Can I break my Tring to Worthing journey at Sutton?
Tomp94
9 May 2019
Hi all
I have a Worthing to Tring, return within a month, valid via any permitted route.
I would like to stop off at Sutton on the way back, using the victoria to horsham train from victoria, or the sutton loop thameslink from st pancras.
Then back to Worthing via either Horsham and Barnham or Norwood Junction and East Croydon.
Thanks.
marshlinker
18 May 2026
Romney Marsh
You can only go as far as Ford on the coastway but otherwise okay.
Edit: As per below there is an easement to allow travel via Barnham so all Okay
jfollows
26 Feb 2011
Wilmslow
Is there not an easement to allow double-backing via Barnham?
030141 Doubleback
Customer travelling via Ford may doubleback via Barnham. This easement applies in both directions.
Valid routes
  • Worthing - Brighton to London (all sorts of possibilities)
  • LB + EN
  • Worthing - Ford to London (all sorts of possibilities)
  • CW + LB + EN
  • LP + EN
  • SC + EN
  • SC + LB + EN
on maps at https://iblocks-rg-publication.s3.eu-west-1.amazonaws.com/yellow_pages.pdf
plus the easement already mentioned.
SC, for example, allows travel via Sutton.
Mcr Warrior
8 Jan 2009
Is the alternative route that the OP was enquiring about, i.e. Tring->Sutton (London)->Norwood Junction->East Croydon->Worthing, a permitted route without multiple tickets possibly being needed?
marshlinker
18 May 2026
Romney Marsh
Was that a 'yes' or a 'no'? Presumably the OP couldn't travel to/from Sutton (for their planned break of journey) along the line via Carshalton Beeches/West Croydon, in both directions?
The OPs post specified using the Victoria to Horsham service which travels via Mitcham Junction
It's a 'yes'. Map SC allows travel from London to Sutton via a variety of routes, including via Mitcham Junction or via Wimbledon. You could also get there via West Croydon but if doing so you are correct that you would then need to continue in the same direction, i.e. via Dorking.
