Class08Shunter
Can a Eurostar Class 373/e300 go to Amsterdam as I have only seen e320s at Amsterdam.
Not sure if this is the case - e300s have 1.5KV DC for the Ski Trains, which is the same standard the Dutch network uses. The Signalling was the big problem - you need the Dutch ATB for their classic lines and ETCS L2 for their high-speed lines, and it was easier to build additional trains (that were also German-capable) than to try and retrofit the systems onto the e300s.No, they're not compatible with NL's signalling/power supply, so only e320s travel beyond Brussels.
Interesting, thanks.The power may be the same but I do not believe the Pantograph behaviours are the same. NL requires height limited pantographs for gaps and bridges.
There actually is a special sign indicating that foreign trains need to lower their pantographs. Those should be in place at the only part of the route where you'd encounter bridges, as the very same route was used by the Belgian locos for Benelux IC-services several years ago.The power may be the same but I do not believe the Pantograph behaviours are the same. NL requires height limited pantographs for gaps and bridges.
they don't have to lower the pantograph...
NS-bridge
Trains not having a height limited pantograph will have to follow the signals indicated here in section 19.5.I don't believe the Class 373 will behave like what was seen in the video. The pantograph will spring up and strike the equipment where it resumes. Hence the requirement for height limited pantographs, nothing to do with lowering them.
