Carriage lighting
mike57
13 Mar 2015
East coast of Yorkshire
When were carriage lights left permanently on? Growing up i seem to remember that they would only be switched on for tunnels or as it got dark.
Reason it dropped into my mind is that some RER A (and may be other) trains in Paris seem to turn lights off when not in tunnels when light is good.
I personally prefer it as a lot of modern lighting is very harsh.
Rescars
25 May 2021
Does this mark the changeover from the dynamo/battery systems on individual Mark 1 carriages to the train supply being fed from the loco.
Going back, presumably the opportunity to switch lights on and off was a novelty when electric lighting was fitted. The same flexibility would have been tricky to achieve with gas, and even less so with oil pot lamps dropped through carriage roofs.
StephenHunter
22 Jul 2017
You could cover the light from an oil lamp with a movable shade for the lantern - or just turn the gas down to the bare minimum.
This is an antique Victorian bullseye lantern. Otherwise known as a dark lantern. This design was created in the early/mid 1800s for police to be able to have a portable lightsource. It was more convenient than carrying a giant lighted torch, in that the beam was focused and the lantern can be turned to "shut off" the light without actually having to extinguish the flame and later re-light it. This is really cool. The oil burner is non-functional after all this time and is likely from a different dark lantern BUT at least it contains one which makes for easier explanations. These were also used by the Railway and who knows who else. This design was used all over the world, not just Britain.
Acathater
11 Dec 2025
NorthWest
Mk1 coaches had lights on all the time. The compartments had switches to set high/low over the doors, but no off switch. Open coaches were permanently on
Rescars
25 May 2021
IIRC there was a switch in the end vestibule which turned all the lights in the carriage on or off. A conventional square carriage key was needed to operate it.
On the matter of carriage keys, my boss kept an old LMS one in his desk. One end of the T-bar was a special gas key for operating carriage lighting.
Dstock7080
17 Feb 2010
West London
On the Underground the end came with the implementation of OPO/OMO One Person Operation, previously Guards were able to switch lights off in open sections and switch them on for long tunnels. With OPO it became mandatory for lights to be on while the train was in passenger service.
Taunton
1 Aug 2013
The old Wirral Electric Class 503 certainly switched on/off between tunnel and open sections, controlled by the guard and always done at the same point near Birkenhead North, which led to the contradictory aspect that stock running off an electric supply was able to make this minor electricity saving, whereas Mk1 main line stock on adjacent lines, run off batteries, had to keep it on all the time.
A magazine article in the 1960s on a German S-Bahn (I think Hamburg) stated that lights were turned on/off for open sections by having the 3rd rail set at different heights, lower on the open sections, and a mechanical light switch on the collector shoes so when they dropped down the lights went off!
There were separate buttons for on and off, but these only controlled the coach they were operated in. The key switch controlled the whole train. Mk1and all mk2 had these on a cast metal panel and Mk3 had a steel plate.
Rescars
25 May 2021
Of course. I didn't RC!! You are quite right. It's been a while since I needed to know which button to press!
Paul AC
3 Aug 2025
Timperley
Indeed. The whole-train lighting is controlled via the RCH (Railway Clearing House) jumpers fitted to Mk.1/2/3 coaches. It's a three-pin circuit: energise one briefly at +24V to 'set' the train lights; energise another briefly at +24V to 'trip' the train lights; with a common negative via the third wire. The brief energisation of the relevant wire is done via the rotation of the key switch. I think I have that right; I'm not a "carriage technician"....
The set/trip lines through the carriages and RCH jumpers also carry Public Address, Driver/Guard Communications and the TDM (Time Division Multiplex **) remote control functions, each modulated onto their own different carrier frequency, which mostly avoids cross-contamination of the functions.
** applies to both the TDM used on the Edinburgh - Glasgow 47/7 push-pull train sets and the much more sophisticated TDM used for AC loco / DVT remote control; again they used different carrier frequencies.
Ashley Hill
8 Dec 2019
The West Country
The rule book only required the lights to be on during the passage through long tunnels or the hours of darkness.
Nowadays lights are left on permanently, on IETs for example there is not even an on/off button for train lights!
Trackman
28 Feb 2013
Lewisham
I think I know what you are talking about, am I correct in saying, basically an off an switch, but with no buttons? ( but has a T-Key hole)
Rescars
25 May 2021
I think the lights in a 4-SUB were directly connected to the traction supply. They certainly went out when coasting over a dead section. I assume there was a switch to turn the lights on and off, but maybe there wasn't.
StephenHunter
22 Jul 2017
The C and D stock on the Underground would have their lights flicker in certain sections too.
Beebman
17 Feb 2011
Twyford
I've found a picture of a Mark 1 coach vestibule lighting switch:
AVvXsEioYOQ_1YjJBpcLVT04M8QNnBkWqdf3msSsnvDGJLJGBHoGrBhd4mqbw7xL79b0nAPOim9njoQQ1L_kJ4KREuZ-xiJcb7ueenn2os7epq-ZEI0tgLmRecB5265HmVD_9rx1tVnn46ulLlk5rcO05GdysoV24nnnq6v6RICnlHr3SOVRXoOCokQ5yaKO=s596
Source: https://gwsrcarriageandwagon.blogspot.com/2022/05/evolution-survey-of-our-mk-1-coach.html
Tetragon213
14 Oct 2024
West Midlands
Iirc, in heritage the lights are only used when going into tunnels, or when it gets genuinely dark; usually, it's to protect the batteries. I believe some coaches also have manual switches on them which are completely independent of the guard's actions, e.g. the buffet coach lighting.
I have definitely done more than a few runs where the batteries gave up at the end of a winter's night!
Rescars
25 May 2021
Struggling to recall, but I think in a RBK or an RKB there were separate switches for the buffet, pantry, kitchen and staff compartment lights which were independent of the train lighting in the public areas. If you're slicing onions or tomatoes (for instance) you need to be able to see what you're doing!
There was, of course, compartment by compartment control over the lighting in sleeping cars. However things could go awry. I recall being woken on one trip by the conductor shining a Bardic lamp at me. It was barely dawn outside and the dynamo belt had fallen off en route.
Taunton
1 Aug 2013
You didn't want the passengers to operate the lights on their own
Sometimes you did. I recall a Mk2 on the WCML where the lights went off whenever a PA announcement was made, due to some multiplex wiring fault, and I was eventually going and pressing the On button in the vestibule after each one. Fortunately not many in those times, only guard live announcements.
Beebman
17 Feb 2011
Twyford
During the late 80s/early 90s I used to board my evening train home at Paddington in the same coach to be close to the exit at Twyford. On at least 5 or 6 occasions the coach was in darkness and I pressed the ‘on’ button on the panel to illuminate it.
Taunton
1 Aug 2013
The single carriage on the Hemyock branch did insufficient daily mileage to keep the batteries charged, so when the tank loco ran to Exeter shed and back for coal it took the coach along with it to give something of a recharge.
I believe the same was done with the 'emergency' Mk1 BCK carriage kept at Carstairs in the 1970s-80s, specially adapted at St Rollox works to have every combination, dual brake, dual heat, all classes, van, etc, in case a train arrived dividing for Glasgow and Edinburgh and one half lacked some facility. It had a regular run on a parcels train to Edinburgh and back to recharge the batteries.
The exile
31 Mar 2010
Somerset
Either we were on the same train or the fault went unfixed for quite a while!
Tetragon213
14 Oct 2024
West Midlands
I'm surprised they didn't just hook the thing up to a shore supply at Hemyock?
Taunton
1 Aug 2013
Given that a number of the stations in the area still, into the 1960s, had no electricity, and were lit to the end by oil lamps, as indeed were adjacent dwellings, something as sophisticated as a shore supply would be realms of fantasy.
80sGuard
10 Sep 2018
I think you're correct there, although it's now a distant memory, that the SUB's lighting circuit was tapped from the traction supply to provide incandescent lighting at 70v. Moving over gaps in the conductor rail at slow speed wouild cause the lights to go out briefly, but only dim briefly at higher speeds. I don't know whether gaurds had access to lighting controls, but I'm inclined to think not. The SUBS didn't have the ubiquitous 27 wire jumper that later units had. In addition to the brake pipe, there were three jumpers: power, control and lighting which had to be coupled in strict order when working in multiple They had tjhe same effect as the 27 wire jumper - they transferred control of the rear unit to the driver in the front unit, but because they were provided separately, I think (and I may be wrong), that there was no reason to divert one circuit through tjhe guards compartment. He woud have a light switch for his comparetment, but no other switchwork. I may be worth noting that the guard had no electrical means of contacting the driver (no Loudafon.e), it was whistle, flag/lamp, or drop the handle
Taunton
1 Aug 2013
Were the lighting circuits not arranged that in open saloons there were two circuits whose cables zig-zagged to alternate sides, and fed from opposite ends of the unit, so when crossing a neutral section or complex pointwork half the bulbs would momentarily go out, then a few moments later the other half would do so.
It's surprising that once the EPB concept proved itself the SUB units, most only a couple of years later and structurally the same, were not rebuilt to EPB standards.
I recall they did this on the 507/508s too until the mid to late 1980s when they switched to having them on all the time.
Nowadays the 777s are in a low light mode when not in tunnels in daytime.
The exile
31 Mar 2010
Somerset
Is the story about the 4-SUB that ventured beyond the lower-voltage inner suburban lines (? Further out than Woking) only to have every bulb blow when it hit the first truly 750V section true - or an urban myth?
