carlisle gobowen splits?
Cheds
29 Feb 2012
Hello
One adult, no railcard, travel to Gobowen Sunday 24 November lunchtimeish and return to Carlisle Wednesday 27 November late afternoon.
with routes through Warrington, Chester or Shrewsbury there should be some scope for splits I think. The quoted return is £78. Ive got this down, but only to £72. Any improvement? Thanks to all.
It's worth giving http://trainscanbecheaper.info a try.
The cheapest linear split is likely to be:
  • Carlisle - Oxenholme
  • Oxenholme - Burscough Jn
  • Burscough Jn - Gobowen
You must go via, and the train must call, at both stations.
The saving is a further £20ish.
Cheds
29 Feb 2012
thanks yorkie, but there is no sunday service to/through burscough junction, so I assume your idea is, shall we say, stuffed!
Tetchytyke
12 Sep 2013
Isle of Man
Freedom of North West 4-in-8 rail rover plus a return Chester to Gobowen, total £75. Valid via Liverpool or Warrington to Chester or Shotton, but not via Crewe.
ETA: Misread brfares, only a day return is available from Chester to Gobowen. That means you'd need two singles, taking the price to £82.
Depends if you'd use the other two days of the rail rover.
sonic2009
19 Jan 2010
Crewe
Gobowen to Preston Any Permitted SVR £30.50 (Valid anytime after 0415)
Preston to Carlisle Via Penrith SVR £36.60 (Valid anytime after 0415)
Total : £67.10
Further money can be saved on the Preston to Carlisle ticket by splitting at Oxenholme, remember the train must call at the station.
Preston to Oxenholme Any Permitted SVR £17.80 (Valid after 0415)
Oxenholme to Carlisle Any Permitted SVR £15.50 (Valid after 0415)
Total : £33.30 + Gobowen to Preston £30.50 = £63.80
St Helens is an obvious candidate for an alternative.
Good shout :)
Travelling via St Helens Central :
Gobowen to St Helens Central Any Permitted SVR £17.60
(Valid anytime, no BOJ on outward journey except to use station facilities)
St Helens Central to Oxenholme Any Permitted SVR £27.10
(Valid after 0415)
Total : £60.20
Sheepy1209
26 Oct 2011
There's still a handful of advances available for Carlisle Preston, e.g.
Outward - depart CAR 13:29 = £14 (TPE) or 12:49 / 12:53 are each £15 with virgin.
Return - leave Preston at 17:41 or 19:15, both have Virgin advances at £8.50
So with advances - Carlisle/Preston = £22.50, Preston/Gobowen SVR = £30.50, total £53
Cheds
29 Feb 2012
thank you all. I had the oxenholme split and had thought, like Yorkie, of going through ormskirk (which doesn't work on sundays).
But the preston split and svr to gobowen is really helpful because it allows any route. thanks again.
