Ladder23
- Joined
- 29 Oct 2015
- Messages
- 1,880
As above guys, what's the chances of this happening, is there any on going debates or is it a no go.
It was served by trains to Moorgate from both the Midland Main Line and Great Northern routes.What I would like to know is what was the history behind the station prior to it's reopening as a Thameslink station in the 1980s ? It certainly wasn't an entirely new station as far as I could tell.
Two - quicker connection to Tube lines at KXSP.It did have one positive over its replacement though, the ability for wait for a train without being subject to awful squeal from the train wheels
It wasn't that quick to connect with the tube lines except the Victoria line. The long subway was crowded in the peaks and as the only off-street route, it would often get very slow. The new station complex has two main routes to the underground, - 1) via the Met/Circle station which although involves a walk of about 1/2 the length of a Eurostar train (c. 200m), it is dead straight, there's no 'weaving'and it isn't always crowded, and 2) via the new northern booking hall which with many escalators, has fairly free running passageways to Northern and Piccadilly line platforms. For those in the know, there is also the shortcut to the Victoria.Two - quicker connection to Tube lines at KXSP.
Currently you have to walk through a maze of shops and fight your way through arriving Eurostar passengers working out where to go next.
Agreed - but it won't happen unfortunately!A new station at Mount Pleasant, at least on the Met & Circle lines would be more useful.
They were quite hazardous in busy times as passengers passing down them had to walk well over the yellow line.St Pancras Thameslink was built not for better interchange, but because it was possible there to build a station with long, wide platforms. Not only are the old platforms at Kings Cross TL too short with no easy way to lengthen them, they're not that wide- not ideal for handling the modern (and the proposed) timetable.
Not really, it's just 1 mile 27ch. Bear in mind, the speeds run are quite low (50mph?).I've often thought that given the stretch between Kings Cross and Farringdon is quite a long one without a station.
If using the Pentonville Road entrance (does that still open), would you be able to see down the old corridor to the Thameslink platform or does the tube entrance go straight past it?
Yes - the Pentonville Rd station entrance is still there for Underground access (though only really worth it for the Vic now; but much the quickest to and from the Vic if your origin/destination is in that bit of the KX area, or Angel-wards from KX), but it closes late evening and weekends (annoyingly for those of us for whom it's really useful). It does seem to get quite a bit of rush-hour use, but much less at some other times However, the escalator up to the entrance hall and ticket gates from the passageway to/from the Vic platforms has been out of action since some time in 2018(!); LT seem not to care and say it's NR's problem, even though it's only LT passengers using it these days.
As for your question - getting there! - the half landing on the flight of stairs has a locked door where there used to be access to the southbound platform, with a pane of glass you can look through. The overbridge from the upper level and the underpassage from the lower level (both ways to get to the northbound) are of course locked off.
There are only machines there now, but when it was used by T/L as well as LT, some NR tickets were available (though perhaps they were actually LT ticket staff selling them?). And there was a happy era when you could buy there a CDR NR ticket KX to Finsbury Park, which was cheaper than two Underground singles (LT having stopped CDRs by then); and because of the historic interavailability of KX-FP tickets as between LT and NR, you could then use it to dive on the Vic line from there (though the ticket office staff would often try to tell me that since they'd sold me a NR ticket, I had to trot along to KX mainline for my trip to FP). [This was post-KX Suburban trains - which would have gone to FP - using that station to and from Moorgate, of course, since they disappeared as part of the revamping of the route to turn it from a rush-hour extension of the BedPan route into the first stage of the T/L line we know today.] This CDR ruse saved me a few bob over the years, since my work often took me up and down on the tube from an office at KX to an office by FP station.
Thank you!! I’m in London next week so I’m hoping to take a quick glance at it, should I be able to get a look to the passage leading to the southbound platform?
No chance. The platforms are too narrow and short, both of which are nearly impossible to rectify, and it’s too far away from anything to be much use. Even 25 years ago it was hopelessly inadequate for the demands placed upon it.
It did have one positive over its replacement though, the ability for wait for a train without being subject to awful squeal from the train wheels!
As a random aside, I remember using the place on a regular basis in the 1990s, it had the rudest booking-office staff I’ve ever encountered.
Plus the street walk from KXTLK to the main terminii - before the area was "gentrified" was just not urban edgy , but quite dangerous. Especially at the height of "Crack Camden" , the cash point outside the old entrance had one of the highest robbery rates in the city. Delighted when it closed. Awful station back in the day. SPX is vastly better in all respects.
It's interesting how so many visitors found the area dangerous; many of us who've been in the area for decades discovered - when the seeming threat on the streets was at its worst - that there were pretty much two parallel worlds going on. I didn't bother them and they didn't bother me. And before anyone cheers on the gentrification, it must be remembered that a main reason for about two decades of the dereliction was precisely the unfulfilled promise/threat of "development" hanging over the area. If the local community's plans had been put into effect - which of course they mostly weren't because of the power of money - the developments around KX would have been sooner and more positive (ie, not tidying it up by booting lots of the ordinary people out).
If I remember correctly, looking through the little pane of glass on the half-landing means you're looking more or less onto the S/B platform. I might not have a chance to look on Friday (and anyway will be on my bike and not using a tube ticket), and it's closed at weekends (including from the Vic platforms end of course), but if I get a chance, and remember, I'll confirm whether my memory is right by having a look asap after the weekend - and update on here.
It is true that you could just walk by and ignore the "street activity" , and I suppose I never came to any harm in walking through it for 20 years or so at various times of day and night. So while one welcomes the overall "street" improvements , I agree that "gentrification" has probably gone to the opposite , not just "improving" the area , but making it utterly unaffordable for many long standing and decent residents. There ought to be a balance and I suspect it has gone way wrong.
