Can I Cut the Corner?
Chris999999
22 Jun 2010
I will be travelling from Basingstoke to Brighton, then 2 days later travelling to Hastings, and another 3 days later returning to Basingstoke. I have a senior railcard and will be travelling off-peak.
I plan to buy an Off-Peak return from Southampton Airport Parkway to Brighton via Clapham Junction, as this is a bit cheaper than buying from Basingstoke, and as break of journey is allowed both ways I can start and end my journey at Basingstoke. I will also buy an Off-Peak return from Brighton to Hastings.
My question is, when I return from Hastings to Basingstoke, can I cut the corner and travel direct from Hastings to Clapham Junction, or do I need to travel via Brighton?
alistairlees
29 Dec 2016
You'll need to travel via Brighton as that is where your tickets are to / from.
JB_B
27 Dec 2013
Your return ticket from Brighton to Southampton Airport Parkway via Clapham Junction is valid via Lewes (as is the return from Hastings to Brighton via Polegate) so as far as I can see there's no need to go via Brighton and you can take the direct train.
alistairlees
29 Dec 2016
Good spot by JB_B. I had not realised the two validities intersected at Lewes, so allowing the direct train from Hastings via Eastbourne and Lewes to Victoria. Apologies for that!
Chris999999
22 Jun 2010
Thanks both of you for your help. I will return from Hastings to Clapham Junction via Lewes and not go to Brighton.
Whilst it is obvious that trains from Hastings go to Brighton via Lewes, it is not obvious that a ticket from Brighton to Clapham Junction can be used via Lewes, as this is not the normal direct route. Is there an easy way to find out which routes are valid with a ticket?
JB_B
27 Dec 2013
Not exactly easy but the information is in the routeing guide at-
http://data.atoc.org/routeing-guide
- if you haven't used it before it's a good idea to read the Section A (instructions) first - the most relevant parts in this case are...
1. Section B (pink pages) tells you that Brighton is a member Brighton Group and Southampton Airport Parkway is a member of Southampton Group
2. Section C (yellow pages) on page 205 tells you that mapped Journeys from Brighton Group to Southampton Group include travel on map combination LB+SW
( Since you're going via Clapham Junction I'd assumed you're on a route:Not London ticket. )
3. Section D (maps) shows that tracing a route from Brighton Group to Southampton Group on map LB then SW shows you can travel from Brighton to Clapham Junction via Lewes.
Chris999999
22 Jun 2010
Thank you very much. That is very useful. I now understand how to investigate something similar in the future, though I will still probably check here that I have done it correctly.
I will take a copy of map LB with me in case I get a 'difficult' guard.
marshmallow
22 Jul 2017
It is very frustrating that some staff lack basic knowledge of what tickets are valid, and furthermore that they "know" that certain tickets are not! I had a similar ticket recently and tried to break my journey at Falmer. The member of staff at the barrier said that it is definitely not valid, but that he would let me through anyway (as if he was doing me a favour!).
londonbridge
30 Jun 2010
I use the same ticket as the OP when travelling from Croydon to Eastleigh to vist my mother. It doesn't work the barriers at East Croydon, on the way back I show the ticket to the gateline staff and say ""I'm breaking my journey" and they generally open the gate without saying anything. However last time the gateline attendant had an attitude problem. I held the ticket out and said "break of journey", he looked at it and said "Southampton to Brighton? Where have you just come from"? I replied "Clapham, I'm breaking my journey". "Good answer", he replied, in a sarcastic tone and with a smirk on his face as he opened the gate.
marshmallow
22 Jul 2017
In my opinion if a ticket is valid for entry/exit at a station then one should be allowed through with no questions asked.
Similarly if a manual check is performed, this should be done to the same standard as an automatic gate. For example, the barriers at Victoria accept a railcard discounted ticket, however if I have my ticket manually checked (which they do at busy times to speed up the flow), I am sometimes asked to show my railcard. This seems rather pointless to me.
