays during the school holidays. There is no weekday service, which used to exist in the form of 1 outbound only trip in the morning (as the stock would have been needed in the peak back in the metro area).
NorthKent1989
13 May 2017
I take it it’ll run via Greenwich as Blackheath Tunnel will be closed in this period right?
The Victoria to Ramsgate via Woolwich special last year was a good service, I don’t know why they can’t run Victoria trains to the Woolwich line regularly if Charing Cross is full, better than all Cannon Street trains.
nw1
9 Aug 2013
Perhaps surprising there aren't any weekday services as theoretically you could have something departing London around 0900 and arriving back around 1800 which could then form a later peak service. Perhaps the return would be too early though.
Just checked what they did in the 80s and the outbound services left Charing Cross at 1005 and 1105 but the returns arrived after 1900; obviously they had more stock going spare in those days. All formed of seasonal extensions of the Gillingham semi-fasts.
SolomonSouth
25 Feb 2021
Gravesend
I believe there still is a Gillingham semi-fast in the rush hour.
NorthKent1989
13 May 2017
This was pretty much the case until 2017, after which from 2018 to 2022 it was an extension of the Greenwich stopper, last year it was an extended version of the Cannon Street to Dartford service but fast from London Bridge to Lewisham, then there was the Victoria service which was similar to the old CX-Gillingham service but with Plumstead and Slade Green added as stops
I'm pretty sure when it's been Cannon St/London Bridge, which has been the majority of cases, it's run via Greenwich.
