Carlisle, North Wales & Llangollen Released
MidnightFlyer
16 May 2010
Well, I know what I'm doing for the rest of today.
Also note the relatively-new Lancing and Wembley Suburban uploads, which I don't think anyone announced on here.
MidnightFlyer
16 May 2010
I noted a lack of one for Lancing too. I think there was a similar issue with one of the Wembley ones, it had to be downloaded elsewhere.
Jordy
9 Jun 2005
WCML South
If you've chosen the default path for install the timetables are in C:\Program Files\Simsig\Carlisle (or whichever sim you're on).
Jan
22 Dec 2008
If you've never used one of the more recent simulations before, you need to start a new game, open the options dialog (F3), go to the Control tab, and untick the "Use Public Documents folder" checkbox.
The reason behind this is that your not supposed to put user-created files (like timetables, and saved simulations) into the Program Files folder, because writing access there requires Administrator rights.
So therefore, in the future Simsig will store these files in its own subfolder within the Public Documents directory, where you don't need any special permissions for write access.
The problem is that at the moment, if I'm not mistaken, the installer might install the timetable files into the Program Files directory regardless, in which case it might look like there is no timetable at all.
wain77
9 Dec 2011
Another way of dealing with it is to open the options (F3), go to the 'Control' tab, then uncheck the "Use Public Documents folder" option. When you go to start a new sim, the default TTs should be in the right place.
D'oh, just seen Jan's message. Apologies!
Statto
8 Feb 2011
At home or at the pub
I'm having issues with the timetable for the Wembley sim. I've found the timetables but can't load them on to the sim, & that's dispite extracting the timetable to C:\Program Files\Simsig\.:(
