Castleton South Junction Renewal and M62 bridge replacement
Whisky Papa
8 Aug 2019
Back in March, I was travelling from Todmorden into Manchester Victoria and just happened to notice that the connection from the south curve at Castleton had been severed a few metres short of the junction. The characteristic "thump" and sway when passing over the switch in the Up direction, just before the M62 bridge, had gone too, so I assumed the junction had been entirely removed and plain-lined.
Yesterday, I noticed it appeared to have been reconnected. I assume this is a like-for-like replacement, only useable in the Up direction? I'd be very grateful for confirmation of this and some idea of how long the situation I described in the first paragraph lasted, if anyone knows?
Thanks in advance.
Geeves
6 Jan 2009
Rochdale
I rode through yesterday but the cross over was still missing and I didn't look again today
Certainly its more than two years but maybe less than 5. Its been a long time thats for sure
Whisky Papa
8 Aug 2019
Thanks for the response. However, I'm wondering if we are thinking of the same bit of trackwork when you refer to a crossover, or have I misunderstood? It was the connection from the south curve ie from the East Lancs Railway into the southbound line between Rochdale and Manchester I was meaning, which I understood was still connected until relatively recently. When I passed in March, there was a short stretch of ballast visible between the junction and the curve where the track had been lifted, which I certainly thought was a new development. Now the track there has been relaid.
Northampton
The diamond/fixed crossing was plain lined a while ago, I thought. If it has been put back I presume it will have gone back in as a like-for-like as any changes would have needed resignalling to add in the 3 sets of points and associated interlocking to the Box.
The M62 bridge is in need of renewal, and there is a restriction on only having one freight on the bridge at a time I believe.
CAF397
15 Sep 2010
Lancashire
Not just freight. Any train.
No trains should pass each other over the bridge, the signaller at Castleton East Jn should regulate accordingly.
cin88
16 Oct 2015
WCML
Bridge 48A (over the M62) is for want of a better phrase, absolutely knackered. Only one train can be on that bridge at any one time. They plain lined Castleton South Jn to save weight on the bridge. The current estimate is 2025 for renewal of the bridge so this arrangement will be in for a while yet, which led to a groan from me when I was informed by my LOM a few days ago.
Whisky Papa
8 Aug 2019
Thanks. Do you have a date for when it was plain-lined, please?
Also, I'm assuming the switch on the Up line must have been partially on the bridge deck, if this was a weight-saving exercise?
cin88
16 Oct 2015
WCML
Unfortunately I don't, it all happened before I moved onto the area. I'm not sure how much actual equipment is meant to be on the bridge deck, I do know that that set of points is though.
A prior Approval Application has been submitted to rebuild the bridge over M62 at Castleton
It is ref 23/00744/PRA56 on planning section of Rochdale Council website, but there appear to be no associated documents.
3 Feb 2007
Between Heaven and Hell
The bridge has had a weight limit on it for months now and it can only take 1 train over it. We are regularly held at either the signal before the bridge in the Leeds direction, or we get held out of Castleton in the Manchester direction.
CalderTrains
31 Dec 2022
Sowerby Bridge
I travel over that bridge very regularly and it's very common to be stopped waiting for traffic going the other way, or at least cautioned to a slow speed.
My local is Littleborough/Sowerby Bridge so when heading west it's easier to go from Littleborough
507020
23 May 2021
Southport
I take it that the original embankment of the Manchester and Leeds Railway that was severed to build the M62 did not have this problem.
Is it normal to submit a Planning application for a bridge rebuild?
A prior application approval.
More a notification of we are going ahead and any comments please to confirm development is acceptable, than we would like to apply for permission.
The exile
31 Mar 2010
Somerset
Are you suggesting the NR should put the embankment back?
An obviously shoddily-built bridge (knackered after only 55 years) built presumably by the motorway builders is now unable to fulfil its role so yes, put back the embankment until the motorway authorities get their act together. (Only partly joking - certainly not about a shamefully short lifespan on the bridge- should be measured in centuries!)
I think it's more a suggestion that the highways authority should be paying for the cost of the repairs/rebuild. Of course they won't!
Its a post tensioned bridge apparently. Doesnt matter who built it, it appears that they dont degrade in a very linear manner.
One article says it was built in 1969 with an agreement of British Railways Board and Ministry of Transport.
Unless anyone has access to the archives, or lives in the area and can find some info in an old local newspaper from 1969, then not going to know what was agreed.
It is unusual as it was triangular (4 tracks wide at northern side) as originally had a double junction on the bridge
But the bridge must be in bad way, if they are considering rebuilding it, rather than than putting a new single track bridge on eastern side next to it, so current bridge is reduced to one track to lighten load.
Replace concrete deck with steel deck or decks built nearby, move them using modular transporters, would be the likely solution? A few days work over a long bank holiday weekend perhaps? :D
Unless one or both of the abutments have failed, which would take a while longer.
