Category A SPAD
dooton
18 Nov 2010
Just been reading through some of the data i'm collecting from Network Rails Open Data, noticed that there has been a "Category A SPAD" at victoria which is listed as affecting FGW services.
Without going into details about this specific incident what is a category A SPAD, i'm assuming its the most serious? Hopefully the driver in this instance is not too shaken.
Cheers
Matt!
Boodiggy
8 Nov 2012
Evening, usually a cat A is a driver error leading to a signal at danger being passed. Other spad's such as a cat B is where a signal is passed but the issue is with something on the infrastructure, such as a failed track circuit, loss of detection on points or a fault with a signal.
phil281
9 Mar 2011
Think I may have seen this today about 13:30. There was a 442 unit half through the last signal before the platforms on the UF.
Wath Yard
31 Dec 2011
It must have been one hell of a SPAD if it happened at Victoria and is affecting FGW services!
GB
16 Nov 2008
Somewhere
CAT A - Train passes signal at danger where preceding signals showing the correct restrictive aspects to allow train to come to a stop under normal conditions...can be due to driver error, rail head conditions, a fault with the train etc.
CAT B - Train passes signal at danger due to signal going back to red without warning. Can be caused by signaller error or signalling equipment failures.
CAT C - Train passes signal at danger that has been put back to red because of an emergency.
CAT D - Runaway train/vehicle passes signal at danger...can be classed as CAT A under some circumstances.
phil281
9 Mar 2011
The residual delays caused by the blockage of the UF might cause delays for the Gatwick - Reading trains, you'd be surprised how one incident far away can set off a domino like effect especially on a line with tight pathing like the BML
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Just for my personal curiosity... if a signal has been reset to danger because the emergency button on a GSM-R unit in the area has been activated, and the driver passes this due to lack of sufficient warning, would this be classed as a Cat C?
TP
GB
16 Nov 2008
Somewhere
If the driver had insufficient warning then yes, that would fall into "category C"
dooton
18 Nov 2010
Thanks for the replies gents, I am well aware that FGW are not operating out of Vic but thats how its come down to my database :) http://cl.ly/image/2x291Y1G1A0a
It must be as stated somewhat of a domino effect! It would be interesting to see how many SPADS occur and at what times of the year they occur most. I suppose that is something that I can do with this data at a later date.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
I don't read that as a problem for FGW as it's got 'Southern:-' before the mention of the SPAD... :?:
TP
tsr
15 Nov 2011
Between the parallel lines
However, this incident did in fact affect FGW, with at least one Gatwick Airport - Reading service being delayed somewhere between 5-10 minutes due to congestion at Gatwick. Unfortunately, I can't remember which service this actually was.
VTPreston_Tez
26 Jan 2012
Preston
Of course that was to be expected. Of course the major disruption is for Southern services, which I believe is more of what we've been trying to say.
BestWestern
6 Feb 2011
Coincidentally, I believe there was a SPAD affecting an FGW service this morning. I'm unsure of exactly where, but reports were that a distant was displaying green, but as the main signal came into view it was at danger. An automatic signal somewhere apparently, reason initially unknown.
tsr
15 Nov 2011
There was a signalling problem reported on NRE at Sholing (near Southampton) this morning. Was it that, perchance?
BestWestern
6 Feb 2011
Might well have been, that would fit the bill regarding the two aspect set-up.
