Cathedrals Express 07/03/15
gavinro
7 Mar 2015
What happened to it on the return leg? Lost over 100 minutes between Wootton Bassett and Reading (mostly near Swindon, it seems).
theironroad
21 Nov 2014
Probably best not to speculate as a cat a spads and any other cat spad have vastly differing consequences for the driver.
fgwtt1988
27 Apr 2007
Yeovil, Somerset
Confirmed as a Cat A SPAD pending investigation of course. It was the signal protecting Wootton Bassett Jnc so could have been a lot worse!
fgwtt1988
27 Apr 2007
Yeovil, Somerset
It was 34067 Tangmere hauling the train. It was confirmed by a notice I received at work. Obviously after the investigation it may turn out not to be the drivers fault at all but initially they're saying Cat A.
GB
16 Nov 2008
Somewhere
Treated as a cat A rather confirmed as a cat A might be more accurate.
HarleyDavidson
23 Aug 2014
Well said. This sort of thing should not be up for discussion on a public forum, because of the potentially damaging consequences that incorrect reporting can cause.
And as talltim has also correctly said: "Confirmed by who"... No one has officially confirmed it.
I agree it would be best to avoid speculating further until there is some sort of confirmation of what exactly happened.
Temple Meads
2 Sep 2010
Devon
Nope, that is just the usual testing of signals if the Crew disputed the circumstances leading up to the SPAD.
Think we should wait and see.
I agree, which is why I said "thought to be the signal", rather than "the signal is at fault and there's no way it was the driver"......
E&W Lucas
21 Jan 2010
If you're talking about a "SPAD Alert" type notice, they will have done a preliminary investigation before posting. You don't see notices coming out, then being followed by an "actually it was a defective signal". The basics can be established very quickly.
To put some context on it, I've just received a similar notice today, less than 24 hours after the incident concerned.
infobleep
27 Feb 2011
On a more general point, if a steam train is involved in a SPAD, where do they find another driver from to continue the service? It's not as if the country is overrun with mainline certified steam train drivers. I genuinely don't know how it works in such cases.
